Question about Motorola Mobility RAZR V3
Razr V3i charging problem
I may have ruined my charging port, but wanted to see if anyone out there had another explanation. I bought my unlocked V3i on Ebay 6 months ago and worked flawlessly until a couple weeks ago. I bought my wife a Razr V3 from T-mobile and she started using my phone as a charger. To stop this I bought a dual desktop (one that charges the battery without the phone and your phone at the same time) charger. The very first time i tried to use it to charge my phone without the simm installed, it wouldn't charge. I can still charge the battery with the new desktop charger (that came from Hong Kong) but not with a car or wall charger. When you plug it in it said 'insert simm' and turned the phone on. I had an idea and unplugged the desktop charger and plugged my original wall charger into the phone. It turns on and says charging battery, but the battery icon flashes instead of the bars inside the icon and doesn't charge the battery. Any suggestions before I ship it to Motorola repair center? Thanks for any help. And yes I have learned my lesson about using non Motorola equipment.
  • Anonymous Nov 23, 2007
    hey whenever i try to charge my motorola v3i phone..it displays the following"insert sim" the same appears when i attach the earphones to the phone. I have tried fiddling with the sim card.
  • Anonymous Mar 18, 2014
    version 4.04 bought new charger then found the battery pin insert was missing is there another way to charge the battery
    Novelist:
    Scholar:
  • 111 Answers
Hi V3 is very fragile and if you use the incompatible accessories, you can ruin their ports easily. One weak point of V3 Phone is the SIM card Port is not an opening flap like other GSM phone but using pin and spring Port style which is mean you have to push your SIM card in and use the SIM Card edge to push the pin down in order to contact with SIM metal area interface. But by pushing force is varied from users so too strong and too hurry will damage the pin. If one of the pins is damaged, when you slide the SIM card in, the contact is missing of one or two pins due to damaging of the pin cause the error message "Insert SIM". In this case, only way is needed to replace the SIM Board underneath. If you can do it yourself, please follow the instruction pictures below. If you are not sure and never do this before, I suggest you send the unit to Motorola Repair Center. Your SIM Card Board and charging port will need to be replaced. http://www.itsjustmerob.com/files/V3_Razr-repair.pdf This is a Full Motorola V3 Officially Service Manual and even the Motorola Repair Center also has this one. so copy this link and print it out. Around hundreds plus pages but can be your Guide which you cannot find anywhere else. I gave it to you free but I have purchased it before. Hope that you can get it fix. Other solution is looking V3 parts on sale a lot on Ebay and use them to replace part to your phone will be cheaper if your phone is no longer under warranty. If it is still under cover then send the unit to them and don't spend time and money to do it yourself. But if it is out of warranty and want to avoid costly repair then use the method in the manual I provided you and you will be able to get your phone fix. Good Luck
Posted on May 15, 2007
SOURCE:
MOTOROLA V3I
The charge port on the phone has probably become damaged from normal use. Visually inspect it to see if it is. If it is not, the pins that connect to the circuit board on the inside can break off of the board. They can be soldered back on but it does take some practice since they are very small. These ports can normally be bought on ebay for a couple dollars.
Mar 05, 2014 | Motorola Mobility RAZR V3i Cellular Phone
Free unlock code for razr v3I
Free Unlock code is not possible to get for the Model? You need to pay for it...You can get the unlock code for Motorola Razr V3I at reasonable cost at Simpleunlocking.com/motorola-razr-v3i/rs16wp9/ and Unlock it easily.
Jul 20, 2012 | Motorola Mobility RAZR V3i Cellular Phone
Phonebook asks for unlock code Razr v3i
You can get Unlock code for Motorola Razr V3I model Mobile Phone from Simpleunlocking.com/supported-phones/rs16wp7/ and get Free Unlocking instructions at Mobileunlockguide.com/motorola-razr-v3i and Unlock it easily.
Jul 15, 2012 | Motorola Mobility RAZR V3
Help me to unlock my mobile moto RAZR V3i .
lot of unlock source avail across the globe,before get free unlock guidance here http://www.mobileunlockguide.com/
Dec 31, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Invalid battery
Pull out the battery *while the phone is on*. Wait 15 secs then put battery back in and turn phone on. That should fix it.
Nov 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
How to install theme in motorola RAZR V3i
hey!!!!! istead of installin themes its a better option to install skins!!!! you can find skins for the v3i in most of the websites!!! To install these skins you need a software called skiman which can be downloaded from motomodders .net.... also remember to download the p2k drivers b4 installin them!!!!
Feb 20, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Installing java applications and games in razr v3i
download your .jar files to ur pc....
then copy and paste them in the kjava folder on your mobile.....
then go to games & apps and click menu and select switch storage device...
when you switch ovr to memory card ul find "Install New" click on that and u shud have no othr problem....
was it helpful????
let me know
Dec 31, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Anti Virus for V3i
I need the anti virus software for Moto V3i
Nov 02, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola RAZR won't charge
that happens mostly with third party chargers..you may want to explore the option of charging your phone using the PC and a USB cable...you may be required to download a software or driver for it ..along with eh motorola phone tool
Apr 30, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
457 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
