Question about Mossberg Optics
Mossberg 835 firing pin - Mossberg Optics
    Habit-Forming:
  • 143 Answers
Numrich or Ebay. It's a model 500 firing pin. Same firing pin on all the 500 type guns.
Posted on Aug 15, 2016
3 Suggested Answers
agent91
  • 2100 Answers
SOURCE: I have a mossberg mod 352 KB with a broken firing
Go to gunparts.com online, they have schematics for every gun ever made and parts to boot. They sell to the public, certain items of course. Check them out.
Posted on May 30, 2010
o numrich gun parts
Posted on May 21, 2013
Just bought an 835 pump foerarm loose and wobbles is that normal ita a 12 gauge mag
assume this is a Mossberg. All pump shotgun forearms wobble from side to side and feel loose. As long as it functions properly (loads and ejects shells), nothing is wrong.
Nov 23, 2016 | Cars & Trucks
Mossberg 500 A old style firing pin; can I replace it with the new factory pin without changing bolts
It'll work but you'll need the spring, too. The old style pin was pushed back out of battery by the locking lug as you pumped the gun. It won't push the new style so you could theoretically have a stuck firing pin fire a shell out of battery. Be safe, just use the firing pin for your bolt....or buy a new bolt off of Ebay. The entire bolt is a direct switch out.
Jul 30, 2016 | Mossberg Optics
How to remove firing pin spring from mossberg 835 shotgun
Small pin at the back of the bolt. Top edge. Tap it out. As with all pins, just drift it out to the point that you can grab it with smooth pliers and twist it out. Do NOT drive a punch any further into that hole than you need to. Punches widen as they go and you'll deform the hole. Pins are cheap to replace, bolts aren't.
May 06, 2014 | Mossberg 835 Ulti-Mag Mossy Oak Breakup...
Where can i find a magazine loading chamber for a mossberg 835 12 ga. pump? and how much?
I'm sorry but I don't quite know what you mean, sir. Can you explain a bit?
The 835 is a tube mag pump action. You load it by slipping a shell into that open area on the bottom of the gun, slip the shell forward into the tube until it's thumb knuckle into the tube. That gets it past both shell stops.
Apr 09, 2014 | Mossberg Model 835 Ulti-mag Turkey/deer...
I have a mossberg 385t,he took the bolt out to clean it and now cant get it to go all the way back in......What do i do?
This may be a bit tricky. If you have pulled the trigger as you re-insert the bolt and that has not worked. You may have to arm the bolt, try with safe off and pull the trigger as you reinsert the bolt. You may have to pre rotate the Coc piece into the slot in the receiver.
Jul 18, 2011 | Mossberg Marlin Rifle 992m,989,mossberg...
I have a mossberg 4x4 rifle bolt on action 30 06 i have alot of misfire catridges all of them they have that they get hit from the pin ,but i guess not hard enough to fire
I would suggest that the firing pin channel needs to be cleaned. There may be a bit of crud or rust that is keeping the firing pin from applying a consistent strike to the primer. There may also be a burr that needs to be cleaned up.
Mar 20, 2011 | Mossberg Sport & Outdoor - Others
Firing pin not working
Take the bolt out of the rifle and take the firing pin out of the bolt. Thoroughly clean the firing pin and surrounding spring with a harsh solvent (Gunblast works well--be sure to lubricate the spring and pin after cleaning).
Nov 28, 2010 | Mossberg Optics
Mossberg 800 bolt disassembly instructions
TO DISASSEMBLE BOLT - Depress Safety
Cap' Lock Plunger #8 and turn Safety Cap
# 1 counterclockwise. Striker Spring #9
and Firing Pin Assembly #10 can then be
removed.
TO REASSEMBLE BOLT - Replace firing pin
assembly and striker spring. Insert safety
cap and turn clockwise making sure that it is screwed forward as far as it will go. Then unscrew
until the hole for the safety cap lock plunger is in line
with the cam slot in the bolt. Drop lock spring and
plunger into hole and face cut out portion toward bolt.
Depress plunger and screw cap clockwise until the
plunger is engaged in the recess in the rear of the bolt.
Oct 26, 2010 | Mossberg Sport & Outdoor - Others
My model 742 lever action missfires every 3 or 4 rounds.dimple on spent cartraige is much deeper than missfired shells
This may be an indication of a broken firing pin, dirt in the firing pin channel, or an over oiled firing pin/channel. All will exhibit this behavior. A through cleaning is called for, with dis-assembly to follow for parts inspection.
I have also experienced this behavior from a weak hammer spring.
Oct 10, 2010 | Mossberg Marlin Rifle 992m,989,mossberg...
I have a mossberg mod 352 KB with a broken firing pin need a schematic of the rifle or the firing pin, any help would be appreciated. Thanks
May 29, 2010 | Mossberg Marlin Rifle 992m,989,mossberg...
Optics Logo
143 people viewed this question
Top Mossberg Optics Experts
obsteiner
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Mossberg Optic Expert? Answer questions, earn points and help others
