Question about HP LaserJet 4250n Printer
Hp 4250 error code 60.06
Giving an error code 60.06 prints a couple of pages and then stops
Printerguru
  • 10 Answers
SOURCE: hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Posted on Feb 13, 2008
  • 3422 Answers
SOURCE: hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jun 18, 2008
  • 22 Answers
SOURCE: hp 4250 error code 50.3
FALSE FUSER OVERTEMP INDICATION, POWER SUPPLY THAT DRIVES THE FUSING UNIT. MODEL 8150 DOES THE SAME THING. TRY TO GET A REFUND ON THE FUSER?
Posted on Jun 24, 2008
SOURCE: HP OfficeJet 9110 - Receive Fax Error 223
HP Officejet 9100 All-in-One Series - Changing the Fax Baud Rate Parameters Information It is possible to lower the transmission speed of the initial handshake of the HP Officejet 9100 to a lower value that may aid in compatibility and resolve 223, 232, and 283 errors. The following steps will walk you through configuring the setting. These are temporary settings. If the unit loses power, the settings need to be reconfigured. From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
  3. Enter the parameter ____ on the key board and press the Check Mark.
    • 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    The screen will read Cfg param val: 26
  4. Enter in the value ____ and then press the Check Mark .
    • 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    Screen will read Test -001+
  5. Press the Reset button until you get back to Ready *
Posted on Oct 13, 2008
SOURCE: HP Laserjet 4250 PCL6 prints only one page
I've had this problem before as well. I went into advanced printer settings and restored factory defaults.
Posted on Dec 18, 2008
How to clear error code 49.4c18 on HP laserjet 4250
any 49.xxxx codes are related to firmware crash.
the probable cause is a corrupt file in the print queue. remove the printer from the network then after network is disconnected - cycle the power on the machine ( switch off then wait 10 seconds switch back on)
the 49 error will probably clear . if so Clear All print jobs in Print queue on the computerr workstation. then reconnect printer and away you go!
if however the error remains then you will need to Upgrade the firmware or replace the firmare chip/formatter ( unlikely I've only ever replaced one out of thousands of calls for this fault)
Nov 04, 2012 | HP LaserJet 4250n Printer
Maximum file size for printing on the hp color laserjet 5500n - having issues with pdf files
If you are getting 49.XXXX error codes while printing PDF files, you can try upgrading the machines firmware.
This seems to be a common "PDF file printing" problem with the LaserJet 4250.
Oct 25, 2010 | HP Color LaserJet 5500 Printer
My hp 4250 laserjet printer displays an printer error 57.4 message when i switch it on. what could be the problem? since it can not continue the printer checkup progress.
<P><A href="http://www.printertechs.com/tech/error-codes/error-codes-index.php">http://www.printertechs.com/tech/error-codes/error-codes-index.php</A></P><P>&nbsp;</P><P>Plz check the the link for the detail error codes.</P>
Aug 28, 2010 | HP 4250 Monochrome LaserJet Printer
HP Laser Jet 4250/4350 series says its ready then it prints blank page and sends a message 51.20
Try a replacement toner cartridge first.If this fails, then i suspect it's a laser scanner fault. The error denotes beam detect error which is more than likely a laser scanner fault
Oct 12, 2009 | HP Office Equipment & Supplies
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
Error during print 'Remove all paper from bin'
HP Laserjet 4250 Network connected laserjet printer.
Steps to be follwed to set right :
01. Please check in number of desktops or laptops it connected.
02. Give proper IP Address in the Desktop or Laptop where it has to be orignally installed.
03. Being a network printer, lot of desktop or laptop users might have printing job iniated.
04. Right click the printer properties which is available bottom right hand corner ikon and delete or cacel all printing jobs.
05. The original desktop or laptop where the IP Address created will be rebooted. System should be restarted.
06. Try to print now to close this solution.
07. Still the problem persits, kindy contact local HP Authorised printer service engineer to set right this issue.
Have a nice working day.
Jul 17, 2009 | HP 4250 Monochrome LaserJet Printer
My hp 4250 dtn printer is carying(repeating) about an inch of text down the page three times as if the fuser is not working on that particular portion only
From the servivce manual:
Basically:
1 Inspect the drum for scratches or
other damage. Replace the print
cartridge for defects that repeat at
37.7 mm (1.5 inches), 62.8 mm
(2.5 inches), 54.0 mm (2.1 inches),
or 94.2 mm (3.7 inches).
2 Process a printer cleaning page.
See Running the cleaning page
manually.
3 If the problem persists, and the
defect repeats at 75.0 mm
(2.95 inches) or 94.0 mm (about
3.7 inches), replace the fuser (see
Fuser).
Jul 09, 2009 | HP LaserJet 4250dtn Printer
Error code 59.40 on laser jet 4250
Do you mean an HP 4250. If memory serves me right that error number refers to the main drive or cartridge drive. You may have broken the gear on the cartridge while installing it. Especially if your the type to slam it in there. It can happen with genuine and remans so don't go bemoaning reman cartridges...lol. Turn it off...put another cartridge in there...and see if if boots up. I work on printers for a living and had( I'm 95% sure ) that same error code a couple of weeks ago and fixed it for the customer over the phone this same way.
Mar 24, 2009 | Office Equipment & Supplies
Printer 4250n no print
What do you mean by logo? Do you mean the Menu Page?
Jan 30, 2008 | HP 4250 Monochrome LaserJet Printer
HP LaserJet 4250n Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
