Question about Bosch sensixx TDA 8333 Iron
I have an bosch sensixx b25l iron and the calc clean light is on what can i do
4 Suggested Answers
SOURCE: i have an bosch sensixx b5 iron and the calc clean
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean The "calc'n clean" function helps to remove scale particles from the steam dispenser. The iron includes a system to warn when the dispenser needs periodically cleaning. When the "calc 'n clean" symbol lights up on the navigation display the dispenser needs cleaning. Fill the water tank. Plug in the iron and select the temperature setting . After the necessary warm-up period, unplug the iron and hold it over a sink. Position the steam regulator to the "calc'n clean" position and keep it in this position. Gently shake the iron. Boiling water and steam will come out, removing any scale or deposits that might be there. When the iron stops dripping, position the regulator to the position. For improved descaling, heat up the iron again fully and press the steam button several times in quick succession. Then wait until the remaining water has evaporated from the soleplate of the iron. Once it has been cleaned, the cleaning warning must be cancelled on the navigation display. To do this, simply press and hold the on/set navigation key for more than 5 seconds, with the iron plugged in. If you do not do this, the cleaning icon will remain lit. 3. anti-calc The "anti-calc" cartridge has been designed to reduce the build-up of scale produced during steam ironing, helping to extend the useful life of your iron. Nevertheless the "anti-calc" cartridge cannot remove all of the scale that is produced naturally over time.
Posted on Feb 13, 2011
SOURCE: bosh sensixx B25L iron spraying brown water
I have a bosch sensixx b25l and it has started spraying brown water all over the clothes how do I descale it please
Posted on Apr 20, 2011
  • 7 Answers
SOURCE: Bosch sensixx B25L no steam
Are you sure that you have the correct settings chosen? It sounds like you have a faulty unit!
Posted on Sep 26, 2012
Hi Ihave a Bosch B25L steam generator iron and it has stopped steaming completely. Any ideas?
Yousaf/Tony, Either the switch is defective or the heat element has gone bad, probably not cost effective to repair.
May 25, 2014 | Bosch sensixx TDA 8333 Iron
Sep 26, 2012 | Bosch sensixx TDA 8333 Iron
Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
Jul 31, 2012 | Bosch Irons
HI I have a Bosch Sensixx B25L iron. Steam isn't coming out of holes, seems to be escaping from edge of iron. Handle very hot (Too hot to hold on to), burns your hand when steam button is pressed
I just fixed mine - it had exactly the same problem.
First, though, check it's not within the Bosch TWO year guarantee; if it is, they'll either fix or replace it.
If it's not under guarantee then the problem is probably the rubber tubing that connects the external steam tube to the hotplate. You'll need to dismantle the iron. Mine had split right next to the spring clip that holds it on. I shortened it, clipped it back on and all is now well.
Jul 28, 2012 | Bosch sensixx TDA 8333 Iron
Bosch sensixx b25l manual
Though tpmy iron is heating up it won't take the water in and so doesn't steam It has been cleaned and no scale is in the bottom. It worked fine yesterday.
Jan 11, 2012 | Irons
How do you clean a Bosch B25L (TDS2510GB) using the calc'n clean facility?
THE LINK DOESNT SEEM TO WORK SO HERE IS THE INSTRUCTIONS FROM THE MANUAL.
Calc'n clean
Cleaning the Boiler
To extend the life of your steam generator and to avoid any build
up of scale, it is essential that you rinse out the boiler after several
hours of use. If your water is hard, increase the frequency.
Do not use descaling agents for rinsing out the boiler, as they could
damage it.
1. Check that the appliance is cold and unplugged for more than 2
hours, and that the removable water tank (1) has been removed
from the steam generator.
2. Place your appliance on the edge of your kitchen sink.
3. Unscrew the boiler drainage plug (15) located on the bottom of the
appliance using a coin.
4. Holding your steam generator in an upside down position, and using
a jug, fill the boiler (in the base unit) with 1/4 litre of water
5. Shake the base unit for a few moments and then empty it completely
over a sink or bucket. To obtain the best result, we recommend
that this operation is done twice
6. Important: before reclosing, make sure no water remains in the
boiler.
7. Replace and tighten up the boiler drainage plug with a coin
Dec 27, 2010 | Bosch Irons
Bosh sensixx B25L iron spraying brown water
Feb 22, 2010 | Bosch Irons
Bosch sensixx 2400w
The cleaning process is to fill up, heat to max, then hold steam lever across to "calc and clean" position whilst shaking gently over a sink.
Manual is available to download from Bosch.co.uk.
Aug 27, 2008 | Bosch TDA8340 Iron
Bosch sensixx TDA 8333 Iron Logo
13 people viewed this question
Top Bosch Irons Experts
Colin Stickland
Colin Stickland
matt
matt
cwradio73
Are you a Bosch Iron Expert? Answer questions, earn points and help others
