Question about Nikon COOLPIX L5 Digital Camera
If sd card is inserted then camera screen is blank and lens doesnot move.without memory card camera works fine
  • kakima Oct 26, 2012
    What capacity memory card?
  • rohanria
    rohanria Oct 26, 2012
    512 MB card. I was using this card earlier
  • Nikon Master
  • 32,281 Answers
Try a different SD card. it maybe faulty.
Posted on Oct 27, 2012
bunnykinjoe
  • 3 Answers
SOURCE: Camera stuck when using memory card
hi, i had a problem with my camera where i put in memory card and it said 'out of memory' i took the card out turned on camera went to set up mode and found one that said 'rest to factory defaults' pressed that and then put card in and all ok, might be worth a try :-)
Posted on Aug 15, 2007
  • 6 Answers
SOURCE: Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
Posted on Jun 06, 2008
SOURCE: Sd card won't click into place on my Nikon d60
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
Posted on Jun 20, 2009
  • 102366 Answers
SOURCE: camera works with standard SD memory card, but not SDHC
There are hardware incompatibilities between SD and SDHC cards. They're upward compatible in that SDHC devices will accept SD cards but not the other way around. You will have to hunt down SD cards, 2GB and smaller.
Posted on Apr 28, 2010
  • 102366 Answers
SOURCE: Nikon Coolpix 5900/4 GB Kingston SD Card
The 5900 uses SD cards. The 4GB card you have is actually an SDHC card and will not work in the 5900. You'll have to stay with cards 2GB and smaller.
Posted on May 19, 2010
Camera works with standard SD memory card, but not SDHC
Apr 28, 2010 | Nikon Coolpix L1 Digital Camera
Every time i take a picture on my camera it says memory full insert a Sd memory card to transfer and take more photos i havent took any pictures and i inserted a SD memory card
Try this...go into the menu and scroll to "reset"...follow the on-screen instructions. Then, without a card in the camera, go into the menu and scroll to "format"...follow the on-screen instructions. Then if the pics on your memory card are safely on your computer (use a card reader to do this if necessary) insert the card into the camera, go into the menu and scroll to "format" and follow the on-screen instructions. After all this, you should be ok.
Nov 22, 2009 | Vivitar ViviCam 8025 Digital Camera
The LCD screen comes on but is blank. Cannot take or retrieve pictures.
Hello my friend,
Did you drop the camera ?
Basically this can be Lens broken or screen broken. you can check that by:
1. try to move your hands around the lens and see if it will change something. 2. take a picture even tough the screen is blank and then take the memory card and insert it into your computer, if you can see the picture on your computer that means the screen is broken. but if you cannot see the picture on PC that means the Lens is broken.
Oct 29, 2009 | Samsung Digimax S630 Digital Camera
Camera screen said SD card is locked when I installed an SD card
The SD card has a lever on the side of it. Move it to the other position.That is to prevent accidental erasing.
May 12, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Camera wont turn on
How I fixed my Camera:
> First take your Memory card off, and remove battery
> Now, leave your camera without battery-power
=(wait for while!)
>Then,start your camera WITHOUT Memory-Card.
Note: MiniSD Card with adapter, may crash/freeze camera.
(so use the real "one piece" SD-card, not that Micro-thing!)
>When i removed the old SD card, everything was OK.
I hope this can help many others?
GonaOne from Finland.
Feb 16, 2009 | Samsung Digimax S600 Digital Camera
Chip says full after few pics
The chip may not be inserted correctly. You can tell by seeing or not seeing SD symbol in the view screen. Try removing the SD card. Go through the memory and see if the pictures were saved to the camera or to the card. If the pictures were saved to the camera, turn off the camera and re-insert the card. See if the cards responds by showing more pictures available for taking and move the pictures to the card. If the pictures were saved to the card, then the card may need to replaced.
Dec 31, 2008 | HP Photosmart R717 Digital Camera
Camera wont work when memory card is inserted
I suggest you try to use a different memory card. If it doesn't happen again then it's probably a bad memory card.
Mar 06, 2007 | HP Photosmart M417 Digital Camera
Insert memory card, LCD turns lank
Hello Rach326, try with a new SD card. If it does not help contact the nearest authorized dealer/service. Best regards, Arpad
Jan 12, 2007 | SeaLife Reefmaster DC310 Digital Camera
Nikon COOLPIX L5 Digital Camera Logo
47 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
