Question about Video Cameras
Freezer too dry - Video Cameras
  • Jason Walker Oct 28, 2012
    My freezer has trouble with moisture regulation I think. When it makes ice cubes, if they aren't used within 10 days or so they shrink considerably and eventually disappear. What causes this?
    Novelist:
  • 269 Answers
Why is this question in camcorders?
Water can evaporate from ice. This is called "sublimation".
As a result, ice cubes shrink, especially in frost-free refrigerators, which are often very dry. Frost free models have a fan that circulates air internally so the moist air gets blown out, rather than
Freezers get condensation from moist air that gets inside when you open the door. Frost free models cycle off every few hours, and warm up a bit (a heating coil) to melt the condensation and then they blow that out so it won't form frost. They also blow out any vapour from the sublimating ice cubes. Then they cool down again.
Posted on Oct 28, 2012
How can I tell if meat is freezer burn
Usually looks dry/milky colored and is hard. Sometimes it is also a green tinge. Pork is good for about six months when frozen in a deep freezer with butcher wrap. If you are using a frost freeze refrigerator freezer, in a freezer bag us it in 2-3 months. From your picture they don't look freezer burned, feel the chop, if it is dry and hard, it is, if not probably fine.
Jan 28, 2015 | New York Prime Meat Pork Loin Chops Center...
Frigidaire upright, affu2067ew2, freezer door cold and wet, door gasket is dry all around and tight seal. It is in the garage but this has never happened before in 8 years. The whole door is now cold on...
most likely evap iced up and unit drying to de-ice..defrost timer may be faulty..empty freezer ,unplug. if water is present in freezer section after 2 hours.evap definately plugged with ice..repost if this isn't yor problem
Nov 18, 2013 | Refrigerators
Why do pharmaceutical companies use freeze-drying?
Pharmaceutical companies often use freeze-drying in order to increase the shelf life of their own products like different kinds of medicines that should be store in low degree temperature.
Aug 09, 2012 | Camping, Backpacking & Hiking
Maytag refrigerator model number MSD2735GR - Leaks from freezer. Ice build up around condensation drain hole. I have unthawed twice and unclogged ice from the condenate line. Keep having same problem.
I suggest you empty the freezer. Then use a hair dryer to copletely dry the entire inside of the freezer then make sure everything you put back in is dry. I had this same problem and this worked for me. Just had to much humidity in freezer.
Jan 01, 2012 | Maytag MSD2732GR Side by Side Refrigerator
I have this majic chef freezer about 7 cubic ft. 3 years old turned it off to defrost and when turning it back on it won't get cold?? Compresser is hot so I believe it is working and lights on in front...
I'd let it dry out totally then try it again, some of the electronics may have gotten wet when you defrosted it. Give it a week somewhere warm and dry like a garage. If you didn't attack built up ice in the freezer with a knife while defrosting it it should work after it dries out. Most people end up killing freezers by accidently poking holes in the evap coil while trying to remove built up ice.
Aug 14, 2011 | Magic Chef Chest Freezer MCCF5WBX
Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Apr 18, 2010 | Maytag MFD2560HES Bottom Freezer French...
Amana ABB2224DES - 5 years old - freezer is not keeping ice cream frozen it is mushy - the freezer setting has been set on 6 for a long time
Check temp. should be around 0. If not check to make sure condensor fan motor is working. Check condensor for lint. Do not put ice cream in door shelfs this is the warmest point in freezer. if has a icemaker, check to see if ice in bucket has a wet look or dry look. Wet is a not cold enough. dry is cold enough. If refrig is cycling of and on and temp is 0 , ice dry... possible bad thermastate/ sensor.
Mar 05, 2010 | Refrigerators
Water to ice maker leaking in freezer
I emptied out my freezer. Turned it off and made sure it was dry and clean. Then I turned it back on, but left the metal wire that controls the ice maker up so water wouldn't fill until freezer was cold enough. When cold enough, I dropped the metal wire down and kept a close watch of the filling process. Everything went smoothly. No problems in this first 24 hours. I think ice must have built up and letting it thaw and dry made the difference.
Oct 20, 2009 | Amana Refrigerators
Water leaks from the freezer area to the fridge
Check your drip pan and the nozzle of the line and see if it is dry. If it is dry you got a clog like I did.
I solved my own is the line from freezer to the drip pan was clogged with ice. Just remove the two back screws in the freezer section and melt the ice using hot water from the tap and maybe use a light pump could be a small foot pump nothing to powerful to put in the hole and pump until you see the water come through.
Aug 04, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer gasket dry
Roll the gasket back from the inside edge and under it you will find screws if they were the method used to secure the gasket in place.
Jul 31, 2008 | Refrigerators
Video Cameras Logo
117 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
