Question about RIM BlackBerry Pearl 8100
New phone, do not know if i have pressed keys i shouldnt have or not. the phone will not ring or vibrate. there is message at top. "data connection refused" help please
Went to at and t
Posted on Jan 04, 2009
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
Our phones only ring 4 rings before going to message bank. We have a telstra wall connection, and 3 panasonic KX-TG1840AL
You can change the number of times the phone rings before the unit answers calls.
You can select 2 to 7 rings, or “Auto”.
“Auto”: The unit answers after 2 rings when new messages have been recorded, and
after 5 rings when there are no new messages. If you call your phone from
outside to listen to new messages, you will know that there are no messages when the phone rings for the 3rd time. You can then hang up without being charged for the call.
1 Press OK.
Select Answer System, then press >(Right navigation button).
2 Select Settings, then press >.
3 Select Number of Rings, then press >.
4 Select the desired setting, then press >.
5 Press End button
725a0bb.jpg Thank you
Aug 10, 2010 | Cell Phones
How do I add new text message alert tones for my pantech link phone
to change the alert tone for pantech link: go to “menu”, go to “settings”, go to “profiles”, if you want it to ring and vibrate, choose “vibrate and ring” then go to “edit” which is the key at the very top left of the keypad, go down until you get to “message sound, go to “select”, “audio” and then choose the tone you want. hope that helps…i just figured it out today.
Jul 03, 2010 | Cell Phones
I own LG VX8360 and can't figure out hoe to turn ringer on. Can you help me?
To restore the ringer it will depend on what mode your phone is in:
Vibrate Mode:
Sets the phone to vibrate instead of ring.
To set Vibrate Mode, with the flip open, press and hold the # key .
To return to Normal Mode, press and hold the # key again.
Sounds Off Mode:
Quickly deactivate your phone's sounds when you're in a place where phone sounds would be disruptive.
From standby mode with the flip open, press and hold the lower side volume key for 3 seconds. To return
to normal sounds mode, press and hold the upper side key.
Airplane Mode:
Turning on Airplane Mode will disable all wireless communications.
1) With the flip open, press the Menu key.
2) Use the Directional Key (top center of phone) to scroll to 'Settings and Tools'.
3) Press the 6 key for Phone Settings.
4) Press the 1 key for Airplane Mode.
5) Use the Directional Key to highlight a setting, then press OK.
On/Off
Mar 30, 2010 | LG VX8360 Cell Phone
THE PHONE FLASHES BUT DOES NOT RING? We had a power cut the other day and since the phones have not rung, just flash? Anyone know why? We have 3 lines coming into the building. The lines have all been...
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS.
The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)The display should say line 002: appear only
repeat procedure for remailing active lines
If your system uses the older programming template,
then Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
the display says A. Configuration
the display will say1. trunk/line data
Press the next key (bottom right arrow) .
the display will say 2.line access
the display will say line assignment
Press the next key 2 times(bottom right arrow) .
The display should say ringing.
Press the show key (top right arrow).
the lines should be listed as appear only change to appear and ring
press Rls when finished
Oct 23, 2009 | NorStar M7208 Corded Phone
My Slice phone no longer rings out loud or vibrates when a call comes in. How do I restore those settings?
Check out this link for a PDF manual for your phone. Just copy and paste into your browser.
http://safemanuals.com/user-guide-instructions-owner-manual/UTSTARCOM/PCS1400-_E
I got this info off of page 60 from your manual.
CUSTOMIZING YOUR PHONE VOLUME
Control the volume for Ringtone, Speakerphone, Headset, and Advanced settings.
Ringtone
Set ringtone volume and incoming call alert options:
1. Press [Menu], then press "Settings".
Press "Sounds", then press "Volume".
2. Press "Ringtone".
3. Press / to adjust the volume level. Press to select Vibrate when High is the volume level.
The volume settings available are:
• Silence all: All sounds are off.
• Vibrate : Phone will vibrate to alert you of incoming call or message.
• Off: Only the ringtone is muted.
• Ringtone mode: Low, Medium, High.
Tip • You can adjust the ringtone volume with the side keys.
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Oct 05, 2009 | UTStarcom PCS1400 Cellular Phone
I need an extra line to ring on my phone
First, you'll have to know what the line number is in the system for the new line.
To get the line port number, on the set/s that the new line appears on press feature *0 and the the new line.
The display should say for example L025:LINE 05.
The port number of the example is port 025.
write the port number of the new line down for future reference.
Programming2.gif is done on M7310, M7324 and T7316 sets.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should say line 001: appear& ring
press next key (lower right arrow)til you see the line port number you wish to program
The display should say line 0xx: appear only
press the release key when finished
Sep 29, 2009 | Nortel Meridian M7208 Corded Phone
My motorola pebl phone will not ring
Hii
can u plz chk and tell me if ur profile is set into vibrate mode? and regarding keys, u can set the key tone volume to zero.
if ur a new user here is wht u hav to do
> MENU > RING STYLES > Change it to LOUD or VIBRATE and RING
Regards
Hope it helps u
Sep 11, 2009 | Motorola Cell Phones
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
N70 phone showing no notification for incoming messages
hi to all
try this. switch off your phone and turn it on. while phone is starting up. press the * key + answer key(green) + 3 key together till the welcome tone play.
BE SURE YOU BACK-UP ALL YOUR FILES SPECIALLY PHONE BOOK FOR THEY WILL BE DELETED.. YOUR PHONE GOES BACK TO ITS ORIGINAL SETTINGS.
HOPE THIS WILL HELP YOU..
Nov 04, 2008 | Nokia N70 Cellular Phone
RIM BlackBerry  Pearl  8100 Logo
41 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
