Question about Acoustic Solutions Audio Players & Recorders
I have an acoustic solution Ds533 5.1 sound syatem the problem is that it takes long to fire up and produces huming or static sound.
Ds533
What type of guitar is it other than accoustic need more details
There are two main types of acoustic guitar namely steel-string acoustic guitars and classical guitars. Steel-string acoustic guitars produce a metallic sound that is a distinctive component of a wide range of popular genres.
May 10, 2015 | Music
My Line 6 Variax 300 acoustic takes about a half hour to "warm up" before it functions properly. I half to believe that something in the circuitry has a soldering issue, or a specific part is failing. I...
Leaking capacitors on the pre amp/processor board. Very common in older battery powered equipment. They produce a nice product at a fairly hefty price and then skimp on the quality of component.
Aug 29, 2017 | Line 6 Variax 300 Acoustic Guitar, Steel
I have a Takamine acoustic eletric guitar model number eg560c serial numbers 2413693 how do i get a deeper tone do i put on a heavyer gage string ?
Heavier gauge strings will make it a little louder but bear in mind that this is an electro-acoustic guitar - you may prefer the sounds of an all-acoustic guitar designed to produce optimum sounds in an acoustic environment.
Aug 11, 2013 | Music
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
My Guitar's first 4 frets are producing strange sound , could it be because there is a bend ?
Usually the truss rod adjustment does NOT affect the first four, but ones near the middle. The nut height is the common cause of this. Best to take this to a guitar shop for setup.
May 23, 2011 | Yamaha F335 Acoustic Guitar
Where can i purchase a remote for the Acoustic Solutions DS733? is there a universal one that would work
the new name for acoustic solutions is clarity vision call 08712268935. i think its a uk number but i found a forum claiming this is the customer service number to order a new remote.
http://www.avforums.com/forums/remote-controls/735913-acoustic-solutions-ds533-remote-control-issues.html
g/l :)
Jan 29, 2011 | Audio Players & Recorders
Huming noise
kindly tight the pin socket.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Dec 24, 2010 | Boston Acoustics BA735 Computer Speakers
Cyber acoustic A3780 remote control schematic I receive the speakers in gift but the remote control is missing
replacement wired remote control pod that will work for the a3780 2.1 sound system
14.99 which includes US mail with visa or master card
Cyber Acoustics, LLC.
3109 NE 109th Ave
Vancouver, WA 98682
USA
(360) 823-4100
Mar 18, 2009 | Audio Players & Recorders
Gas Dryer isn't producing heat.
is the gas turned on??? the inlet valve is a double redundant syatem so it can't stay open.in emergency .replace if it wont open on demand..... check thermostat.. clean out all the lint in the cabinet so it can breath and won't catch fire.
Jun 12, 2008 | Whirlpool Dryers
Top Acoustic Solutions Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Acoustic Solutions Audio Player and Recorder Expert? Answer questions, earn points and help others
