Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
Error code F5E1 - KitchenAid Architect Series KEBC107KSS Electric Single Oven
According to the manual, If the error code is a letter followed by a number, you need to reset the display.
Press LOWER OVEN CANCEL / OFF, UPPER OVEN CANCEL /
OFF or CANCEL OFFIf it comes back it needs to be serviced call
1-800-422-1230.
Please rate my solution, Thank you
Posted on Oct 26, 2012
What can I do for F5-E1 situation
Check this article as the cause could be the control board, the door lock mechanism or the Membrane Keypad!
Whirlpool Oven Common Problems and Causes
Jan 08, 2015 | Ovens
Kitchen Aid Superba double oven
f5e1 is a door locking error. try shutting off power for a minimum of 2 minutes to reset the control board. If you still get the error replace the latch. Here is the part to order.
Jun 19, 2013 | KitchenAid Architect Series KEMC308KSS...
F5E1 or FSE1 error code DOOR LOCKED LATCH NOT OPERATING
On this double oven, each door has it's own latch mechanism that consists of a motor, a position switch, and the door switch used to activate the cavity lights. Because the error indicated a latch failure (and the bottom door was locked), Start by cycling the power to the unit. Each time the power is removed and then applied to these ovens, both latches will lock then unlock the doors to ensure they are in the home open position. By doing so, you might be able to get the bottom oven door opened allowing me access to the latch assembly. With the latch removed, I try to begin a clean cycle so you could watch the motor operate and you will probably find that it will start to turn, but never would rotate enough to lock the door. Since the position switch was not actuated at the end of the motor operation, the F5 E1 error was again displayed. Replace the motor assembly
E
Nov 23, 2011 | KitchenAid Architect Series KEMC308KSS...
I HAVE A WHIRLPOOL MODEL NUMBER RF368LXKQ RANGE AND WHEN I TRY THE SELF CLEAN BUTTON I GET F5E1 WHAT IS THE PROBLEM
The F5E1 error codes means that the door light switch OR a switch on the self clean latch has failed. If the oven light comes on and goes off when the door is opened and closed it most likely going to be a switch on the latch thats the problem.
The part numbers are;
DOOR LATCH W10107830
LIGHT SWITCH 3195993
GENE
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I used the self clean cycle and it has cooled off now getting error F5E1 and won't unlock? Please help. I use my oven almost daily!!
F5-E1 is a door lock error. Depending on the extent of the error, a hard reset may recycle the door lock and allow you to use the oven. Turn off power to the oven for 2 to 5 minutes and then turn the power back on. Give the oven about 2 to 3 minutes to possibly reset.
If the error code returns, there a few different problems you may have.
  1. The door latch mechanism could be broken or shorted
  2. The may be a pinched or shorted wire
  3. The Oven Control Unit may be bad
If further assistance is needed, please submit the brand and model # of your oven
Apr 15, 2011 | Ovens
Have Whirlpool self clean electric oven model # F368LXKQ. Am trying to self clean-get a F5E1 or FSE1 error code and it will not start to self clean/heat. Any idea what the problem is?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 19, 2011 | Whirlpool Ovens
I have a whirlpool oven self-cleaning.. get code F5E1 or FSEI, when i set the self cleaning?
I live in apartment with a Whirlpool dishwasher and oven. Today was my first day to do automatic clean. After two minutes the "F5SEI" would pop up, then the door would unlock. I repeated this a couple of times. My mind wondered about a water source; perhaps the dishwater. Fortunately, I had a load of dishes ready to go. So I started the dishwasher, then the automatic clean on the oven. Behold! They work together like homies :)
Nov 15, 2010 | Whirlpool Ovens
My oven code is F5E1 , my oven was in self clean , now the door is locked
F5E1 is door latch assembly. One way that may work to unlock is to turn circuit breaker to stove off for few seconds then turn back on and door lock should activate and unlock. If not you are going to have to replace the door lock assembly.
Mar 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Inglis F5E1 Oven model: IJP85801
The error code F5 E1 is normally associated with problems cleaning
in this case latch not locking. If you did not initiate the cleaning mode then (as u indicate - was baking) then we have a bigger problem. The controller (clock) has malfunctioned. Press any key for about a minute - F2 should appear - then press cancel observe for about a minute - try operation - either back to normal or change control board
Aug 18, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
517 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
