Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
IT CRANKS BUT WONT START
I HAVE NOT USED IT FOR ABOUT FIVE MONTHS THERE WAS VERY LLITTLE GAS IN THE TANK SO I FILLED IT UP AND WENT START IT AND ALL IT WOULD DO IS CRANK AND WOULD NOT START
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • Briggs & Str... Expert
  • 133 Answers
Check compression and spark then if they are fine rebuild carb
Posted on Mar 12, 2013
95 tahoe, Bernardo Parker for a while whith no battery, now I put a new one ,, will cranks but won't start???
It may not be getting gas if it set for 6 months or longer the gas may have went bad and clogged ports depending if its fuel injected or carb .=, try carb cleaner in gas tank.
Mar 16, 2015 | Cars & Trucks
I replace my 1994 Toyota 4 runner gas tank with a used gas tank filled it with gas now it wont start why?
Did you use the old fuel pump or was there one in the used fuel tank? If you did use the old fuel pump check your fuses and relays. If the used tank had a fuel pump already in it then the fuel pump may be bad.
Jul 29, 2014 | Cars & Trucks
I replace my 1994 Toyota 4 runner gas tank with used gas tank filled it with gad now it wont start why?
third posting of the same question. It has been answered on one of your other posts. Let me know if you need more help.
Jul 29, 2014 | 1994 Toyota 4Runner
How can you tell if your car has jumped time? I have a 1998 buick park ave. that tries to start but wont.
check fuel filter and make sure its not clogging up, make sure the engine is getting fuel, have someone go under the car where the fuel tank is and have them listen when you turn the key to on to see if there is any sound coming from in the fuel tank, if not, then you may have burnt out the fuel pump. Fuel pumps are Great for randomly going out at a moments notice. those GM v6 engines dont jump time easily so it more than likely wont be that.
Apr 06, 2014 | 1998 Buick Park Avenue
Truck sat for a few weeks, gas tank was on empty...filled it to about 1/4 tank and now it wont start, it just cranks. I did spray either in intake and it fires but dies.
it sounds like the fuel pump needs replacing.by spraying either and it starts tells me there is no fuel getting to the cylinders.
Sep 10, 2011 | 1999 Ford F150 Regular Cab
I have a 2004 Pontiac grand am not wanting to start, Have a 2004 Pontiac grand am not wanting to start, it just cranks like it's out of gas but wont start. Had this problemHave a 2004 Pontiac grand am not...
Does it start soetimes? Has it been down all this time? Is it got enough gas? the gauge can be wrong. fuel pumps and gauges are failing alot as the tequies used to steal gas are breking things that peaple don't think about. Peaple steal gas to get to the job they haven't gotton yet. It's getting bad out there It was only once in a while I found this problem but now it's everyday. One in 5 no starts are out of gas and most of the peaple said they keep the tank full ( thier thief knows you and gets plenty, then next htings you know he bends the fuel gauge sender and takes all you gas or you don't but more as you think you have some and you don't.
Aug 05, 2010 | 2004 Pontiac Grand Am
I think fuel pump went out how can i check it? we just put gas and the car died out went to start it and it just cranks over and over but wont start
have someone turn the key but do not try to start. Also, listen by the gas tank for a 2-3 second hum. IF you hear nothing then check your fuses. If fuses are good your pump is bad. Pump is inside tank and will require removing the tank. I have done this before and it is a 4-5 hour job on a truck, maybe a little longer on a car.
Aug 03, 2010 | 1999 Ford Escort
2004 Jeep Grand Cherokee Trouble Starting
if the battery is weak,it does not have the rpm needed for the computer to start the vehicle.
if your immobilizer is kicking in,it will not start.
get the electrical checked out.
Apr 20, 2009 | 2004 Jeep Grand Cherokee
S10 pickup - engine won't start
when you put the kee on do you ear the gaz pump going if no get somebody to crank the the engine take a hammer and it the gaz tank most of the time the pump gonna kick in but get it check out you may have dirt from the fill up or simply change the gaz pump
Jun 20, 2008 | 1996 Chevrolet S-10 Pickup
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
103 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
