Question about Singer Tiny Tailor TT700
Adjusting tension of bobbin case of singer tiny tailor model
barefoot1957
SOURCE: Missing part
I too have a Tiny Tailor with missing parts. I emailed Singer directly and this is the answer I got back from them...
I would be willing to GIVE you mine if you want it...
Unfortunately this item was discontinued several years ago, and replacement parts are no longer available. For this reason, this item is not repairable. We regret that we were not able to assist you with your request.
You may want to search on EBay, where a private individual might be selling this unit. You may be able to obtain parts this way.
Singer Consumer Affairs
Posted on Nov 04, 2008
bargainbox
  • 1388 Answers
SOURCE: Problem with tension on singer tiny tailor mending machine
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Aug 30, 2009
  • 139 Answers
SOURCE: need ownes mauel for singer tiny tailor mending
You can download a free manual at the Singer website:
http://www.singerco.com/accessories/manuals.html
Posted on Apr 07, 2010
  • 139 Answers
SOURCE: bobbin tension is too loose
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Posted on Apr 16, 2010
SOURCE: The bobbin tension too tight on my Singer Quantum 9240.
I am having this problem also; the thread catches in the **** in the bobbin. I am thinking maybe I am not threading the machine correctly--the bobbin area, not the top thread. I will try this & see if it fixes the problem. You may be doing the same as I am.
Posted on Nov 12, 2010
How do Iinstall the Bobbin holder in na Singer tiny taylor machine?
I"m assuming that you are asking how to reinsert the bobbin case, rather than the bobbin itself. If you don't have your user's manual, you can download it free at the Singer website. When you do, look on page 19; it has exact directions and an illustration there regarding how to reinsert the bobbin case.
Oct 06, 2014 | Singer Tiny Tailor TT700
Adjust tension
:) I found this blog about a Tiny Tailor you may find helpful.
http://handmadedetroit.com/2008/06/22/vintage-crafty-the-singer-tiny-tailor-1982/
Sep 10, 2012 | Singer Tiny Tailor TT700
I picked up a singer tiny tailor and it does not have a bobbin case. How can I get one and where?
I will advice you order it online, it will be delivered to you within a very short time, you can order for it at either ebay.com or ereplacementparts.com
Mar 10, 2011 | Singer Tiny Tailor TT700
The needle will not go up and down on my TT700 Tiny tailor sewing machine
the bobbin case came out and cant get it back in
the needle wont go up or down it doesnt catch the thread also its brand new and it came out of the box with the bobbin case out of it
Dec 15, 2010 | Singer Tiny Tailor TT700
My bottom stitch is "loose"
You might try adjusting your bobbin. You can do this with a tiny flat head screwdriver. Adjust in very small increments! There is a screw located on your bobbin case.
Here is the info directly from the manual:
"To test if the bobbin thread tension is correct, suspend the bobbin case by the thread and **** it once. Correct bobbin tension will result in the thread unwinding by only one or two inches. If too loose it will unwind continuously. If too tight, the thread will not unwind at all. When adjusting the tension on the bobbin case, make only slight adjustments with a screwdriver."
That is usually the cause of garbled up threads on the bottom side. Sure hope this helps!
(The 132Q is my third Singer, but will be my last. It's been a nightmare to deal with, and ALWAYS has something going wrong with it. I can never just sit down and do a project.... it is like the settings never stay put. There is also a LOT of plastic inside this model, and it cracks, breaks, warps, etc. We've replaced plastic gears/parts with metal parts, and it still acts up. Just a lemon model!)
Nov 05, 2010 | Singer Featherweight 132Q Mechanical...
I have a Singer Magic Tailor with no
Try www.singerco.com for a new manual. They should have it.
hardrocko
Feb 01, 2010 | Singer Tiny Tailor TT700
I've lost the manual to the Singer Tiny Tailor mending machine M100A and need to know how to refill the bobbins. Can you help me? Thanks
Jan 18, 2010 | Singer Sewing Machines
Tiny Tailor bobbin won't wind
I don't know the solution but you can find the manual here:
Do search for TT600 when given the model number (do NOT use TT600X since it wll say not found). It's a very nice manual that is in PDF format.
Jan 12, 2009 | Singer Tiny Tailor TT700
Missing part
Oct 22, 2008 | Singer Tiny Tailor TT700
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
