Question about Epson 9880 stylus pro Printer
Epson 9880 only prints c m y k - Epson 9880 stylus pro Printer
3 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: Epson Stylus Pro 9880 Does Not Print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
  • 10865 Answers
SOURCE: My Epson 9880 will have
Hello terry..... Here is an excellent link to step-by-step instructions on how to solve this annoying problem... http://www.google.com/#sclient=psy&hl=en&safe=off&rlz=1W1DKUS_en&q=epson+printer+how+to+clean+the+cleaning+station&rlz=1W1DKUS_en&aq=f&aqi=&aql=&oq=&gs_rfai=&pbx=1&fp=7b989c6c17f79c85
Joe
Thanks for choosing Fixya!
Posted on Dec 19, 2010
How to fix printer blurr
most likely you're wiper for the capping station is covered in ink. I recommend having the printer cleaned by someone who does maintenance on Epson printers.
Mar 21, 2014 | Epson 9880 stylus pro Printer
Epson 9880 prints half a job, then stops
i aint too sure if its the same but i had an epson printer with the same problem last year it would print half a page spit out and then print the same half a page again and just stuck in a loop even on printing disks it did the same i found out after by speaking to a printer specialist it was the printers eeprom which is the printers memory bank that was failing and nothing can be done with it
Feb 11, 2014 | Epson 9880 stylus pro Printer
Epson stylus pro 9880 blocked nozzles won't clear
I have a 9800 - you can remove the print head, and try cleaning the nozzles manually and see if there's something on them. I'm sure any warranties would be void if you do such a thing, but - you're up for replacement of the print head anyway. So do with caution and at your own risk.
It takes about 30 mins and requires a reasonable level of skill. Search around and get the service manual - they are out there pretty easy to find. They give step-by-step procedures to get it apart safely.
Then clean the print head with either rubbing alcohol or hot water (alcohol is probably better). If your print head got stuck on tape, you might have the glue from the tape on the print head. So some kind of solvent to remove the glue - again - be careful and watch that you don't create further problems.
I've done similar with my printer and it still works fine and haven't had to change the print head for the past few years.
Feb 05, 2014 | Epson 9880 stylus pro Printer
Paper not sensing
i think the head of your printer ruined take it to epson agent to repair it
Oct 12, 2013 | Office Equipment & Supplies
Epson9880 no ink sent to print head
no ink sent to print head at all?problem with printer mainboard, usually caused by short circuit in head, then "burn" the fuse in mainboard.
Jan 14, 2013 | Epson 9880 stylus pro Printer
Can anyone recommend a epson repair shop in Washington state that they have used. I have a Epson 9800 as well as a Epson 9880 that need some work on them.
Printers are a dime a dozen. Don't waste your time fixing it. You can buy a great one for less than 40 bucks,
less money than if you repaired an old one at the repair shop.
Dec 31, 2010 | Epson Stylus Pro 9800 InkJet Printer
9880 not print nozzle ink discharge check in self test
Go to Menu and off Auto Nozzle check ...............
I hope it may solved your porblem
Oct 26, 2009 | Epson 9880 stylus pro Printer
Jan 08, 2009 | Epson Stylus Pro 9800 InkJet Printer
Epson 9880 stylus pro Printer Logo
18 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
