Question about HP PSC 1610v All-in-One Printer
Printing Each time I try to print, a box appears stating output file name, what do I do
  • 700 Answers
You need to go into the control panel and make sure that the printer that you are trying to make print is the prefered printer . it sounds like right now your trying to print to the computer xps.folder instead of the printer there hsould be a setting the you can set up yoiour printing preferences from the buton at the top of oyur sceen that says page setup. click on the then click on tehbox and scrool to the printer that is hooked up and you are trying to print with. Hope this helps.
Posted on Jan 03, 2009
Apparently there is a bug that HP is not fixing. Following is not a solution, only HP can solve this problem but a "workaround" for the time being, allowing you to print the file as image. Keep in mind that the printing will take longer time, because the file is output as bitmap, and that this way of printing it's not good enough for color proofing of any sort.
Check in the specific software Print dialog window, if you can print the file as image. Sometimes the controls are in the advanced options. In Acrobat, check the box for Discolored Background Correction in the PostScript tab of the Print dialog window, and if that doesn't help, check Print as Image check box.
Aug 18, 2010 | HP Color LaserJet 2600n Printer
The print que does not empty after a print job has
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 11, 2010 | Alps MD 5000 Thermal Printer
I have been using Adobe 7.0. and can no longer print the doc
reinstal the program because i think you or someone else made a wrong setting.
Nov 23, 2009 | Computers & Internet
What is print to file? What is output file name?
It is windows way of storing a document for printing later.
It will save the job you want to print at another time but ask you for a file name so that you can give it a name you will remember.
It will do this if it is set as the DEFAULT printer.
To change that and provided you have a printer installed then go to CONTROL PANEL / printers and faxes / then right click on the printer you want as the default and on the box that opens will be that exact option, click it and you are done. it wont ask you those questions again.
If this information was useful please click below
Aug 19, 2009 | Konica Minolta magicolor 2550 EN Laser...
Cannon ip4300 does not recognize when printer output tray is open
The micro switch on the door may not be working. You need to fix it or replace.
May 16, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Gateway Computer will not send any document to any printer
ur default printer might be set to microsoft image printer...
go to control pannel, then go in printer & fax then right click on appropriate printer & click on set it as default try printing
Apr 10, 2009 | Gateway (4000635) Motherboard
Its keeps asking for my output file name when i go to print.what is a output file name ?
Sounds like whatever your printing to is set for print to file or your default printer has changed.
Go into the control panel, select printers, select the printer that you want to use and press the right mouse buttons for properties.
Select the ports tab and make sure that the file box isn't checked and that the USB port is (or whatever port your printing with).
Press ok
Make sure that you printer is set for default printer.
Jun 10, 2008 | Office Equipment & Supplies
Won's print pdf files
Trouble with the HP Laserjet printed output may be solved by using the following settings (or similarly named ones): "Use raster Graphics" (instead of "Use vector graphics"). This may fix the problem of "reversed" text (white on black background) not printing, as well as other problems. "Download TrueType Fonts as bitmap soft fonts" (select "bitmap" instead of "outline" or "graphics"). This may remove the overlapping of text on the printed document. "Graphics dithering" select "coarse" or "fine" (instead of "none"). This selection may improve the quality of images contained in the document. You can find all these settings in your printer properties. Go to File, Print, click Preferences, in Printing Preferences, click one by one all the top options, and change one of the top solutions, one at the time, checking your printing output. Always check if you have the latest version of Adobe Reader Program. If not download the latest version from Adobe, it's free. Is this the first time that you have the problem? or with the same printer (HP 4si), did you were able to print PDF files in the past?
Sep 10, 2007 | HP LaserJet 4si Printer
HP PSC 1610v All-in-One Printer Logo
48 people viewed this question
Ben Johnson
