Question about Insignia Kix MP3 Player
How to disconnect mp3 from computer
I do not see the Icon on lower right screen of monitor to safely disconnect Mp3. How can I disconnect correctly?
  • Anonymous May 02, 2009
    i dont know how to disconnect my mp3 from my computer saely
    Problem Solver:
  • 7 Answers
From a command window run:
C:\WINDOWS\system32\rundll32.exe shell32.dll,Control_RunDLL hotplug.dll
Also, you can try this if it goes away again:
Right click on the taskbar, select properties
click Customize
click on "Safley Remove Hardware", and set to "Always Show"
Posted on Jan 03, 2009
I dont knw how to upload music onto my RCA opal mp3 player
There's a manual for the M4001 in pdf format, it's under this link:
http://www.voxxsupport.com/images/manuals/M4001/media/M4001_UMEN.pdf
Making music transfers:
> Explore 'My Computer' and use the copy and paste or drag and drop method for music transfers: seeing the player as a removable disk.
note
Before you disconnect, when exploring the player, always go through the safely remove hardware icon in the right corner below of your computer screen. Left click the icon and left click again on the drive letter of your player: after the message the device is disconnected, it is safe to take out the USB cable. ( look in the manual for more info )
> Use Windows Media Player 10 or higher:
Right click in the upper bar of WMP10 or higher and see the Help function for how to transfer music.
Jul 18, 2010 | RCA OPAL M4001 MP3 Player
Not sure if player is charging
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps.
Apr 07, 2010 | Coby MP-610 MP3 Player
The player comes on when connecting USB but has no power when disconnected and it is new
Hello Chris,
The battery could be drained and needed to be plugged into usb to charge. In here, the computer is the one supplying power to the MP3 player so it turns on. Try charging it further like one hour before you take it off. Also, please remember that all USB devices, especially mp3 players should be "safely removed" to avoid it being fried. To safely remove, click on the green usb icon on your lower right corner of your computer and click "safely remove device..". Wait until it tell you that it is now safe to remove your usb device.
Now if it still wont work, the player might be defective and since it is still new, please dont hesitate to return back and ask for replacement as this player might give you other problems later on. Since it is under warranty it would save you further cost.
Oct 27, 2009 | Curtis MPK2066 MP3 Player
80GB frozen with "Do not disconnect" displayed on screen.
you have to send to apple eng. or els call me i can help u sir 9177110844
Sep 15, 2009 | Apple iPod MA446LL/A MP3 Player
Safely disconnecting Sansa C250 from Laptop with Vista
Right click the taskbar and select Properties. Then select Customize - look in past items and see if you find the safely remove hardware option.
-Tha Mp3 Doctor
Dec 30, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
I have no idea how it happened, but i plugged it into my computer to charge. and then i just saw my mp3 player and the screen froze and it says usb connecting and when i plugged it out it still said usb...
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Nov 28, 2008 | Samsung YP-U3 MP3 Player
MP3 not being recognized by computer
My opinion.
No one here seems to understand the question...unless it's just me.
Not being recognized by computer means you should not be able to disconnect the device safely. Am I right?
I cannot seem to disconnect the device safely, which means that the refresh database option will not display and do so!
Help?
Nov 06, 2007 | SanDisk Sansa e260 MP3 Player
Disconnecting from the computer
anything that comnnects via usb as a portable device will be in the taskbar somehere normally a little grey icon with a green arrow above it, right click it and select the remove hardware device you need to remove.
Sep 07, 2007 | SanDisk Sansa E280 MP3 Player
Can't upload mp3's onto camera
To transfer MP3 files to Digimax i6:
- Turn off camera
- Plug USB cable to PC and camera
- Turn on camera
- On your COMPUTER screen, it will tell you select USB: Printer or Computer
- Select Computer using the arrow buttons
- Press MENU/OK
- On your COMPUTER screen, a window will pop out like
Removable Disk and it will be telling you a lot of options
- Select "Open to View Files"
- You should be seeing the DCIM folder as you select that option
- Right click on the white space where DCIM is located
- Select "New" and then "Folder"
- Rename the folder as MP3
- Open your documents containing the MP3 files that you want to transfer
to your camera
- Make sure that the format is MP3
- Select the files that you would like to transfer
- Right click on one of those and select copy
- Now, go to the MP3 folder that you've just created
- Open the MP3 folder
- Right click on the white space of the MP3 folder
- Select PASTE
- All MP3 files will be copied to your camera
Note: It depends on the file size of your MP3 if it could still
be accomodated inside your memory card
To safely unplug your camera:
- Look for the green arrow icon on the lower right corner
of your computer
- Right click on that and select "Safely Remove Hardware"
- Just select your memory card in there that is pertaining
to your camera and select stop
- Once, you've seen the message "You could now safely remove the camera",
then you could now turn off your camera and unplug it so as to prevent any problems
On your camera:
- Turn it on
- Press the M button
- Scroll to the right until you see MODE menu tab
- Use the down button to select Still/Movie/PMP
- Press MENU button (all will disappear)
Now,
- Select Resume
- Make sure to be on MP3 mode
- Select the desired files and those will play
If it still does not work, call the Manufacturer.
Jun 23, 2007 | Samsung Digimax i6 PMP Digital Camera
Open Questions:
Insignia Kix MP3 Player Logo
983 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
