Question about Thermador Hood Control Housing - VCH8
I have a Thermador range hood vch-8 with both lights out. The Bosch switch light part 19-19-021 is unavailable. What can I do to get it back working?
  • 1314 Answers
SOURCE: Thermador oven/broiler turns off after 5-8 seconds
two things come to mind a faulty safty valve thats the device that the ignighters connect to the other maybe trash stopping the screen on the pressure regulater are any codes displayed on the clock
Posted on Jan 30, 2008
SOURCE: thermador PDR30 4ZS/05 duel fuel
It's the motherboard. You must have had a power surge. I just replaced mine. Motherboard + shipping 200.00. its not easy to replace but not so difficult.
Posted on Jan 10, 2009
SOURCE: Flashing Lights on Thermador Oven/Range
I HAVE THE SAME PROBLEM. MY OVEN BINKS ONCE FROM BAKE AND TWICE FROM THE OTHER LIGHT. OVEN DOES NOT WORK, ADND WE REPLACE THE CONTROL BOARD ALREADY. WHAT DOES THAT MEAN?
Posted on Jan 31, 2009
the lights flashing in a sequence indicates the error code. The error codes indicates what the problem is with your stove. Based on the response to your message, it sounds like their error code is 12, one then two. It is not clear what your error code is.
There is an explanation of the error codes on the wiring diagram that comes with the stove. I found the wiring diagram for my stove taped to the inside of the kick plate. The kick plate had to be removed to find it.
my oven is not working either. the error code I get is 34. I am told by a technician that error code indicates that the computer is not recognizing that the cooling fan is operating, which is why my oven will not work.
When I try and order a new cooling fan from Thermador, the website says that it is temporarily out of stock. Obviously, other people are having the same problem I am.
Posted on Mar 06, 2009
SOURCE: Thermador Pro Harmony Range--> Blue Lights Blinking
thermador rang, blue light blinking. Oven is not working,
Posted on Feb 05, 2010
Please can someone advise how to get at the switch board for a Bosch cooker hood E-Nr DKE 995 A GB and FD 8009.
many of the switches used are of the push in type and have little clips on the sides that need depressed to extract the switch . without the ability to see exactly what you have make it impossible for us to assist . contact an electrician locally .
Sep 21, 2016 | Bosch Kitchen Ranges
Parts breakdown
Thermador ranges use Bosch parts, or perhaps even are made by Bosch (my strong suspicion). The Bosch part you are looking for is "Bosch (OEM) Part #00369988". It should be available under that number.
Dec 20, 2013 | Thermador PRG486GDUS Gas Kitchen Range
No power to the fan or lights. Checked the
You're saying fan (singular) and lights (plural)? Does this fan and these lights work off of one switch? If so, then it's probably a bad switch. You can check this by turning off the circuit breaker. Remove the switch from the wall, and put the two wires going to that switch together. Make sure to use a wire nut, or tape to keep these wires together without touching and grounding anything. Make sure these wires are clear of anyone or anything, and then go back and turn on the circuit breaker. If the lights and fan go back on, then it's a bad switch. This is what it sounds like. So now, you can turn the cir. brkr back off - replace the switch, and then after everything is secure and the switch is in the off position - you can turn the cir. brkr back on again. Then go back into the kitchen and turn the switch on again to reaffirm that everything is back in working order. If for some reason this doesn't work, feel free to contact me again. Good Luck!  Jim
Mar 30, 2010 | Thermador 30", 36", 42", 48", 60" Wall...
Where can I purchase the 120V, 40w bulb for E27 base thermador hsb wall hood light
Try Reliable Parts Co. at 1800-666-0313. You will probably also need your model number off of the unit.
Dec 16, 2009 | Thermador 30", 36" Silent Series Wall...
Bosch dke 935 90cm hood. light and extractor not working
The fuse will be located in the switch or socket that the hood is connected to. This is sometimes inside the flue on the back wall. There should be two small screws either side of the chimney located at the top, unscrew and slide one part of the chimney down, please be careful as stainless steel has very sharp edges.
Dec 09, 2009 | Bosch DKE93xxUC Stainless Steel Kitchen...
I need a Thermador griddle control/ignitor & a light switch knob
We are Thermador factory authorized service and parts suppliers. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
and we can get your ignitor and light switch out to you asap.
We look forward to working you. Thanks, Ella
Nov 10, 2009 | Thermador 37 in. SGSX365 Gas Cooktop
Replacement filter
I found the part on thermador.com.  Just click on "support center" then "purchase parts & accessorie" and then click the order button for "order accessories and additional parts", on the next screen type in the model "VCH 8" and then just click through the parts list.  The filter part is # 368815 (pos 105).  The part costs $28.40.  I have ordered it but have not received it yet.  Good Luck!   Timnbobbi
Dec 08, 2008 | Thermador Hood Control Housing - VCH8
Jan 30, 2008 | Thermador PRG304US Gas Kitchen Range
Kitchen Ranges Logo
74 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
