Question about Frigidaire FTF2140E 3.5 Cu. Ft. Front Loading Washer
Stopped spinning during the rinse cycle
My Frigidaire washer (front loader) FTF2140ES1 stopped spinning during the rinse cycle. It has this humming sound, like it's trying to spin, but can't. I shake the door a little, because someone mentioned, the door latch, might be a be a problem. It spins a little super slow and then stops. Does that mean it's the door latch and if so how hard or easy is it to replace (I'm a woman), so not too terribly "handy", but can usually get by.
  • 91 Answers
Possible door latch problem also can be pump
Posted on Jan 03, 2009
My frigidaire LTF6700FSO will not spin
Your symptom sounds like a jammed drain pump. Was it spinning and then stopped before the spin cycle should have ended or did it not begin spinning when it should have?
Jan 17, 2013 | Frigidaire ATF6000ES Front Load Washer
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire front loader washer makes a very loud knocking sound during the spin cycle before the final rinse. It intensifies the longer I allow it to spin. I have to shut it off before the cycle is...
from your description, it sounds like your washer is already broken - to check, open the door and reach your hand into the tub at the front top. push up. if the tub moves more than a fraction of an inch, the bearing and/or spider are toast. last time i checked, the PARTS were in the neighborhood of $450 and it's a BIG job! [read that: big labor bill]. this is a common problem with these machines and it's probably time to get a new washer. sorry!
Aug 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Water not draining during rinse cycle
check the drive belt for the pump under the machine
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Sep 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire FTF2140E 3.5 Cu. Ft. Front Loading Washer Logo
491 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
