Question about Coleman Powermate Premium Plus 6250W Portable Generator
Coleman generator 54 series manual
4000 watts
SOURCE: oil type and capacity
Use 10/30 weight oil fill till : " if it has a "dipstick" fill to middle of hash marks" if not, There in the hole for the oil filler cap their is a knotch cut out of the theads for that cap. fill to just below the top of that knotch . drain plug on bottom of crankcase
Posted on Sep 01, 2008
SOURCE: lost manual 6250 watt coleman generator what oil to use and were
If it has the Tecumseh engine..
Above 40°F Straight SAE 30W
Below 40°F down to -20°F Straight SAE 10W or SAE 5W30 or
Below 40°F down to -40° SAE 0W30 Synthetic
Using multigrade oils above 32°F will increase your oil consumption. SAE 10W40 is not recommended.
Per the manual, all the oils should be marked A.P.I. Service SL/SJ, but you may have to use something to a newer standard. E.G.: Service SM.
The oil sump capacity is 1-5/8 U.S. Pints or 0.76 Liters.
Hope this helps.
Posted on Dec 31, 2008
  • 211 Answers
SOURCE: looking for owners manual for coleman powermate 4000
Hi
First you need to change the plug with a new one with the same heat range(too long time).Priming the engine few times(put some gas in the cilinder through the plug hole)and start the engine until it runs constantly.
bestregards savumihai71
Posted on Feb 12, 2009
  • 252 Answers
SOURCE: need manual for my Coleman Powermate generator
Get model number and go to: http://www.powermate.com/productmanuals.php?cat_id=3
Posted on Mar 11, 2009
  • 905 Answers
SOURCE: Coleman Generator not Making Power
actually, it sounds like the diodes are blown. Check our diodes.
As for checking stator, find the two wires, typically labeled L1 and L2 that are going to it. Measure with a multimeter. If there is no visual signs of damage, continuity can indicate a good stator. You should not have continuity between either wire and the stator frame.
The same goes for the rotor as well. The resistance measurements will not be the same for each one though.
Unfortunately, Powermate is out of business, and service information is scarce.
Posted on Aug 25, 2009
Missing part off carb need service manual
Look up make and manufacture on google, download from manufacturers website
Jun 22, 2016 | Coleman Powermate 4000 Watt Generator...
Wiring diagram for Coleman 4000 watt generator
Request the wiring diagram directly from Coleman.
Mar 02, 2013 | Electrical Supplies
Manual for powermate 54 series model#545020
what is the low pressure ( ) setting for a powermate 54 series
  • model 545020 is . because .i need a new fuel pump and dont have the manual for it thank you
Sep 30, 2012 | Coleman Powermate Powermate 5000W...
I'm looking for an owners manual for a Coleman Powermate 4000
You may not be able to find the owners manual, but if you search using model / type #s off the engine, you may be able to find the manual for the engine from the manufacturer.
May 07, 2010 | Coleman Electrical Supplies
Generator runs, but doesn't produce electricity
Manuals and part lists:
Contact information:
http://www.powermate.com/contact.php
Mar 20, 2010 | Coleman Powermate Premium Plus 6250W...
Where can I get parts for Blue Max 6.5hp blue max
http://www.powermate.com/productmanuals.php?cat_id=3 for manuals and parts diagrams
Mar 16, 2010 | Coleman Powermate Powermate 5000W...
I have a 4000 watt Coleman generator that won't
If it has been in storage with gas in it. it is gunked up. Need to remove carburetor and take to someone to clean carb.
Aug 23, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
245 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
