Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Side by side frigidare brand refrigerator model#frs6b5eew3
My refrigerator stop cooling the digital control panel behind the right door is dark is not illuminated when i push the on or off button it's does not come on the fan in the back that blows the coils comes on and lights inside the refrigerator works where do i start trouble shooting i own a oms meter
Check this out it may help you http://appliancehelp.hypermart.net/xmb_ge_arctica_sxs.pdf
Posted on Jul 29, 2007
MY FRIGIDARE MODEL FRS23ZTJ IS NOT WORKING RIGHT. THE REFRIGERATOR IS NOT COOLING. THE FREEZER SEEMS FINE. WHAT DO I DO NOW?
check the damper door located between the freezer and refrige compartments,it may be iced up in the closed position and can't let cold air in from the freezer,it may be covered behind a plastic cover or diverter,you may feel some cold air in this area moving if its open part way,if its iced up,use a hair dryer and defrost it then adjust the cold control in the refrige and see if the damper door opens and closes with adjustment of this control
Mar 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
My side by side Model GSH22KGRE BB freezer is
there is one of 2 possibilities,either the damper door between the refrige and freezer compartments is frozen shut due to ice build up and needs thaw out,the cold control that controls this door is bad or the mother board on the lower rear apron behind a cover panel is defective,if you have had light bulbs go out in the refrige compartment and now the refrige part does not cool and the temp light readout is dark this is a good indication its the motherboard,also if the lights are strobing and you can hear a relay clicking
Jan 17, 2010 | Refrigerators
My refrigerator & freezer no longer cooling
I will need to help you first by telling you I can help. But is it possible that you could find a model number and brand name.I see everything is going to be lost so if you want me to help you repair let me know soon, I will show you the places to look for these numbers in one moment. Sea Breeze
Dec 10, 2009 | Refrigerators
Only the freezer side is working
I don't think the darkness is related to the fridge not being cool. The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer at 32 degrees, fan running ,fridge cool
The evaporator coils behind the rear cover inside the freezer are probably iced over because of defrost system failure. Defrost system consists of defrost heater, defrost thermostat and defrost timer(or motherboard in newer models.)
Jul 27, 2009 | Frigidaire FRS26H5AS Side by Side...
GC5SHEXNQ02 Whirlpool 2door ref - Panel gets hot
I am not going to say the problem is normal. Normal operation those strips are placed behind the metal and inside the walls around the door seals to prevent moisture or sweating around the doors. They are usually noticed to become hot when there is a change in the control boards operation. Some brands have the hot gas from the condenser circulating around the doors. If your model has an economy switch, switch it on. I would look for any abnormal operation of the refrigerator like compressor or condenser fan stopping or ice buildup or abnormal temperatures in the fresh food compartment. If this continues I would unplug the refrigerator and open the control panel inside the fresh food section and examine both sides of the control board for signs of heat or burn marks on both sides. May not be anything to be concerned about also because this may be the first time you noticed this. But it should not be too hot to touch. Sea Breeze
Jun 23, 2009 | Refrigerators
Lights come on, not cooling, temp indicator shows (-)
Because your digital controls appear to be confused I think the electronic module behind the temp control is defective. The part number for your control board is 12868513
You can enter the model number JFC2087HRP in model and parts search feature at the link below. You may want to unplug refrigerator and examine the part for burn marks or other signs of damage. Let me know what you find, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
May 23, 2009 | Jenn-Air JFC2087HRP Side by Side...
Refrigerator stopped cooling
the back panel inside the freezer has screws in it. take out the screws to remove that panel. the coils are behind that. melt all the frost. youll see one or 2 heating elements in there also. replace the elements. its a common ge problem. this will fix the problem
Nov 27, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
116 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
R.A. Ellis
R.A. Ellis
