Question about Kenmore Side by Side Refrigerator
Motor works but fridge doesn't get cold. kenmore model 106.53502300 can you help
Model #106.53502300 mfg 11/2002
    Genius:
  • 1,011 Answers
Might need gas
Posted on Oct 26, 2012
Compressor model#md152c-r1u dose not start?
Posted on Nov 28, 2012
  • Audley Mckenzie Nov 28, 2012
    compressor model#md152c-r1u dose not start?
  • 62 Answers
SOURCE: Freezer works but fridge does not cool..please help
Ther are several things that can cause this, one a bad evaparator fan or an defrost problem. Look on the back of the freezer wall and see if there is a lot of frost. If there is then it's a defrost problem and the part most likely is a bad termination thermostat also known as a bi-metal. If there is not a lot of frost, check to see that you have air going to the refrigerator section. If not then it could be the fan.
Posted on Aug 30, 2008
bobicehouse
  • 1524 Answers
SOURCE: fridge won't get cold
Try checking the compressor relay (little black box) she might have gotten it wet.
Posted on May 01, 2009
peyton32034
  • 410 Answers
SOURCE: kenmore fridge not getting cold
first thing to heck would be the condenser fan motor which is located int the compressor compartment pull the refrig away form the wall remove cardboard cover and inspect the fan motor that you will see. check for obstruction or if the fan motor is seized. if this motor fails it will cause the compressor to run extremely hot then shut off on internal motor protector. if you determine the motor is bad you can place a house fan behind unit blowing on compressor area to keep unit working until you get it repaired.
Thanks Peyton
Posted on Feb 17, 2009
  • 117 Answers
SOURCE: My kenmore refrigerator side by side
All the cooling takes place in the freezer and is blown over to the frig side so the frig side will start to warm up soon. Possible cause is the starting device to the compressor is faulty, compressor motor locked up or cold control faulty and not closing.
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
Trifect7
  • 57 Answers
SOURCE: refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Posted on Mar 04, 2008
Hi, I have a kenmore coldspot 106.56152500 and the fridge has stopped working. I can hear it running but it is not cooling at all. The freezer is still working, however, not as cold as it should be. I...
Yes the most likely reason for not defrosting is your=> W10135901 Defrost Control Board
The defrost control board can be found inside the fresh food compartment behind the control panel where you adjust temperatures for the refrigerator and freezer. To gt to the control board you need to unplug the refrigerator and disassemble the control panel. Look over the control board sometimes you may see signs of heat damage but not always. If you have questions I will be here so please ask, Thanks Sea Breeze
106.56152500 Parts
Jul 03, 2012 | Refrigerators
My kenmore refrigerator / freezer (model #2539338710 mfg: 4/95) won't get cold enough. The freezer & the refrigerator are both @ 49 degrees with the controls in the freezer & refrigerator
HI JOHN.both at exact same temp.sound like your motor is not running due to failure or relay or overheating due to con/fan ;cond/unit blocked or again motor.check these first good luck Ali
Jun 29, 2012 | Kenmore Refrigerators
Refrigerator not cooling. doesn't seem like fan is blowing. freezer still working
all that happens is the cold air from the freezer gets blown into the fridge section by the evap fan motor brhind the inside back wall of the freezer so if you open the freezer door and don't hear the fan blowing i would say that yes you do have a bad evap fan motor and that's why the fridge section is warm.next time send the brand name and model number so i can help you better
Sep 17, 2011 | Refrigerators
The fridge (kenmore) doesn't seem to be cooling but the freezer (on the bottom) seems to be working fine. Help! :((( Single mom
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Refrigerators
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
Freezer works great but refrigerator. Doesn't get cold its cool but not cold turned thermostat to 33 and ut isn't gettingcold
heatman101
Aug 21, 2011 | Kenmore Side by Side Refrigerator
I have a Frigidaire FRC150FF fridge, the fridge light comes on but the fridge is warm. The frezzer compartment is working fine
How old is the fridge? Can you hear it running?
It could me many things. Could be anything from a dead compressor to a coolant leak.
Did someone change thermostat setting, maybe during a cleaning? There's a knob in the refrigerator section somewhere; see if it's turned to "Off" or to a less-than-cold setting.
If you hear the motor running, but it doesn't get cold, it probably doesn't have any refrigerant to compress. That could be recharged, but modern refrigerators are pretty tight, so that would also indicate a leak. With a leak, it will need recharging again sometime later.
Jul 22, 2011 | Refrigerators
Refrigerator side is barely cool. Defrost light on for over a week, but unit is self defrosting??? why is ref section cooler not performing?
you have a defrost problem?all a fridge does is blow cold air from the freezer to the fridge section,when you open the freezer door you should hear the fan blowing,under the fan there's the evap coil,this is what makes everything cold,if it doesn't defrost it gets covered with ice and then you have problems or on some models there's a damper and the door doesn't open stopping the cold air from blowing into the fridge section.you'll need a meter,pull out all the food in freezer,remove all shelves and then remove the inside back wall of the freezer.with a hair dryer melt out all the ice,then find the bad part,defrost thermostat,defrost heater,bad timer or board depending on the modelwith the meter you can check the parts.also if you look down at the bottom kickplate,pull the kickplate off and look for a tech sheet,it will tell you how to put the machine into defrost,also next time send the model number so i can see what model you have,if you have a timer advance it and see if the heater comes on,also it doesn't hurt to change out the thermostat while you're in there and alot of times this is the problem,you can cut the two wires going to the thermostat located on top of the evap coil,connect them bypassing the thermostat,put the fridge into defrost,listen for a crackling sound,if you hear this the heater is on and you'll know the thermostat is bad,call your parts store,give them the model number and they will sell you the correct thermostat,if the heater doesn't come on remove the heater on the bottom and read it out with the meter,if it's not a glass heater most likely the heater will be good but check it anyway with the meter.if that's good then most likely you'll have a board problem depending on the model.hope this helps and good luck.
May 07, 2011 | Kenmore Refrigerators
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Side by Side Refrigerator Logo
1,011 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
