Question about La Crosse Technology Ws1501 Weather Station - black
I'm not getting rain data from ws1501 station! I've tried several times pouring water into the pluviometer but nothing happened on the console
Tip
How to measure rain fall when your rain gauge overflows
Most rain gauges that you will make at home will only measure up to one inch of rain fall. The problem with this is that if you live in a place where you will get more than one inch of rain your measurement if taken incorrectly will be very skewed. If your rain gauge has been constructed correctly you should have a fail safe in place.
When you construct a rain gauge you should have a measuring tube inside of an over flow tube. The meausuring tube will hold about one inch of rain fall, but when more rain falls the inside tube will overflow into the outer tube. To measure the excess rain fall you will follow a few simple steps.
Start by reading the inner tube of the rain gauge and then carefully empty the tube. Make sure that you don't pour out the water that has overflowed into the outer tube.
Once all the water for the measuring tube has been emptied carefully pour the excess rain water into the measuring tube. To get the most accurate reading try your best to not spill any water out, you can pour the water over a bucket to make sure that if you do spill any out you will catch it and be able to measure accurately.
If there is a lot of overflow you might want to measure a little bit of overflow at a time to get an accurate read. As you measure, write down the measurements and when you finish add up the values to get the reading.
The readings are done in inches so you have a reading that is 1.00 and has an overflow that measures up to .50 then the total read out will 1.50 inches.
on Feb 02, 2014 | Garden
Hyundai Getz leaks near pedals when raining
My Getz is also having similar problem. I have thrice got water test done from Hyundai server center. After 2nd test they put some sealants underbody and return the car, but still water was leaking in. 3rd time water test, hyundai said its all fine, no problem but still problem persists. It happens when it rains only, so I dont suspect air-con filters or radiator problems. Water pool is created in driver side footwell only. During heavy rain, I tried to troubleshoot but couldnt find any fault point from where water might be leaking inside. Its second year, I have running into this problem, creating stinking smell inside the car due to wet mats. Looks like I need to do away with my car.
Apr 29, 2012 | Cars & Trucks
1999 gmc safari doesnt start after heavy rain?
surely ......change the wires check your sparkplugs..
Apr 20, 2012 | 1999 GMC Safari
No steam or water through steam wand on Gaggia Titanium
Try this, push in on the knob when the flow stops, if that works, then the tap rod needs to be replaced. If your machine has the plastic steam valve assembly, try to get the stainless steel steam valve, I noticed that you have replaced once.
Apr 04, 2012 | Gaggia Titanium Espresso Machine
I've a VW golf 1989 every time its starting to rain my car doesnt work at all and i check every thing in it but there is no water reached anywhere do you have any idea about that ??
There HAS to be water getting somewhere!
Have you checked under the hood?
Mainly around the starter, and the alternator, and the battery!
Mar 24, 2012 | 1990 Volkswagen Golf
I have a Playstation 3. Starting tonight, everytime I put in NBA 2K11 the game will load to the main screen and ask me to press start. Everytime I press start me game freezes and I have to restart my...
Yes it will delete all your saved data.
You want to keep the data, so you need an external storage device (memory card, flash drive and so on). Copy the data on the device. If anything happens to the PS3, you still have your data on the device. When you restore the PS3, you can put back the data.
Keep us posted.
Jul 03, 2011 | Sony Playstation 3 (PS3) Console
Water on passenger floor board
You may need some new door weatherstrip.
Also make sure that you don't have water inside your door....
Jun 11, 2011 | 2002 Dodge Caravan
La Crosse Technology Ws1501 Weather Station - black Logo
65 people viewed this question
Top La Crosse Technology Measuring Tools & Sensors Experts
Tom Chichester
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
