Question about Lands Phones
How to turn ringer back on arc110 I can't find sound switch
Turn ringer on
To set the Vtech T2326 ringer:
there are only four ringer tone/volume choices plus "off" available
1. Press the PROG end of the "SELECT/PROG" rocker switch.
The display will light and show "DIRECTORY"
2. Press the right side top button "VOL +/DIR"
The display will change to "SPEED DIAL"
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: [number] ( 1 - 4 or OFF )"
4. Press the SELECT end of the "SELECT/PROG" rocker switch.
The "RINGER: [number] ( 1 - 4 or OFF )" will blink and the ringer will sound.
5. Press the right side top button "VOL +/DIR" The display will change from "RINGER: 1" to "RINGER: 2" and the sound will change accordingly.
6. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 2" to "RINGER: 3" and the sound will change accordingly.
7. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 3" to "RINGER: 4" and the sound will change accordingly.
8. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 4" to "RINGER: OFF" and the sound will cease accordingly.
9. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: OFF" to "RINGER: 1" and the sound will change accordingly.
10. ...and so on, cycling through the four choices & OFF: when you decide to select one, press the "SELECT" end of the central "SELECT/PROG" rocker switch.
11. The display light will go out, the phone will chirp in acceptance, and it will be ready to use the chosen ringer. --
Sep 07, 2013 | Vtech T2326 Cordless Phone
Phone rings but no sound
turn the phone up side down you can see the ringer switch on off and the ringer volume try to adjust them to on..then test the phone ringer if nothing happen the ringer speaker must be faulty and needs replacement..
Sep 30, 2011 | NEC Electra Elite DTU 16D-2 Corded Phone
Phone will not ring on incoming calls
Your phone might be set to silent. On the upper left hand side of the iPhone, there is a little switch. Switch it on/off to silence or set the sound of the ringer. If the problem persists go to Settings > Sound Settings > Ringers & Alerts
Jun 30, 2011 | Apple iPhone Smartphone
How do u take off the mute icon. because every time i get a call or text it never rings just vibrates?
It's in the "Sounds and Ringtones" setting. You just have to switch the ringer on. There is an easier option. There is a ringer switch located on the side just above the volume control buttons. Slide to turn the ringer and notification sounds on or off. (Red means off.)
Feb 25, 2011 | Palm Pixi Cell Phone
My phone is ringing but cannot hear the sound only blinging the light. So how can i return back the ring sound?
Only 3 things make it not ring, there's a switch for the ringer on the left side of the phone, it needs to be programmed to ring in the 40x's, or the ringer is defective. If it rings on the intercom (with the AUTO ANS) turned off, it must be programming.
Carl
Jan 24, 2011 | Panasonic KX-T7730 Corded Phone
The iPhone does not ring, only vibrates
There's a switch on the left side at the top of the iphone that turns the ringer on and off. Make sure this is towards the front of the phone to enable the ringer
Jul 26, 2009 | Apple iPhone 3GS Black (16 GB)
I dont know how to adjust the ringer volume
The manual is available for free download from www.manualslib.com
A Google search on "vtech t2326 manual" will take you right there .... follow their site instructions,
enter the "spam protect" numbers and choose "download the .pdf file" Be careful of clicking on the
advertising that might take you into strange areas for other purposes.
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: 1" ( or "RINGER: 2 or : 3 or : 4 or : OFF" )
10. ...and so on, cycling through the four choices: when you decide to select one, press the "SELECT" end
11. The display light will go out, the phone will chirp in acceptance, and be ready to use the chosen ringer. --
To preload names & numbers into the DIRECTORY is a bit more arduous but not difficult; there is
a limit of 10 entries after which attempting to add another will result in a "MEMORY FULL" alert
being shown. Hint: during name entry, the "VOL -/CID" button will backspace/erase letters and the
"VOL +/DIR" button will enter blank spaces. Letter selection is familiar to text messaging ie, the letter B
is a result of "22" being keyed, the letter R is "777" etc.
Good luck !
Jun 08, 2009 | Vtech T2326 Cordless Phone
My son turned off the ringer on our uniden portable phne and I cant figure out how to turn it back on. Chris
Pick up the handset and underneath the handset is an off on switch for the ringer
Handset ringer switch
This switch turns the handset
ringer on or off.
Page 20 of the manual
EXAI985HS English 2,578 kB Product Details
Apr 17, 2009 | Uniden Cordless Phone EXAI985
Panasonic cordless phone,
press menu,scroll down to ringer settings,hit select,scroll to ringer volume and hit select then press up the round button in the middle until you hear it make a "ring" sound. adjust your preferred volume and hit save.
Oct 16, 2008 | Panasonic KX-TG5632 Phone
SCH-u410 Phone "All Sounds Mode Off Activated"
Press and hold down the # button until it says "exiting silent mode...
Apr 25, 2008 | Verizon Communications Samsung SCH-u410...
Lands Phones Logo
20 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
