Question about Philips Phillips 2422-549-01929 Tv Remote
Phillips tv wont change channel - Philips Phillips 2422-549-01929 Tv Remote
    Genius:
  • Philips Master
  • 2,432 Answers
Tried with pressing the channel button at the panel tv or using with the remote controller doesn't work?.
Posted on Oct 28, 2012
My Phillips tv is it wont do nothing it wont turn the volume up or down or change the channel
Sounds like main system control memory IC fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 08, 2015 | Televison & Video
I have a Phillips SRU3006WM/17 remote I need the
just press your setup button untill the red light stays on then hit TV or what ever your trying to program then keep clicking channel up until the channel changes and once it changes hit enter or setup button
Jan 08, 2010 | Philips Televison & Video
I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Oct 19, 2009 | Philips Magnavox Learning Universal Remote
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
Phillips tv 32pf77320A/37
problem was with the FIOS Box not the phillips TV. The box appeared to be working but would not respond to channel changes and is being replaced.
Jul 12, 2008 | Philips TV Tuner Video Capture PCI Card -...
Need code for phillips remote
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 09, 2008 | Philips Televison & Video
Phillips pm3s lost code book:
Hope this helps :)
May 31, 2008 | Philips PM3S Remote Control
Panasonic pv-df2704 27"
Try this:
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press the CHANNEL DOWN button to backtrack through the library until the device changes channel. Pressing CHANNEL UP changes the direction to forward again.
5. Press and release MUTE to install the code.
If it's still not working, these are the codes that are given for your tv on the phillips website: 0718, 0416, 0007, 0618, 0807, 0039, 0739, 0345, 0696, 0901, 0608.
May 29, 2008 | Philips PM435S Remote Control
Channels are not available on phillips tv
HI
CHANGE YOUR TV TUNER CHIP.
ALSO PUT REMOTE CONROL CHIP AND NEW REMOTE .
Mar 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Phillips TV/VCR combi 14PV400/07
To solve this problem, cancel the wake up alarm !
Dec 23, 2007 | Philips 14PV225 14 in. TV/VCR Combo
Philips Phillips 2422-549-01929 Tv Remote Logo
158 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
