Question about Belkin (F5D6230-3) Wireless Router
Comment: There is an IP conflict with another computer on this ne
We have 1 x PC Vista & 1 x PC XP Home, both are desktops networked via a Belkin F5D7230-4 Wireless G Router. Error says, There is an IP conflict with another computer on the network. The xp system is unable to diagnose the problem. The Vista systems offers to diagnose & says there is a bridging problem & is also able to repair it but we have do do this many times per day?
  • 2,460 Answers
What other items are on your network? Do you have a network printer, a wireless access point, a second router, or fixed IP addresses in either computer?
A utility that's easy to use is a product called Angry IP Scanner http://www.angryziber.com/w/Download get the 2.6 stable version and save yourself some time :-)
The idea would be to start one computer on the network, run ipscan, then add the second computer and run it again. It's pretty self-explanatory, you put 192.168.x.1 in the left box and make the last octet equal 255 and press start.
Please take time to post back and let us know what you found for a conflict.
Carl
Posted on Jan 03, 2009
  • 827 Answers
Use either computer to login to the router eg 192.168.0.1 or just type www.routerlogin.com into the internet browser URL bar. Under LAN Setup, click LAN settings, and from the menu that comes up, turn DHCP Server 'on'. This will assign IP addresses for your computers automatically.
Hope this helps
Chris (ziraffa)
PS Your router's 192.168... number might be different from my setup.. try 0.1 or 1.1 or 2.1 etc at the end, or just try that routerlogin method.
Ip conflict
go to start, control panel and select network. right click on local area connection 1 and go to tcp/ip and make sure it is set to DHCP not static.
Feb 23, 2012 | Computers & Internet
Our laptop won't connect to our network set up on our desktop home computer. The desktop is running Windows XP Home Edition V2002, and the laptop is running Windows Vista Home Premium V2006. When we try to...
if you have wireless acces point or 802.11 known as wi-fi,
there might be a problem in your laptop internet protocol, you laptop have an ip address already.
you can fix it by using your desktop, open your desktop go to control panel/network connection/status/
details.
copy the details information and put it to your laptop internet protocol. you can found it in network connection properties you can see Internet Protocol (tcp/ip) open it configure it manually. the last number of the ip address must bigger than the desktop. ex, 192.168.1.2 in desktop. the ip address of the laptop must be 192.168.1.3.
Feb 02, 2011 | Acer Computers & Internet
I have a message that say Ip address conflict, what can I do
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
Nov 24, 2010 | Computers & Internet
IP conflicts using the Belkin Model 570230-4 router and I do not have the belkin utility CD.
For that you need to enable dhcp on router.
Then set in your computer network adapter property to ip get automatic.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then enable dhcp and save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 07, 2010 | Belkin Computers & Internet
Toshiba wireless sees desktop but desktop cannot see laptop. using belkin wireless
this is not likely a problem with your router, here's a couple of tips (this typically works in xp...hate vista and haven't got ahold of 7 yet)
open command prompt, find your ip info (ipconfig /all) try pinging both computers' ip address (ping 192.168.x.x), then ping the router...if you're using local ip addresses it should be 192.168.0.1 or similar...its likely that one ping the other but not vice versa
MAKE SURE the first three numbers are the same, i had a problem when i missed a 192.168.1.1 vs a 192.168.0.1
If you have not created a home network, i'd recommend it...you don't have to make a network disc like it tells you to but make sure they're setup for the same network (i.e. XPHOME, JOHN'S NETWORK)
if they both still are not communicating after a few minutes, try to connect a hard line between them, set one up as the router and dns...your ip config should look similar to this:
DESKTOP LAPTOP
IP 192.168.0.2 192.168.0.3
SUBNET 255.255.255.0 255.255.255.0
GATEWAY 192.168.0.2 192.168.0.2
DNS 192.168.0.2 192.168.0.2
you wont be able to have internet access but I do this to check network integrity, try pinging again, it should work both ways now, set up the network again and then change your gateway and dns back to your router.
I hope this helps, sorry if thats confusing
Nov 28, 2009 | Belkin 802.11g Wireless Desktop Network...
IP address conflicting
Have you checked to see if either computer has a static IP address? that might conflict with the DHCP table.
Jun 27, 2009 | Belkin (F5D7230-4) Router (587009)
How to connect a laptop having vista home basic with a xp desktop
Be advised that,
it makes not different to connect one PC/Laptop to another one via LAN because when you connect your system in lan networking you system will be automatically detected if LAN has been set up through a server.
And if not you need to do manually by assigning ID address on bot PC/Laptop.
For that,
first assign an IP address in either Laptop or desktop (IP address must be same category)
ex.
192.168.1.231 (first one)
and second one should be
192.168.1.here you can up (instead of 231) any number excep 0 but make sure not confliction between other system. means not duplication IP address on same LAN.
once you ae done with IP assigning
Go to
Star>Run>command and hit enter
once you see command prompt then
type there:
ipconfig and hit enter (it shows your ip address) if you wanna have more info then type ipconfig/all
once you are done with this then
you need to ping to your next PC.
for that
type in
ping 192.168.1.231 (means you need to type another PC's IP address here)
and hit etner
if you see like on image
then you are good to go.
Thank you
and rate all answers.
Jan 02, 2009 | Microsoft Windows Vista Home Premium with...
Keep geeting an error message another IP address has been detected. I have a wireless router & laptop, and a desktop whcih the the main computer.
If you have Vista,
  1. Go to START > CONTROL PANEL
  2. Under Network and Internet, click VIEW NETWORK STAUTS AND TASKS
  3. On the side panel, click MANAGE NETWORK CONNECTIONS
  4. Right click your Wireless network, and click PROPERTIES
  5. Single-Click Internet Protocol Version 4 (TCP/IPv4)
  6. Click Properties
  7. Write down all the infromation in case you need to type it in again later.
  8. Click "Obtain an IP address automatically" and "Obtain DNS server address automatically"
Sorry, but I cannot help with XP at the moment.
Mar 06, 2008 | Computers & Internet
WRT54G linksys router
The first thing I would do is check to make sure the desktop with XP has the network card set to "obtain an IP address automatically"
if it is set to obtain an ip address automatically, I need to know the following:
What is the IP addresss of the router?
What is the IP address of the Vista computer?
What is the IP address of the xp computer?
You can find the ip address by going to start, then run, then type cmd and hit enter. at a command prompt type: ipconfig and hit enter.
Feb 21, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin (F5D6230-3) Wireless Router Logo
231 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
