Question about Toshiba Computers>Laptops Satellite A5 PC Notebook
My Toshiba A50 won't start. Just gives a choice between running windows normally and repairing (recommended) on the ground that it either didn't turn off correctly due to power cut or has some
    Problem Solver:
  • 17 Answers
Try going into safemode
After you see the Toshiba logo disappear. Press and hold the F8 button.
You should get a choice. Choose Safemode. If it loads try doing a system restore.
Unfortunately, if it does not load, then your Windows OS is too corrupted and needs to be re-installed. You will need the original disc that came with your laptop to do this.
Posted on Oct 26, 2012
  • Steven Oates Oct 28, 2012
    Thank you very much. Actually I made a mistake and the model is A660. But anyway I tried the F8 thing, then the recovery disc - but none of it works.
rockitman187
  • 2559 Answers
SOURCE: windows vista wont start
Ok,Try safe mode with command prompt,If you can get to the command prompt
Type these in one at a time and press enter ( let each one completely finish before typing the next one.)
Bootsect.exe /NT60 c:
Bootrec.exe /FixMbr
Bootrec.exe /FixBoot
Bootrec.exe /ScanOs
Bootrec.exe /RebuildBcd
bcdedit.exe /import C:\Boot\BCDBackup
Posted on May 21, 2009
devdeep dhar
  • 375 Answers
SOURCE: Laptop won't starup (Black screen displayed) Help me please!!
Try this.
Turn the computer on and immediately press and hold the F8 key.
On the Advanced Boot Options menu, choose Repair Your Computer.
When you reach the System Recovery Options menu, choose Startup Repair. You already did that, but try it again.
If that doesn't do the work, go back to the System Recovery Options menu and do a System Restore.
You can use the Bootrec.exe tool in the Windows Recovery Environment (Windows RE) to troubleshoot and repair the following items in Windows Vista or Windows 7:
  • A master boot record (MBR)
  • A boot sector
  • A Boot Configuration Data (BCD) store
Note When you are troubleshooting startup issues by using the Windows RE, you should first try the Startup Repair option in the System Recovery Options dialog box. If the Startup Repair option does not resolve the issue, or if you must troubleshoot more steps manually, use the Bootrec.exe tool.
To run the Bootrec.exe tool, you must start Windows RE. To do this, follow these steps:
  • Put the Windows installation disc in the disc drive, and then start the computer.
  • Press a key when you are prompted.
  • Select a language, a time, a currency, a keyboard or an input method, and then click Next.
  • Click Repair your computer.
  • Click the operating system that you want to repair, and then click Next.
  • In the System Recovery Options dialog box, click Command Prompt.
  • Type Bootrec.exe, and then press ENTER.
Note To start the computer from the Windows DVD, the computer must be configured to start from the DVD drive. For more information about how to configure the computer to start from the DVD drive, see the documentation that is included with the computer or contact the computer manufacturer.
Thank you Sir, Have a nice day.
Posted on Sep 20, 2009
  • 9 Answers
SOURCE: My toshiba pslb8us-05202f satalite l305-s5908,
do the recovery from the Windows CD , then chose repair
Posted on Mar 15, 2010
drckzm
  • 243 Answers
SOURCE: my toshiba satellite laptop keyboard just quit and
turn off your laptop by hold your power..ten turn on again and try to press f8 when it booting..go to safe mode and restore it by go to all program, accessories, system tools, and system restore
Posted on May 12, 2011
  • 4044 Answers
SOURCE: i have toshiba C655D-55136. even
Usually that long beep is indicating a hardware problem. To eliminate the hard Drive, Memory and Keyboard when you get the Toshiba Splash screen enter the Bios and there are options to test the Hard Drive and Memory if the keyboard functions to let you make those selections then the keyboard is good. If all three are good then that leaves the Video and Screen. Usually you can enter into Safe Mode and look at Device Manager and see if you have any error indicators on critical devices. The system will not give you that error beep for a network card or Phone Modem issue but will do that if the cooling fan on the CPU or Graphics cards does not work. The CD faulting out will not give you that warning either. I have had a few computers give me this same situation and all I did was start them in Safe Mode and then reboot and the problem resolved. Most likely this problem is the Keyboard, hard Drive, Memory or a cooling fan issue. Depending on how old the computer is you may have a clogged cooling system, this is especially true if you have it outside or traveling a lot or have long hair pets.
Posted on Jul 17, 2011
Toshiba Satellite A305-S6837 is in a "DO -LOOP" with the following:
Use the Windows Install disc and load on top of previous version. Do not do a clean install, this will delete all previous settings and data.
Jan 06, 2013 | Toshiba Satellite A305-S6837 (4400 mAh)
Windows wont start, launch repair won't start and won't start as normal either
Insert your windows dvd into disk drive. Follow recovery options or re install.
Oct 20, 2012 | Computers & Internet
Window 7 won't boot up
BECAUSE THE FIX IS LONG GO TO http://windows.microsoft.com/en-US/windows-vista/What-to-do-if-Windows-wont-start-correctly
Apr 15, 2012 | Computers & Internet
My Laptop wont boot , and coudnt run Samsung recovery 4
u need to try a complete reinstall of windows from CD/DVD drive.
u may have a HDD problem or just a complete software problem so reinstalling windows will hopefully fix this and u can then at least get into the machine to make more changes.
I have the same computer so let me know the outcome here or at philip.irving01@btinternet.com. I can supply u with a windows CD if needed.
another idea could be to use a removeable HDD to see if it is a hardware or software problem.
this sort of problem needs to be looked at, a few lines explaining don't really help me alot.
Dec 05, 2011 | Samsung R430 Notebook
I can't connect to internet after i format may toshiba satelite a50 psa50L-07mOO2 how can i find land driver of my toshiba satelite a50?
Pls follow the below link to install the LAN driver...
http://drp.su/drivers/notebooks/?v=Toshiba&m=Satellite%20A50&id=41541&l=en
OR
http://driver-toshiba.blogspot.com/2010/02/toshiba-satellite-a50-drivers.html
thank you
Aug 03, 2011 | Computers & Internet
I can't start windows normally, when turn on the power it shows startup repair recommended. if choose that nothing open, just black screen. how to fix this problem.
Normally computers do have the repair option, but usually it does not work or if you have formatted your PC and changed the OS.
The best way to get it repaired is to boot from your Windows CD. Once booted from the CD, you will have the choice to repair Windows. Just select this option and it will correct the problem.
Once done, your computer will restart and you should not get this message anymore.
Hope this helps!!
May 15, 2011 | Computers & Internet
When I turn my Toshiba Satellite A50 on and Windows tries to boot I get the following: Windows could not start because the following file is missing or corrupt: WindowsSystem32ConfigSystem It then says:...
You need the Toshiba CD that says "Operating System"...
If the CD doesn't boot, then boot to the BIOS setup screen and change the boot order.
CD should be listed first.
Re-boot.
Sep 25, 2009 | Toshiba Satellite A50 Keyboard
I have accer 5570 Laptop when ever i start it up it gives me this message on and off and wont let me start the window here what it says" windwos Erro Recovery-windows failed to start. A recent Hardware or...
Tried starting normally & go int contol panel on the start menu,system tools & system restor to last good setting!
Hope that helps but if not get back to me!
Sep 22, 2009 | Acer Aspire One AOA150-1784 Netbook
Toshiba Computers>Laptops Satellite A5 PC Notebook Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
