Question about IBM Lenovo ThinkCentre M55e PC Desktop
4 beep code and no screen appear in lenovo thinkcentre m55e
No screen appear and 4 beep sound continuous listen
2 Suggested Answers
  • 3278 Answers
SOURCE: lenovo thinkcentre a51 reboots with several beeps
Your problem is hardware-related. Either memory or power supply.
Remove the memory and add back one at-a-time and boot to see which one (if any / either) is bad.
If not, the second culprit is the power supply, which would need to be replaced.
Hope this helps.
Posted on Aug 04, 2009
After i change the processor dual core 1.80ghz on the IBM thinkcentre M 55e 9632 series the monitor only showing, cpu=1processors detected,cores per processors=2 intel pentium dual cpu 2160 1.80ghz 1527...
HI,
I am sharing some general info:-
If you are change processor no problem, some point see you like after change processor any beep sound, processor more hitting.
Second check it *********** board power come or not, your display cheap more hitting or not. Check RAM proper connect, your all cable proper connection. If all things ok then may be your PC not supported processor.
Thanks..
Oct 14, 2013 | Lenovo ThinkCentre M55e 9632 PC Desktop
Lenovo won't power on, no light no fan, zero
You need to test the PSU, if you need help post back.
PSU- power supply unit.
Apr 15, 2013 | IBM Lenovo ThinkCentre M55e PC Desktop
Echo through speakers
Unintended reverberation, or "echoing," from your computer speakers is a common problem that can arise from improper setup of your audio properties.
Resetting all of your audio information to default will correct this problem, allowing you another chance to strike a good balance to satisfy your audio tastes.
This can be accomplished by accessing the Sounds menu in your operating system.
Select the "Start" menu from the bottom-left corner of your screen, and click on "Control Panel." Find the "hardware and Sound" button and click to select.
Click on the sound icon and select the third tab labeled "Sounds" in the window that appears. A list of sounds will appear, beginning with "Asterisk." Click on a sound to highlight and select test.
Listen to hear if the echoing problem occurs.
If it does, you need to configure your speakers or check to see if it is a third-party issue.
Select the first tab labeled "Playback" from the same window. Right-click on the "Speakers" icon. Click on "Configure Speakers" from the top of the list.
Choose a setup from the list that appears and select test to test different sound configurations for the speakers.
Listen to decipher if one configuration has less echo than another. If so, choose the speaker configuration without the echo to fix the problem.
However, if none of the configurations remove the echo, you need to attempt to troubleshoot the issue from "Safe Mode."
Turn on your computer if it is off or restart your computer. Continuously press the "F8" key until the "Advance Boot Options" screen appears.
Use your arrow keys to navigate the screen, pressing down until you have highlighted the "Safe Mode" option. Hit "Enter" to select. Wait for the drivers to load.
Log on from the "Administrator" account. Test the sounds again, and if the echo does not occur, the cause is a third-party driver or service.
hope this helps
Sep 15, 2012 | ASUS Computers & Internet
Server beeps continuously can not read monitor ,keyboard
you should start by re-seating the RAM first as this is a common problem. if that does not work re-seat the processor. If all that fails remove all add on cards and memory only leaving the processor and see if the beep codes change. Replace the components one-by-one to find the problem piece of hardware. HERE is a guide from Dell to tell you what the beep codes mean and also some troubleshooting tips.
May 08, 2012 | Dell PowerEdge 2500 Server
How to get rid of static
Your radio allows you to listen for weak signals on
the current channel at the press of a key.
To turn ON the Monitor Mode:
• For brief listening, press MON button. The RX
icon blinks.
• Press and hold MON button for 2 seconds until
two beeps sound for continuous listening. The
receiver circuit stays open, letting both the noise
and weak signals to be heard.
To turn OFF Monitor Mode:
Press MON button to return to "Normal" mode,
and the RX icon stops blinking and disappears.
Dec 28, 2011 | Uniden GMR22382CK Two Way Radio
How do i find out which Lenovo model is my Desktop PC? Its a Lenovo ThinkCentre 9637-AA5.
1) Series:
It's a ThinkCentre M Series Desktop
2) Subseries:
ThinkCentre M55e
3) Machine Type:
9637
4) Model:
The Model Number will be right after ThinkCentre M55e-9637
It will be two numbers and a letter, or two letters and a number, or three letters.
Three characters. (symbol)
Some examples; 21B, 21H, 22U, 28s, 28y, B2F, B26, I2F, (i2F), I64, (i64), W2Y, W2Z, WJW, WJM
ThinkCentre M55e-9637-WJW
(Above is fictional. Just an example)
Regards,
joecoolvette
Sep 20, 2011 | Lenovo ThinkCentre M55e 9637 - Core 2 Duo...
My system is HP G60 with window 7, making this continuous beeping sound on starting window, does give sound from hibernation. Sounds up to 2-3 minutes before the start up can continue.
Beep codes are codes used for troubleshooting hardware issues. Kindly read my Tips and Tricks to give you a better idea. click here
Here's a link to guide specifically for HP and Compaq computers. click here
Hope this helps.
Jul 29, 2011 | Lenovo ThinkCentre M58e Desktop Intel...
IBM Lenovo ThinkCentre M55e  PC Desktop Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
