Question about Roper RAX7244KQ Top Load Washer
How do I replace a belt in a Roper RAX7244KQ Top Load Washer?
Is there more than one belt? Is it difficult to change? I'm a total novice.
  • 22 Answers
SOURCE: roper washer top loader spins very slow
if the appliance has a induction type motor could be that the running capacitor is failing coul be the motor itself
Posted on Nov 13, 2008
  • 686 Answers
SOURCE: Washer will not pump water out
go to this site and look at this part it 's like a lint catcher and if it is filled with junk it will prevent from pumping out. clean it out and see if that fixed ya. www.repairclinic.com/SSPartDetail.aspx?s=t-RAS8445KQ-%3d%3di541811&PartID=541811 After looking at this you can back click and see more parts to your washer. Good Luck.
Posted on Apr 03, 2009
ginko
  • 19396 Answers
SOURCE: I have a top load Roper washer that won't spin.Any ideas?
That sounds like a bad drum bearing, check and eventually replace the drum bearing.
Posted on Apr 27, 2009
  • 24 Answers
SOURCE: my washer spins but will not drain. the pump seems to be working but wont drain
The drain line is probably clogged... sometimes debris or small objects can get in between the tubs and plug the lines...if not, the pump may be bad. I just replaced my pump on my GE washing machine.
Posted on May 19, 2009
  • 30 Answers
SOURCE: how do I find the lint filter on my roper top load
Washers normally don't have a lint trap. dryers normally have them and they are normally in bottom by where the door opens or ontop of the dryer.
Posted on Jan 02, 2010
Timer repair on roper washing machine
How do you know you have a timer problem could be your lid switch?
May 06, 2014 | Roper RAX7244KQ Top Load Washer
RAS7233KQO washer wont spin and makes a grinding. noise
Hi, without knowing exactly what the sound sounds like its hard to tell.If the drum trys to spin this could be the sound of a slipping clutch. If it doesnt it could be the transmission doesnt go into gear. If the sound is more dull the motor coupling. The coupling is the cheapest fix, then clutch, then trans. If your handy there not too difficult to change.
Sep 27, 2011 | Roper RAX7244KQ Top Load Washer
Washer won't empty or spin
More than likely its your lid switch or your pump is clogged.
Sep 25, 2011 | Roper RAX7244KQ Top Load Washer
Water won't come out of the machine. It worked the night before last...I did not change any settings or touch anything. What can I check?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Roper RAX7244KQ Top Load Washer
WATER NOT DRAINING FROM WASHER.
This video while not exact for your model will still help.
http://appliancejunk.com/forums/index.php?topic=5191.0
Apr 18, 2010 | Roper RAX7244KQ Top Load Washer
Waher
ckd pump lean washer back against wall pump next to front ..2 clips hold pump to motor 2 clamps on hoses pump slides off motor ..also ckd hose from pump to drain underneath
Sep 10, 2008 | Roper RAX7244KQ Top Load Washer
Roper washer not draining
okay you say coupler was broken, make sure coupler is on properly, and make sure your pump is clear of debri, sounds like you washed something heavy, make sure your pump is also clear
Apr 03, 2008 | Roper RAX7244KQ Top Load Washer
Roper RAX7244KQ Top Load Washer Logo
55 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
