Have sound, no video
I wasn't getting video or sound so I went into setup. It was set for S cable and I changed it to Progressive. Now I have a black screen and can't get the setup page or anything else on screen.
Pressing the I/E button on the remote control repeatedly until the DVD blue screen appeared fixed the problem.
Posted on Jan 05, 2009
How do you get higher than 480p resolution on playback?
Hi Chuck, I copied this from the MWD7006 manual - I hope it helps.
If your TV is compatible with 525p (480p) progressive scanning and you want to enjoy that high quality picture, you must use Component Video cable connection and progressive scanning mode.
To set the mode, set "PROGRESSIVE" to "ON" in SETUP menu, so that the "P-SCAN" indicator on the front panel lights up.
When "PROGRESSIVE" is "ON", video signals from the unit's VIDEO OUT and S-VIDEO OUT jacks will be distorted or not be output at all.
If your TV is not compatible with progressive scanning, use this unit in interlace mode and set "PROGRESSIVE" to "OFF" either in SETUP menu, or by pressing and holding [PLAY B] on the front of the unit for more than 5 seconds, so that the "P-SCAN" indicator on the front panel lights off.
Download Magnavox MWD7006 Owner Manual
Jan 25, 2014 | Philips Magnavox MWD7006 DVD Player
While going thru the settings on the dvd part of my sanyo dvd/vcr reciever it went to progressive scan mode and now i can't get back to the setup part to turn it off, can you help me?
If your TV has component video inputs then it will work (and give you improved video quality) in progressive mode. If not try leaving it unpluged for several hours to see if it resets itself. Otherwise refer to your owners manual to see how to reset the settings.
Aug 17, 2011 | Sanyo Cinematic Progressive Scan DVD...
PROGRESSIVE LIGHT WAS SET BY MISTAKE, AND IT HAS BEEN SET ON AUTO HOW CAN I SOLVE THIS PROBLEM BECAUSE THERE'S ONLY A BLACK SCREEN AND SOUNDS THAT COMES ON.
According to the operating instructions (page 97), Progressive Scan can be cancelled (or turned off) by pressing and holding PAUSE (on the main unit) continuously for 5 - 10 seconds, until the progressive indicator goes out, or turning it off in the setup menu. Your recorder should now be back to normal interlace video output. I recommend that you check your setup menu after this procedure to make sure nothing 'AUTO' is set, that shouldn't be set, and subsequently turning off any function that isn't required.
Apr 30, 2011 | Sony RDR-VX515 DVD Recorder/VCR
I have a Sanyo Cinema Progressive DVD player and the videos are playing back in black and white, rather than in color. What is the problem?
The output signal maybe set to S-video and the input connector does not have S-video capability. Change the output signal or use a HDMI cable. If the connection is via progressive cable (three leads), the colors maybe mismatched.
Apr 09, 2011 | Sanyo Cinematic Progressive Scan DVD...
I want to set up my dav-fr10w to 'interlace' option so i can play the dvd's on my tv, but it's set to 'progressive' right now and the instruction manual doesn't give the specific information to change it....
To cancel Progressive scan output or to change output to interlace signal format, follow these steps..
1- Select DVD by pressing Function button on unit.
2- While holding down |<< (review) button, press Function button on unit.
This will change output signal to interlace/ composite video output from yellow pin/ S-Video.
Hope this info will help you.
Thanks.
Feb 05, 2010 | Sony DAV-FR10W System
I have a dvp 3960/37 player I am trying to hookup to a Sony KV 32fs120 TV using YPrPb as a component. The Sony manual says the DVP must be Setup before connecting. The Phillips manual says to use the TV's...
If you are using the component output from the dvd player (3 wire video) progressive scan connect corresponding cable to tv . Besure to match colors. If you are getting a black and white double image you need to set the output of the dvd player to progressive scan. See owners manual for dvd player to set this. The yelow color jack on the tv is composite video and is not compatible with the 3 wire video .
Nov 20, 2009 | Car Audio & Video
I was in the setup screen for the Protron PD-DVR-100 and chose progressive scan for the output. Then the screen went half black and half white. The trouble shooting in the manual send to put it back to...
If your player has the red blue green video inputs on the back plug your video cable into one of them the picture will be a bit distorted but you will be able to see enough to change it back. I did this one time with mine.
Aug 13, 2009 | Protron PD-DVR100 DVD Recorder
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
