Question about Canon PowerShot A560 Digital Camera
Canon powershot a560 problems with batteries?
Each time i put new batteries in no matter what it keeps telling me that i need to replace the batteries..... it wont stay on for anything can anyone help????
  • 9 more comments
  • drea_da_lett Jan 04, 2009
    Thank you fixed it right away!!!
  • salcharette Jan 05, 2009
    I'll try the other batteries, but it seems strange that the camera has worked just fine on the regular batteries for more than a year and suddenly won't recognize them.
  • maggiebelle Jan 13, 2009
    My A560 will not power up any longer and I have used rechargables since it was new. I've tried several different batteries with no success. I have it packed up and ready to send back to Canon during lunch today. I'm hopeful they'll have it back to me as fast as last time when the shutter refused to close.
  • mrsfeige Jan 16, 2009
    I have the same problem. I was using NiMH batteries all along. When I contacted canon they said I have to use canon brand NiMH batteries. What a crock. Has anyone found a solution to this other than canon batteries?
  • kearney4 Jan 31, 2009
    I have the same problem as does my Brother-in-law and the same problem seems to be all over the internet blogs. Canon's big fix is to clean terminals with a pencil eraser, or I can buy a new rerurbished camera from them...Must be how they keep the refrurb supply up build in a defect..Time to switch to NIkon
  • sandorjr Feb 07, 2009
    Eu tenho o mesmo problema. Esta camera devora as pilhas novas- podem ser recarregáveis ou não.
    Isto é um absurdo. Gastarei mais em pilhas do que custou a camera. Não vale a pena. Tem que usar pilhas de litio, que são muito caras.
    A Nikon Coolpix L14, faz 1.000 shots com 2 pilhas Energizer-Litio.
    Essa sim, vale a pena !!!!!!!!!
    Estou profundamente decepcionado com o consumo absurdo de pilhas dessa camera .
    Nota ZERO para o consumo de pilhas !!!!!!!!
  • Dawid Gibek
    Dawid Gibek Feb 09, 2009
    I have the same problem. And my sister, who has canon A710, has the same problem as well. We check a lot of different rechargeable NiMH batteries. We deleted picture counter, data, next all settings, change memory card... and the problem still exist :( Our batteries is working fine on other equipment and we checked them with technoline BL700 charger, which show that our battery (energizer 2500) still have 2350 mAh...
  • jvsham Feb 25, 2009
    I also have the same low battery warning problem with my A560 which is less than a year old. It has worked fine for about 8 months, using AA alkaline batteries, so I don't think the post about using only rechargeable batteries is on target. I've read other forums on this issue and it is widespread. Some say the contacts on the lid do not make good enough contact, others suspect some problem with internal circuitry becoming degraded from moisture/humidity. Canon seems to ignore it or tell you to use their rechargeable batteries. I have no clue how to fix this problem but I do not think using rechargeables will do the trick. I have some and will put them to the test and report back.
  • rev_jeff Mar 02, 2009
    I never thought about, but after reading several of the posts here I realized that my Canon A560 did NOT have a battery drain problem for the first year or so of operation. The batteries (just regular alkaline AAs) held their charge well and I did not have to replace them regularly. It just occurred to me that the battery drain problem I am having developed after having the camera for a couple years. I not only tried rechargeables, I even tried buying new rechargeables, but to no avail. I'm wondering what could have changed in the camera's internal circuitry that would result in the battery drain. But it is clearly a later onset problem and not something that was present when the camera was new.
  • llvolkman Mar 23, 2009
    Same problem! I've tried every kind of battery, from regular to rechargeable, even bought brand new ones that are the good kind that are recommended from a previous post. I'm convinced it's not the batteries!!
  • gusdawg Apr 18, 2009
    It's a defect in the camera's durability design inherited from the previous line. The camera worked well for about a year. Then I developed the low battery indication with new batteries problem. It doesn't matter if the batteries are brand
    new duracells or freshly charged Ni-MH. This camera (A560) only is
    capable of a handful of pictures before shutting down with low battery.
    I had the exact same problem with a Canon A75. Note to self, BIt twice = never buy
    Canon again!
    I wish i had a solution. Cleaning the contacts isn't it...
Tem que passar LAPIS BORRACHA nas pilhas, no plo positivo e nagativo, e tbem nos terminais da camera......aí, funciona tudo normal.....se houver um pouco de suor das mãos nos terminais das pilhas, a cemera reconhece que as pilhas são usadas, e pede para trocar as pilhas.....é uma camera MUITO SENSIVEL.......!!!!!
Posted on Mar 20, 2009
Para esta consumidora voraz de pilhas, só pilhas de LITIO.......que custam muito caro !!!!!!!!!! ou troquem pela Nikon Coolpix L14, a camera mais economica do mundo !!!!!!!
Posted on Feb 07, 2009
  • Canon Master
  • 4,738 Answers
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Posted on Jan 03, 2009
I have a Canon Powershot A560. The date and time stamp do not work. I checked the manual and it says to replace the battery located under the flip-up panel on the left side of the camera. I can not...
Think your problem is that you are looking in the wrong spot. Don't know why your manual is telling you to look there (are you sure your manual is for the A560)?
Your CR1220 date/time battery is located in the regular battery compartment. Look right beside your AA batteries. You'll see a little flap labeled "CR1220". Slide this open with your fingernail, and take the little coin battery down to your local drugstore to buy a replacement.
Oct 07, 2010 | Canon PowerShot A560 Digital Camera
I just charged my camera's batteries and an error
Your camera is telling you that the batteries have insufficient power. First thing to check is that the battery contacts on both the batteries and inside the camera are bright, clean and free of grease or oil.
Assuming that you're using the original NiMH rechargeable batteries which came with the camera, then you almost certainly need to replace them with new ones as they cannot be reused indefinitely.
To test whether the problem is with your rechargeables or with your camera is very easy. Just buy a set good quality, non rechargeable, alkaline (e.g. Duracell) AA batteries. If the problem disappears then you know that you need to buy new rechargeable NiMH batteries next time.
There is also a small possibility that you have a faulty recharger but it's unlikely. The only way to test it without special tools is to try getting your NiMH batteries charged in a borrowed recharger. If the batteries get fully charged then the error message on your camera will vanish and you'll need to buy a new recharger. Just make sure that the charger is designed for NiMH though or you will damage your batteries and possibly the charger.
Jan 15, 2010 | Canon PowerShot A560 Digital Camera
Hi I have just put brand new batteries in my canon powershot A560 and having taken approx 4 or 5 photos it is now telling me that my batteries need changing. The low battery symbol is also on alot of the...
Make sure that you use the correct type of batteries some cameras prefer Alkaline or Zinc Carbon both at v1.5 some only can take 3 rechargeable Nickel Cadmium (Nicad) Cells at 1.3V (3x1.5v= 3.9V) or one Lithium Ion at 3.6V
Be careful if you put a 1.3V NiCad Rechargeable in a camera that was designed for 1.5 Alkaline it can damage the camera and you may experience similar problems to that you have now.
Always check that you are using the recommended batteries, this is why most manufactures supply there own Lithium Ion 3.6V rechargeable K type cells to avoid this type of problem.
Jan 06, 2010 | Canon PowerShot A560 Digital Camera
My 2 yr old Powershot A560 is not accepting new batteries. The lense telescopes and the lcd briefly lights up with the red battery symbol flashing. I can preview photos taken, but I cannot take any new...
The battery you found (CR1220) is for the camera memory.IE time and date.Chances are the batteries that were installed are dead.Also check the contacts on either end of the batteries and clean if needed.
Dec 31, 2009 | Canon PowerShot A560 Digital Camera
Batteries wear out quickly
most cameras use alot of energy so it could be normal but you may be using batteries that dont put out enough voltage. your rechargeable batteries may be wearing out (as they all eventually do). i suggest trying out duracells. the computer may have just reconized the old camera so it knew what to do but since you got a new one, your computer doesnt reconize it.
Aug 07, 2009 | Canon PowerShot A560 Digital Camera
Need battery door for canon a560
Contact Canon themselves for a service center near to you.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Regards.
Jul 14, 2009 | Canon PowerShot A560 Digital Camera
Powershot A560 overheating
change your batteries our contact your customer care
Jun 20, 2009 | Canon PowerShot A560 Digital Camera
Canon PowerShot A560 Digital Camera Logo
405 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
