Machine won't wash
LG WD1015FB on quick 30 cycle displays error code 1E
Sent machine to scrap metal
Posted on Jan 08, 2009
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
I have a LG WD-1018C washer that wont spin out .. it just keep starting and stopping in about 30 second intervals ... an error code has just come up ... 1E ...can you help please ? Steve
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Feb 20, 2015 | LG Washing Machines
My washing machine keeps displaying error code F17 and won't go on. Does anyone know what this means and what I can do to fix it?
F17 indicates no water coming into the condensing chamber during drying.
Unplug the appliance.
Take the top off.
Check to see if the condensing chamber below the heating chamber is blocked.
Oct 15, 2012 | Siemens Washing Machines
My washing machine had an error code of 1E, and now will not wash on any setting except the "quick wash" - and even then, occasionally the detergent will not go through. It is an LG front...
It is not 1E, but I.E which is "INLET ERROR", the inlet valve is not letting the water through, it does sound intermittent though, please check the following, if it does not solve your problem, the Inlet valve should be replaced (Which can be bought at any reputable Appliance Spares Shop)
- Is the tap open fully?
- Check the Inlet Hose, is it kinked in any way?
Hope this helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM-2277HW Front Load Washer
I have an LG F1256QD machine that keeps stopping half way through the cycle with the message 1E displaying. I've lost the manual! Any idea how to solve the problem please?
1E = WATER INLET ERROR
• Correct water level (2 level) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes.
Check to see that your water valves are open all the way. Check the strainer in the water hose for any buildup or blockage.
Here is the "Service Manual" for your machine.
Happy Holidays! Rick
Dec 11, 2010 | LG Washing Machines
Error code FE
From the manual ,FE means Water level is too high due to a faulty water valve. hence the possible leak
Dec 22, 2009 | LG WM2277H Front Load Washer
Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
May 19, 2009 | Samsung SW62ASP Top Load Washer
LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Aug 02, 2008 | LG WD-1280FHD Front Load Washer
LG LDF7811ST 1E code
Are you sure it's 1E and not LE error code??  The symptoms you mentioned indicates that it is an LE error code and the motor has an issue.  You will need to call a qualified LG technician to diagnose and resolve the problem.
Jun 28, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
