Question about Epson 9880 stylus pro Printer
Epson 9880 only prints 4 color test pattern - Epson 9880 stylus pro Printer
jackboy
  • 2985 Answers
SOURCE: cx4600 epson
Jets are clogged Needs deep clean. 1st try -www,ssclg.com The Epson utility. Run the program- select your model- right click on the icon on the bottom task bar. 2nd Take a look at www.fixyourownprinter.com. 3rd make your own cleaning tool as here
Posted on May 18, 2007
  • 4102 Answers
SOURCE: epson stylus color 760 failing to print.
you can take it to repair shop and they will clean the head for you with some cleaning fluid if it has been without ink for a while sometimes these get blocked but it is not worth replacing cus would cost more than the printer as the ink cartridge you brought was originall then this isnt the problem check all cables if not better off buying new printer as these are not made to last long sorry couldnt be any,more help...........................
Posted on Nov 05, 2007
yooperbud
  • 8637 Answers
SOURCE: Epson Stylus Pro 9880 Does Not Print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
Jay_Sav
  • 93 Answers
SOURCE: Epson 6000 prints light colored line every 3/4 inch.
Clean the heads with some InkJet Head Cleaner. Get a syringe like the ones you get in the refill kits, and remove the cartridges. Using the syringe, gently squirt cleaning fluid into the cartridge nozzles in the printer. Note: Not into the cartridges themselves. Leave to soak for a while, and then using a cotton bud, remove any excess fluid. Run a few cleaning cycles and you should find the heads come back to life.
Posted on Mar 05, 2009
  • 10865 Answers
SOURCE: My Epson 9880 will have
Hello terry..... Here is an excellent link to step-by-step instructions on how to solve this annoying problem... http://www.google.com/#sclient=psy&hl=en&safe=off&rlz=1W1DKUS_en&q=epson+printer+how+to+clean+the+cleaning+station&rlz=1W1DKUS_en&aq=f&aqi=&aql=&oq=&gs_rfai=&pbx=1&fp=7b989c6c17f79c85
Joe
Thanks for choosing Fixya!
Posted on Dec 19, 2010
How to fix printer blurr
most likely you're wiper for the capping station is covered in ink. I recommend having the printer cleaned by someone who does maintenance on Epson printers.
Mar 21, 2014 | Epson 9880 stylus pro Printer
Epson 9880 prints half a job, then stops
i aint too sure if its the same but i had an epson printer with the same problem last year it would print half a page spit out and then print the same half a page again and just stuck in a loop even on printing disks it did the same i found out after by speaking to a printer specialist it was the printers eeprom which is the printers memory bank that was failing and nothing can be done with it
Feb 11, 2014 | Epson 9880 stylus pro Printer
THE FIRST TWO LINES OF A PRINTED DOCUMENT ARE PRINTING DOUBLE.
If your printouts contain misaligned vertical lines, you may need to align the print head. Make sure the EPSON Stylus CX3200 is turned on and not printing, and the Error light is off. Load plain, letter-size paper in the sheet feeder. Press a Menu button until you see Head Alignment, then press the Color Copy button to print an alignment page. On the test page, select the pattern with the two vertical lines most precisely printed on top of each other. You may need to use a magnifying glass or loupe. maint.6.7.1.jpg Select one pattern each for rows 1, 2, and 3. (In this example, pattern 8 is the best in each row.) Press the + or - button to select the number of the best pattern for the first row, then press the Color Copy button. Repeat this step for the second and third rows. Note: If you select a pattern other than 8 in any row, that pattern becomes pattern #8 the next time you align the print head. When you’re finished, press the Stop button.
Feb 10, 2010 | Epson Stylus CX3200 All-In-One InkJet...
9880 not print nozzle ink discharge check in self test
Go to Menu and off Auto Nozzle check ...............
I hope it may solved your porblem
Oct 26, 2009 | Epson 9880 stylus pro Printer
Epson Stylus Photo R340 Faces in photo are printing day-glo green
Possible printhead or driver issue.
Are you using Adobe photoshop? Please try to print also using a different application to isolate the issue.
Make sure that you are using correct epson cartridges.
Please print a nozzle check pattern. If you see gaps, missing colors or missing lines on the pattern, clean the printhead using the driver.
If the nozzle check pattern printed out successfully, please trash and re-install the drivers. The driver is available on epson.com
Apr 29, 2009 | Epson Stylus Photo R340 InkJet Printer
Jan 08, 2009 | Epson Stylus Pro 9800 InkJet Printer
Have Ultra Hi-Definition RX595 Photo all-in-one print,copy,scan,photo. After setting everthing up and when I print from word or anyting the print comes out in color. I thought I could have color or b/w...
1) Make sure the printer is turned on but not printing. Ensure there are no error lights or messages appearing in the LCD.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
Aug 21, 2008 | Epson Office Equipment & Supplies
One color not working
try to clean the print head 3 times and do a pattern test if it still doesnt work then it has to be service
Nov 17, 2007 | Epson C64 InkJet Printer
Not printing in black
Turn off the Stylus CX. Load letter-size paper in the sheet feeder. Press the ink and ON buttons together and hold them down for about 3 seconds.
The Stylus CX turns on and prints a test pattern, which includes a nozzle check. If the print comes as = >
Nozzle check pattern with no gaps, and if its print in black then reinstall the printer driver
or => Nozzle check pattern with gaps and black doesn't print please send the printer for repair
Sep 19, 2007 | Epson Stylus 680 InkJet Color Printer
Epson 9880 stylus pro Printer Logo
37 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
