Question about ASUS M2V Motherboard
M2v usb 3.0 pci-e card not detected
USB 3.0 pci-e card into 1x pci-e slot not detected at all (inLine card w/ NEC usb 3.0 controller uPD720200)
  • 1 more comment
  • Jose Diaz
    Jose Diaz Oct 27, 2012
    BIOS?
  • marcemiri Oct 29, 2012
    Thank you all, but it seems like this mobo would have issues w/ usb3.0 cards coming on pci-e x1 slot. BIOS does not allow to make any change to pci-e x1 slot and drivers for the card have been installed properly. The fact is that windows (or mobo at this point I would assume is the same) not even senses the card installed. When I put the card into the slot It seems to be powered (a green ked goes on)
    sorry, I kept the message hung!!! I was saying, the card seems to be on (as a green led lits) but windows does not detect it...
  • ASUS Master
  • 3,606 Answers
Hello the home page is here:
http://www.asus.com/Motherboards/AMD_AM2/M2V/#specifications
Your mainboard does not support pci-e cards in the white socket.
They are TOTALLY INCOMPATIBLE with each other.
The PCI Express x1 is for a graphic card.
Usb 3,0 cards does exsist as pcix and this is what you are looking for.
If you want to know what pcix is:
http://en.wikipedia.org/wiki/PCI-X
Hope this will help you
Posted on Nov 29, 2012
4 Suggested Answers
pgmadhav
  • 145 Answers
SOURCE: PCI Slot not detect any device
Please post questions in detail to help us to serve you better. The answer which I'll be providing you is based on assumption on the little data you have provided. I think you haven't loaded the driver for the said card and hence, your PC is unable to detect the card. The drivers are usually supplied with the card on a disc,Just run the disc and if should solve your problem.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Posted on Jan 26, 2009
  • 1011 Answers
SOURCE: Please can you give steps to disable the onboard
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Posted on Feb 04, 2010
  • 106 Answers
SOURCE: 1. WHAT COLOR ARE THE ELECTRICAL POWER CONNECTORS
1. this is the manual for the board: http://support.asus.com/download.aspx?SLanguage=en&m=M2N-MX&p=1&s=24&os=22&hashedid=0pKBwEIE8tqMT4j7
it should be able to answer your questions.
Posted on May 21, 2011
Is the hp a1330n usb 3.0 compatible? Mine doesn't even have the "pci-e" mini slots for plugging in a usb 3.0 card. Is my only option is replacing the motherboard with one that has pci-e slots?
- You can use PCIe x16 slot (if using onboard graphics adapter) and PCIe/USB 3.0 card (data transfer rates up to 5 Gbit/s, i.e. 10x faster than USB 2.0).
- Or use PCI/USB 3.0 card (for legacy PCI slots to support the USB 3.0 standard), which allows data transfer rates up to 1.3 Gbit/s (3x faster than USB 2.0).
2 Port PCI SuperSpeed USB 3 0 Card Adapter
May 31, 2015 | HP Computers & Internet
INSTALL PCI EXPRESS USB CARD IN DESKTOP COMPUTER
just plug the card and insert the cd and install it...
May 30, 2008 | Televison & Video
Fitting a Gforce video card in a veriton 5700GX
Your restrictions are based on available slot size and version. So get one that fits PCI-e x16.
Could not locate PCI version so check your manual, because the slots are backward compatible. Meaning you can connect a Ver 1 card into a Ver 3 slot, but not the other way around.
Expansion Slots - 1x PCI-e x16 slot, 1x PCI-e x1, 2 x PCI slots
Dec 11, 2012 | Computers & Internet
Can you tell me where the sodimm slots are located on a Advent 6551 laptop
Advent 6551 Laptop Specification CPU Intel Celeron Dual Core T1600 (1.66GHz) BIOS Phoenix BIOS. Press F2 to enter Chipset Intel GL40 Express Memory 1GB DDR2 PC2-6400 800MHz SODIMM (2 memory slots. Max 4GB) Hard Drive 160GB CD Drive DVD±RW Screen 17" Widescreen TFT (native resolution 1440x900) Video Card Integrated Intel GL40 Express Chipset Family Webcam Built in Sound Card Realtek ALC888 High Definition Audio Network Card Realtek 8139 / 810X (Onboard)
MSI MN54G 802.11bg Wireless G Mini PCI Card (MS-6877) Ports 1x Headphone
1x Line-in
1x Microphone
1x Expresscard slot
1x Card Reader
2x USB 2.0
1x Kensington Lock
1x LAN
1x eSATA *
1x DVI Battery U40-3S3700-B1Y1 (11.1v 3700mAh) Size 27.8 x 287 x 402mm (HxWxD) Weight 3.4kg Colour Black Made By F71IL1 * The eSATA port also doubles up as a 3rd USB port.
Drivers
Your laptop should have been supplied with a Utility CD which contains a copy of the user manual and all the drivers. There is also a copy of the drivers on the laptop itself, you can find it by browsing to the c:\applications\drivers folder. Finally you can download some of them from The Tech Guys website.
The Wireless LAN card uses a Ralink RT72 chipset so if you're struggling to find drivers then the "USB(RT257x/RT2671)" ones on the Ralink site should work - http://www.ralinktech.com/support.php.
Memory Upgrades This laptop has two memory slots. One slot is accessed by removing the cover underneath the laptop (see the "Bottom of Laptop" section below)
Jan 20, 2011 | Computers & Internet
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Motherboard diagram
A Computer Motherboard Diagram motherboard-diagram-01.jpg Once you know what you are looking at, you can recognize the components on any motherboard layout. A computer motherboard diagram is very useful for when you need to replace motherboard, do motherboard upgrades, troubleshoot motherboard, or build your own computer.
  1. PCI Slot - This board has 2 PCI slots. These can be used for components such as Ethernet cards, sound cards, and modems.
  2. PCI-E 16x Slot - There are 2 of them on this motherboard diagram, both are blue. These are used for your graphics card. With two of them onboard, you can run 2 graphics cards in SLI. You would only need this if you are a gamer, or working with high end video / graphics editing. These are the 16x speed versions, which are currently the fastest.
  3. PCI-E 1x Slot - Single slot - In the PCIe 1.x generation, each lane (1x) carries 250 MB/s compared to 133 MB/s for the PCI slots. These can be used for expansion cards such as Sound Cards, or Ethernet Cards.
  4. Northbridge - This is the Northbridge for this motherboard. This allows communication between the CPU and the system memory and PCI-E slots.
  5. ATX 12V 2X and 4 Pin Power Connection Power Connection - This is one of two power connections that supply power to the motherboard. This connection will come from your Power Supply.
  6. CPU-Fan Connection - This is where your CPU fan will connect. Using this connection over one from your power supply will allow the motherboard to control the speed of your fan, based on the CPU temperature.
  7. Socket - This is where your CPU will plug in. The orange bracket that is surrounding it is used for high end heat sinks. It helps to support the weight of the heat sink.
  8. Memory Slots - These are the slots for your RAM. Most boards will have 4 slots, but some will only have 2. The color coding you see on the motherboard diagram is used to match up RAM for Dual-Channel. Using them this way will give your memory a speed boost.
  9. ATX Power Connector - This is the second of two power connections. This is the main power connection for the motherboard, and comes from the Power Supply.
  10. IDE Connection - The IDE (Integrated Drive Electronics) is the connection for your hard drive or CD / DVD drive. Most drives today come with SATA connections, so you may not use this.
  11. Southbridge - This is the controller for components such as the PCI slots, onboard audio, and USB connections.
  12. SATA Connections - These are 4 of the 6 SATA connections on the motherboard. These will be used for hard drives, and CD / DVD drives.
  13. Front Panel Connections - this is where you will hook in the connections from your case. These are mostly the different lights on your case, such as power on, hard drive activity etc.
  14. FDD Connection - The FDD is the Floppy Disk controller. If you have a floppy disk drive in your computer, this is where you will hook it up.
  15. External USB Connections - This is where you will plug in external USB connections for your case or USB bracket.
  16. CMOS battery - This is the motherboard's battery. This is used to allow the CMOS to keep its settings.
May 31, 2010 | E-Machines T2542 PC Desktop
My motherboard has fried: Albatron KM18G Pro 2003. It no longer seems to be available. For the computer to be exactly as it was before disaster struck, do I need exactly the same motherboard?
Well you do not need exactly the same motherboard. You need a motherboard that has the exact CPU socket, DDR slots and AGP or PCI slot.
Here are the specifications for the motherboard: Processor
- AMD Athlon/Athlon XP/AthlonXP Barton/Duron Processor
- FSB 200/266/333MHz
Chipset
- North Bridge: NVIDIA nForce2 IGP
- South Bridge: NVIDIA nForce2 MCP
- I / O Chip : Winbond W83627HF
Memory
- 3 DDR Sockets:
DDR200 to 400 non-ECC DDR SDRAM up to 3GB (Single Channel) or up to 2GB (Dual Channel)
Expansion Slots
- 1 x AGP 8X/4X slot (1.5V Only)
- 3 x PCI slots (PCI 2.2 compliant)
IDE Connectors 2 ATA133 channels (up to 4 ATA 133 IDE Devices)
Onboard I/O Connectors
- 1x Floppy Connector
- 2x USB 2.0/1.1 header (4 ports USB cable optional)
- 1x CD_IN header
- 1x COM Port header
- 1x S/PDIF in/out header (S/PDIF in/out cable optional)
- 1x CPU fan header with fan rotation detection function
- 1x System fan headers with fan rotation detection function
- 2x 5 pin system panel header (Intel spec)
- 1x 3 pin Power LED header
- 1x 4 pin Speaker header
- 1x Front audio header (Intel spec)
- 1x Case Open detection header
- 1x Wake on LAN
- 1x 4 pin TV-Out header
So you have to buy a motherboard that has Socket A, that support DDR I memories and has an AGP slot (for the video card).
If you need further assistance, just leave a comment. Thank you for using FixYa.
Apr 19, 2010 | Albatron nForce2 KM18G Pro (KM18G PRO 2.0)...
Addinga card reader to an ASUS M2V m/board
Install a PCI usb card to give you the USB connectors.
Feb 16, 2009 | ASUS M2V Motherboard
I HAVE MY PROBLEM REGARDING MY MOTHERBOARD, AMD ATHLON EP-8KTA3L
Specification DFI AK74-SC Model DFI AK74-SC Socket Socket A Motherboard CPU AMD Athlon /Duron processor 600MHz-1.2GHz and faster Chipset VIA KT133/686A Memory 3 DIMM sockets
max. 1.5GB (unbuffered or registered)
Supports PC 133/ VCM SDRAM BIOS Award / 2Mbit Power Management ACPI and OS direct power management
Wake-on event: RTC/Modem/LAN Hardware Monitor System and processor temperature Expansion Slots 1 AGP slot (Supports 4x/2x AGP)
4 PCI slots
1 AMR slot
1 ISA/PCI slot Audio AC`97 Audio codec with Yamaha AP Super I/O 2 x NS16C550A compatible UARTs
1 x SPP/ECP/EPP parallel port IDE Dual PIO mode 3/4 EIDE channels up to 4 IDE devices
Ultra DMA/66 transfer rate up to 66MB/sec Rear Panel I/O Ports 2 x USB, 2 x DB-9, 1x DB-25, 1x PS/2 Mouse,
1 x PS/2 Keyboard, 1 x game/MIDI, 3 audio jacks I/O Connectors 1 x IrDA, 2 x external USB, 2 x IDE, 1x Floppy,
1 x ATX power, 3 x fan, 1 x WOR, 1 x WOL, 3 x internal audio Form Factor 4 layers ATX Motherboard Form Factor
30.5 cm x 22 cm 12.0 inch. x 8.66 inch. Warranty DFI AK74-SC Motherboard Pro DOA Warranty ONLY
DOA DFI Warranty
DFI Warranty
motherboard
If you want more Information then go to this link :-
http://www.motherboardpro.com/Motherboard-With-ISA-Slot-DFI-AK74-SC-1-ISA-4-PCI-AGP-Socket-A-ATX-Used-Motherboard-p-39.html
Dec 03, 2008 | DFI AK74-SC Motherboard
Foxconn Utility CD for motherboard Intel 915 series p/n: 91-185-915-MB-OM W A N T E D
Hi Witalorant,
I have searched the driver for your motherboard chipset and found one similar for the one you were looking at, i copy and paste the link here for you to download it and install it to your unit.
Click the link below and see what driver you need to download when the page loaded..
INTEL 915
Hope it helps.
Enjoy
Pls. rate & hope to hear more from you soon..
tnx
-micro
Feb 10, 2008 | Foxconn 915P7AC-8KS Motherboard
ASUS M2V Motherboard Logo
681 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
