Question about Altec Lansing Multimedia Computer Speaker System Acs5
DC Power cord needed for Altec ACS5 speakers
Where can I buy the DC power cord?
  • 4 Answers
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
  • 10 Answers
SOURCE: Altec Lansing computer speakers , power requirements
You have to find out what the speakers are rated at then go form there. There is usually a placard or sticker on the back that says what watts and voltage they are rated at. Then you have to find out what plug goes in. Or you just buy an OEM plug
Posted on Dec 06, 2008
edwinmeyer
  • 57 Answers
SOURCE: I have Altec Lansing AVS 300 multimedia speakers with no power
Unfortunately the subwoofer supplies the power to the amp on the speakers, Once again I have the solution,
These speakers are factory molded so that the only way to open them is to break the factory seal
this can be done by sharply rapping the seam at the bottom of the speaker with a heavy screwdriver handle or something similar.
Now you need to supply power to the amp...If you do not have the subwoofer you will need a 4.5volt power supply, after removing the board from the casing find the red white and black wires connecting
the orange plug wire to it, Personally I removed the entire cord from the unit, shough you can splice in at this point if you desire.
Connect the white lead to your posative on your power supply by either splicing or soldering, connect the ground to the heat sink using the screw that is already there holding the chip to the sink. reassemble the speaker.....super glue... and you are now in business.
Ed Meyer
Owner AACS
www.alwaysaffordablesolutions.com
Posted on May 22, 2009
  • 232 Answers
SOURCE: i have a pair speaker altec lansing model
Buy some broken ones off eBay, throw them in the bin and just use the power supply :D
Posted on Dec 15, 2009
  • 226 Answers
SOURCE: Step up transformer for altec lansing atp3 that runs on 220 volts
What voltage are you stepping up to?
Does the unit run off a seperate PSU/Transformer.
Can you check your info please.
Posted on Jan 19, 2010
Replacement power supply - can i convert AC to DC output connector?
I'm not clear on the four pins of the DC power supply for the speakers. Do you think there two different voltages needed??? It's not worth trying to convert your ac power supply/ It would take a few parts and you will not end up with 18 vdc. You can purchase a 18 v dc adapter for as little as 15.00.
Jun 16, 2014 | Altec Lansing M604 Computer Speakers
What voltage and polarity do the ACS-5 speakers require?
Computers always use DC voltage. Computer speakers receive DC voltage from the computer.
DC voltage has a Positive and Negative polarity.
In the power jack of the speaker, the Center pin is the Positive connection. The outer shell is the Negative connection.
Center hole of the DC adapter plug - Positive.
Outer shell of the DC adapter plug - Negative
Voltage 5 Volts DC.
In case you need it,
http://support.dell.com/support/edocs/dta/acs5/
Nov 29, 2010 | Computers & Internet
Need to know the voltage on the dc power adapter for ACS5 model
Hard to find info. It looks like they run on about 14 to 15 volts dc. It's not critical. Check local electronic surplus stores or thrift stores before spending a lot more elsewhere.
Oct 06, 2010 | Altec Lansing Multimedia Computer Speakers
Jan 19, 2010 | Altec Lansing ATP 3W Computer Speakers
Need AC 15V 1.1A power cord for HK195 speakers
Hey, I was in the same situation. I tried a 9V DC (yes DC) converter I had and it works perfect. You can use a DC on a AC input - never the other way around. Due to insufficient power I get distortion at very high volumes... but I never play that high so I'm good..
Oct 07, 2009 | Harman Kardon HK206 Computer Speakers
No sound coming from ACS 48 Altec Lansing speakers
Hi janros123 - I don't know if this will help - I have a subwoofer ACS48 that needs satellite speakers (they are blown). Want to buy my subwoofer or sell your satellites? I will buy your broken subwoofer, too...thanks, and good luck! Greg illdooyoo at gmail dot com
May 16, 2009 | Audio Players & Recorders
Good Luck
Nov 20, 2008 | Altec Lansing AVS 300 Computer Speakers
Altec lansing ada745
the box like thing that you plug in the power cord....
which converts the ac supply to dc
Mar 27, 2008 | Audio Players & Recorders
Dc power cord
It should show it on the old cord, or on the DC jack on the TV set. A little diagram should be right by it.
Sep 14, 2007 | Sansui COM311AD 13 in. Combo
Altec Lansing Multimedia Computer Speaker System Acs5 Logo
706 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
