Question about AllAboutApps AppBox Pro
Appbox pro won't open. when i try to, it just says
After i edited the p-calendar, i tried opening the other apps on it like currency. had to send sms so i quit app box pro. when i tried to open it again, it just said"loading" for a loooooong time. and it won't open anymore. I deleted it and re-installed it. it works at first then when i quit and open it again... the "loading for a loooong time" happens again. :-( i've deleted and re-installed about 5 times already. help!
How do i erase text messages i have received
It depends on the app, but do try to long tap and check what comes out. Maybe there is an option to delete. But if not, download an SMS app that allows you to delete conversations. Set that new app as your default SMS app and all of the SMS text will be transfer to the new SMS app.
May 16, 2017 | Cell Phones
How do i add gmail calender in iphone
If you are iPhone users with iOS 7 or later installed, you can follow the steps below to sync Gmail calendars to iPhone.
1. Tap Settings > Mails, Contacts, Calendars > Add Account, and add Gmail into your iPhone.
2. Then tap Calendars to ON. Go back to Home screen, and launch Calendars App, then the Gmail calendars will be synced to your iPhone.
add-gmail-calender-in-iphone-oxaxc0rwhkhzilrwacqreyis-1-0.png http://www.leawo.org/tutorial/how-to-sync-gmail-contacts-to-iphone.html
Aug 24, 2016 | Google Computers & Internet
Why I can't send or receive photos with sms?
I have to go to Gallery, go to the photo I want to send, select Share, then select the Messaging app. On my Messaging app there isn't a way from selecting a photo.
For receiving photos, see if they are automatically put in your folder, like contact info is put directly in your contacts list without even opening the message - and if you did open it, it would show a blank message.
May 30, 2016 | Samsung Galaxy Cell Phones
Cant get alert sounds for new text mess how do I remove hangout
Hangout is a native app from Android, it can not be remove, this is if you are using the latest Android OS.
But there is a way around, I guess you want to use another messaging app as your default sms. The first thing that you can do is to disable Hangout. You can achieve this by going to setting, apps, search for Hangout and tap it, now tap disable.
Now, I'm not sure how to enable default for a third party app, in this case a messaging app, but you can always open the new app and maybe it could prompt you to set it as default. For the sound or ringtone, there are 2 ways to do it.
1. Open the messaging app and tap the menu, from here you can set the ringtone for your sms.
2. Download and install Zedge from the PlayStore, download the ringtones that you like the most, after downloading them, the one that you want to set it as your sms ringtone, just tap set at the bottom, and choose messages or sms.
Jul 19, 2015 | Cell Phones
Bring up my month calendar that' on my galaxy s3 on the computer so i can copy the information
Hi is it the S planner app you talk about?
I found that S Planner uses several calendars. You can have one in the samsungaccount. Open Splanner app. In menu press MENU button (left bottom), select calendars. Now you have a whole list. facebook, gmail, samsung. I started initially using (and adding things) to my samsung calendar. But I soon found that the samsung was difficult to use. So I changed to using the gamil calendar and reentered birthdays etc. Now with the gmail calendar it is synced at all times and you can access and edit your calendar in PC when logging in to gmail, you select calendar. In to right corner you find a small grey with nine little blocks. This is apps. In here you go to calendar. Hope it helps. Stop using the Samsung account calendar! I guess if you want to access this on pc you must log into your samsung account on pc. I didnt because I switched to gmail calender. Best regards
Lisbeth
Mar 01, 2015 | Samsung Galaxy S Iii Gt-i9300 - 16gb -...
Stop Go SMS Pro from automatically updating
You should have the update for the previous version on your phone. Check with your provider for reversing that version's software.
Feb 09, 2015 | Samsung Cell Phones
How to use whats app
whats app is for texting only. you need to launch the app, input your mobile number and any other information the app asked you for. it will then say it has sent you an sms with a one time pin. once the sms has arrived close the app (press the home button), open the sms app and read the one time pin. remember it. open the whatsapp app and enter the one time pin from the sms. it will verify the sms and then ask you for more information like your display name etc. fill it in and click next until you are at a screen with a small square with a pencil in it, in the top right corner. press that button and then select a contact from your contact list which will be displayed. type your message in the now available text bar and press "send" which is next to the text bar, when ready. this is how you message with whatsapp. to exit the chat press the "chats" button in the top left.
not you can resume the chat at any time by selecting it in the chats window
Oct 15, 2014 | Apple Working Black Att Iphone I Phone 3gs...
How do I edit my calendar on the samsung galexy S II
To add an event:
1. Click on calendar app icon2. Click menu button (bottom left below screen)
3. Choose 'Create' (with the + sign)
4. Set time, description, notifications and other data for the event
5. click 'save' (bottom left of screen)
To edit an existing event:
1. Click on calendar app icon2. Go to relevant day, and click on relevant event3. Click menu button (bottom left below screen)
4. Choose 'Edit' (with the pencil icon) - note this option is only for events you have created.
5. Set time, description, notifications and other data for the event
6. click 'save' (bottom left of screen)
Jan 04, 2012 | Samsung Galaxy S II
Calendar app not working
You need to upgrade your software of phone. This is the only solution you can try. If you don't know how to do this better you try to do this by someone else / take our online help.
Feb 13, 2008 | Nokia 5500 Sport Cellular Phone
AllAboutApps AppBox Pro Logo
83 people viewed this question
Top AllAboutApps Apps Experts
Erin Wood
Erin Wood
Are you an AllAboutApps App Expert? Answer questions, earn points and help others
