Question about InFocus IN34 OWIZ136606413601
How to replace light tunnel on InFocus IN34? - InFocus IN34 OWIZ136606413601
  • 17 Answers
SOURCE: Infocus X3 light tunnel
Are you speaking of the small prism shaped tunnel or the lamp itself? The prism or light tunnel may be accessed underneath the metal bracket that holds the color wheel in place. Be extremely careful as even breathing on this may cause it to collapse (ok, I exaggerate).
Posted on Feb 19, 2008
SOURCE: i need a new light tunnel for my infocus X2
Was actually looking up a different problem with an X2 and came across this thread.
I do electronic repair, and often do repair on projectors with this light tunnel problem. Probably 3 a week!
I came up with a solution about a year ago. It's a tunnel peice made of highly resilient carbon fiber, lined inside with extremely reflective mirrored stainless steel.
A company here in St Louis builds them for me and I go through quite a few!
If anyone is interested, feel free to email me at mhale@ahvio.com. I charge $50 per replacement tunnel (They are pretty expensive to make). Plus $10 for shipping to anyone in the US, unless you want to come by and pick it up.
I can include a extremely easy guide to install (Its VERY easy!)
These carbon fiber replacement tubes are a solid peice, unlike the factory that is just glued together mirrors :/ They are morons! haha
I've been using this replacement tubes for about a year now and installed well over 50, so I swear by them! Very resilient to heat, and very resilient to someone installing it that isn't very careful. It's almost impossible to break!
Also sale homemade LED super high flux projector bulbs for the X1, X2, and X3. May be able to build a bulb for a different brand, depending on what the current bulb is like.
These LED bulbs have a life of 40,000+ hrs and use very little power, and produce VERY LITTLE HEAT! Cheaper to build than the factory ones, at about $175 for a complete bulb with assembly. Have about the same ANSI output as the standard bulbs, I actually think it's a little more than the rated (like 50 more lumens or so~)
If interested in either, feel free to hit me up! Willing to send parts, or can do install myself.
Posted on Mar 01, 2009
  • 8 Answers
pls send the tunnel photograph
Posted on May 27, 2009
  • 3 Answers
SOURCE: Fixing an Infocus X2 Light Tunnel Problem...
I have managed to get hold of a few light tunnels for the optoma X1,X2,X3 projectors if you need to get a replacement drop me an email at Sales @ herefordict. co.uk, Ive had the same problem except the silver coating the tunnel flaked away.
Posted on Feb 07, 2010
  • 74 Answers
SOURCE: infocus in34 bulb replaced now won't light back up
looks like you power supply is defective. My best guess is that this is the first time in a while that you have physically disconnected the projector from power. If the power button on the projector doesn't come on its your power supply. Need to send it to a repair shop, or someone like me that can repair projectors.
Posted on Apr 22, 2010
Replace light tunnel infocus 4805
Hi, to get the basic instruction on how to clean/fix the 4805, click on this LINK...
Thank you.
Jun 06, 2012 | InFocus ScreenPlay 4805 Multimedia...
Infocus IN34 all indicator lights on
Power Supply problem. Check for "Bulged" capacitors in the output circuit ( 5 parts 470uf @ 16VDC). Also an indication of this problem is to remove the lamp cover and plug in the AC power cord. If the fans run slow....this is the problem.
Aug 29, 2011 | InFocus Work Big IN34 DLP Projector
I have a vertical shadow about 1-2 ft in width running up the right side of the projected picture. The bulb was just replaced this year and the shadow didn't start until some time after the bulb was...
The light tunnel has collapsed. Google "infocus light tunnel." You can glue it, as I did, but it tends to break again. From what I have read nobody has a good fix and the manufacturer has ignored the problem which has alienated a lot of customers. They won't even sell a replacement tunnel. Good luck!
Dec 01, 2010 | InFocus X1 Multimedia Projector
Infocus in34 bulb replaced now won't light back up can't get bulb to work to get to menus
Apr 20, 2010 | InFocus Office Equipment & Supplies
InFocus 4805 - right 1/3 is fine, middle 1/3 dim, left very dim.
the light tunnel is collapsing and needs replacement. the part itself is relatively inexpensive, but you have to be careful if you want to replace it yourself. it's under the colorwheel, which is delicate. when you remove the top, front, and rear panels, remove the colorwheel (which is between the lens and the lamp) and carefully set it aside. there are 2 screws holding the light tunnel bracket in place. remove them and the bracket. pull out the pieces of the tunnel (little rectangles of mirror) and replace with a new one. reverse the steps to put it back together. by the way, you can get the part from any infocus authorized service center (check the infocus website for the one closest to you). part # 306-0095-01
Oct 14, 2009 | InFocus ScreenPlay 4805 Multimedia...
I have an infocus in26 projector that has a shadow on one side of the image. i have been told this is indicative of a light tunnel collapse, is this a problem i can repair and if so how do i get the new...
it is the light tunnel. it is moderately easy to replace. just remember which screws go where. remove the lamp door, the top, rear and sides (8 screws on bottom, 2 in back). you'll see the colorwheel between the lamphousing and the lens. unplug the 2 cables for the colorwheel from the main board. unscrew the colorwheel base. the tunnel is under the metal clip next to the colorwheel. remove the clip and tunnel. replace tunnel and replace the clip, colorwheel, top, and lamp door. the top comes off as one piece, but must be replaced as 2 pieces. there are clips attaching the front to the top.
the part number for the tunnel is 306-0113-xx (if you have a in26+, it's # 306-0122-xx) and you can purchase it from any authorized infocus service center (find the closest one to you on the infocus website).
Aug 27, 2009 | InFocus IN26 Multimedia Projector
Feb 07, 2008 | InFocus X1 Multimedia Projector
InFocus IN34 OWIZ136606413601 Logo
54 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
