Question about Sony 8gb Memory Pro Duo Stick Ms For Psp Camera 8 Gb Psp
Can you recover your memorystick - Sony 8gb Memory Pro Duo Stick Ms For Psp Camera 8 Gb Psp
    New Friend:
  • 25 Answers
Dear friend,
Its little difficult to recover lost data from a memory card, but if you have a computer then with your memory card attached to your computer go to www.recova.com . This is the best site to recover lost data for free!
Regards,
Priyank Abhineet.
Posted on Oct 26, 2012
Hi I Have a 2GB Sony MemoryStick PRODuo and when inserted to the camera it said that there was no space available (when there was), so I deleted them from a computer and when took the MemoryStick out and...
Don't be panic. you can try some data recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Apr 28, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
Sony Cyber-shot DSC-T700 system error message error C 32:01 what is this and how is it fixed?
C:32:01 is a "disk format error". It means that your memory card is most likely corrupted.
First, remove the memory card and visually check that the electrical contacts are bright, clean and not greasy. Do not touch the contacts with your bare skin, use a cotton bud moistened with alcohol or methylated spirits if they need cleaning. At the same time, check that the lock switch on the MemoryStick is fully unlocked. Slide it fully to locked and then fully back to unlocked.
If the contacts and lock switch are fine then you can try reformatting the MemoryStick using the "Format" command in the camera menu, do NOT do this on a pc/Mac or in an external card reader. If there is an option to "Full Format" or "Quick Format" choose the full option. Note that any stored images will be deleted, but if you have suitable data recovery software they can still be recovered afterwards as long as no new pictures are taken which overwrite the data.
If that fails then try another MemoryStick in your camera. If the fault remains then the camera is faulty and must either be sent to a Sony Service Centre or replaced. Your camera may still be under the manufacturer's warranty, if so repairs will be free.
I hope that I have been of some assistance; please take a moment to rate my answer.
Sep 24, 2010 | Sony Cyber-shot DSC-T700 Digital Camera
When you turn it on the lens pops out, and retracts and pops out. can not take pictures message says access then eventually the message says turn off
There are a number of potential causes but the most likely one is that either the MemoryStick has had the protection switch turned on.
To check, remove the MemoryStick and look underneath it. There's a small physical switch near the electrical contacts; the slider needs to be switched away from the contacts to unlock the memory card.
If this doesn't fix it, then try cleaning the contacts with a cotton bud (US= q tip) moistened with alcohol, and if this doesn't fix it borrow or buy another MemoryStick (when new the camera is usually supplied with a free small capacity MemoryStick which most owners instantly replace with a larger capacity version, so maybe you can try that one).
If that doesn't work then please post a comment and we'll try the next steps.
If I have solved your problem already then please let me know by rating my answer.
Oct 02, 2009 | Sony Cybershot DSC-T200 Digital Camera
I cannot formate my sony 1gb memory stick pro duo when i inserted in my computer it shows it cannot use it before formate disk when i tried to formate it shows window was unable to complete the format
Windows formatting tools are not good enough to format Sony memorysticks.
You need to use special formatting tool
Download that from here:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=MSACUS40&upd_id=2860&os_id=7
If this will not be able to format your memorystick - call sony support and report that repair of memorystick is necessary. It is a hardware fault with memorystick and it needs to be repaired or replaced.
May 28, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Deleted pictures
Please download Smart Recovery free software and hope this will recover deleted photos.
Jan 15, 2009 | Cameras
Do i have to upgrade my psp version to use the memory stick?
you dont need to Update the memorystick
put it in the psp and then format the memorystick
after formatting it should work
memorysticks need to be formatted to the system your using it for
please rate"
Dec 18, 2008 | Sony PlayStation Portable (PSP) Console
Deleted photo recovery from cameras internal memory
Please try this, turn on your camera, insert a blank memory stick, slide the side switch down to the lowest point, should say “No file in this folder” click on menu, click on Setup, use the arrows and go to Memory Stick, choose “Copy” choose “Album” the “OK” this will copy all you pictures from the Album in your camera to your memory stick.
Hope this helps
J
Apr 12, 2008 | Sony Cyber-shot DSC-N1 Digital Camera
Accidental Hard Drive Deletion - Please Help
you may try to go to esupport.sony.com and download the file rescue program for memory sticks. you will need a memorystick model number and serial number to download it. try this: MSX M1GST(model name ) K422L1L(serial number) email me me if you want me to walk you through.
Feb 26, 2008 | Sony Handycam DCR-SR40 Camcorder
DSC F-505 doesn't support Mac OS?
SInce the only storage option on the F505 is Memorystick, you would need a memorystick reader. Sony has a MemoryStick/PCMCIA adapter card that would fit in standard PCCard slots. Once the images are in your computer they are standard JPEGs. Go to the Cybershot forum on http://www.mavican.com and ask what the F55 Mac users do. It also uses only memorysticks.
Sep 08, 2005 | Sony Cyber-Shot DSC-F505 Digital Camera
Sony 8gb Memory Pro Duo Stick Ms For Psp Camera 8 Gb Psp Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
