Question about Briggs & Stratton Garden
I need to know the torque spec for the connecting rod bolts for a 28m707 briggs and stratton engine
mcdw
SOURCE: briggs and stratton engine #204412 type #0163e1
I found a parts list for model 204412 at http://www.buysmallengineparts.com/
Posted on Sep 07, 2008
  • 22 Answers
SOURCE: NEED TORQUE SPEC FOR CONNECTING ROD BOLTS ON GX390
the torque setting is 16nm,hope this helps
Posted on Mar 30, 2009
  • 68 Answers
SOURCE: the flywheel pin needs replacing on 3.5hp briggs and strat.engine
Take off the top sheet metal , there should be a nut & spring washer that will have to come off, they will be tight. Put the nut back on a few threads, use a prybar to put some upward pressure on the flywheel at the keyway side, while hitting down on the nut with a block of wood & large hammer. This should pop the flywheel loose from the taper shaft, replace drive key with ALUMINUM key!!
An impact wrench is sometimes necessary to get the nut loose.
Posted on Apr 26, 2009
  • 15 Answers
SOURCE: briggs and stratton lawnmower 4horse power engine needegap specs on coil and points
That's easy man! You will always hear, "You sir, need to gap this or that at EXACTLY .00071542 inches per square meter".
The actual "poor boy fix"-
Put your magneto back on there, and stick a business card from your wallet in between it and the rotor. Let the magneto pull itself to it, you center it, and give it just a hair of breathing room (to slide the card back out). Tighten 'er down, and you got it.
1.- If you can't pull the card out, it is too tight.
2.- If you pull the card out easily, too loose.
3.- JUST enough to pull it out, and have it drag just a bit on the way out is JUST ENOUGH!
Remember, on 4-strokes, they ARE forgiving, and can do miracles even if you try your best to destroy them.
Posted on May 30, 2009
SOURCE: need torque specs for a 85 s10 chevy with a 2.5 engine?
here you go!
Posted on Jun 21, 2009
Torque spec on 21 hp briggs and strattonand sequence
Doug, Torquing multiple bolts, like on a cylinder head are shown in last video link.Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
FAQ Small Engine Specifications Briggs Stratton Specs
Engine mounting pattern
HOW TO LOOK UP AND TORQUE BRIGGS HEAD
How to replace Briggs Stratton Intek Head Gasket Pt 2
Jun 01, 2016 | Cars & Trucks
What are the torque specs on intake manifold on Briggs & stratton
if there is thread locking compound on bolt or threads it must be removed, use a tap to clean the threads and a wire brush to clean the bolts. Use a thread locking compound (blue) when reassembling, torque the bolts to 30 ft. lbs. alternating bolt to bolt in 7-10 lb. increments. Recheck the torque after the engine has been ran up to op temp.
Jul 17, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Connecting rod torque specs
All the Briggs and Stratton specs are here....
www.briggsandstratton.com/us/en/support/manuals
Mar 10, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Torque specs. for a briggs @ stratton 24hp. head bolts
WHAT IS THE VALVE CLEARANCE ON A 23 HP. BRIGS MOTOR AND THE TORQUE ON THE HEAD BOLTS?
Jul 17, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Need timming specks & torgue speck for rod bolts
There are no timing "specs", if the flywheel key is good and the magneto air gap is properly set, the timing will be right.
Torque for the rod bolts is 45 INCH pounds - NOTE INCH pounds not foot pounds
Sep 23, 2009 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Head bolt torque for 16hp horizonal shaft engine
Anywhere from 35 lbs to 220 lbs, depending on the series of your engine. For your engine, the head bolt torque should be 190 lbs.
But I've attached a chart for you to utilize to make sure of your exact engine model series, just in case there was a transposed number, etc.
http://www.small-engines.com/torque.html
Here's the official Briggs & Stratton chart for all versions of their engines, which confirms the 190 lbs torque spec.
Hope you found this Very Helpful and best regards!
Aug 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
64 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
