Question about Singer Sewing Machines
Singer thread c7
C7 error on singer one 1
3 Suggested Answers
SOURCE: Singer Futura 350 bogus thread breaking error
I had the same problem for a LONG time. Yesterday I finally removed the top and the cover for the upper tension and found thread fragments under one of the discs. I removed it and used compressed air for dust clean out and it is working wonderfully. Good Luck
Posted on Dec 26, 2009
SOURCE: I keep receiving the E-1 error that the thread is
Don't use Singer needles, go to where ever you buy your fabric and get a pack of Shmetz Universal needles, it will cost you $2.50 or something like that.
Also don't use cotton thread for a while, the sensors are very sensative when the machine is "breaking in", so use poly blend threads for the first few projects.
Posted on Jan 08, 2010
I have a Singer One sewing machine and every time I pushed the pressure foot it said C7.
Search for:
Make Model error code
there is also a Support contact on the Singer site.
Mar 10, 2018 | Singer Sewing Machines
Singer futura quartet seqs 6000 keeps giving me a broken thread error. Thread is not broken and I have done tried the unwaxed dental floss and canned air, Please help
Hello
Embroidery sewing machines will often give this error message due to low "drag" on the thread. Try placing the spool of thread upright into a cup on the floor and lead-up the thread as normal for threading. Make sure that the thread does not catch on the thread lock on the spool.
Happy stitching
Sewingirl/
Apr 20, 2017 | Singer Sewing Machines
I have a Singer 160. Was sewing fine then suddenly all I get after three stitches is a C6 error telling me the upper thread is broken but it isn't. I've rethreaded multiple times both upper/lower.
Remove the thread completely from the machine. ALWAYS RAISE the presser foot when threading the upper thread. If the error continues, there may be a piece of thread stuck somewhere in the thread pathway.
Apr 02, 2017 | Singer Sewing Machines
SINGER FUTURA XL-580 Error # 16 what does it mean and about sotution Thanks
Search the internet for:
Make Model error #16
or check the owner's manual Troubleshooting section. Frequently, it will list error codes.
this is from another website:
Singer Futura embroidery If the error code is not in your instruction manual, email singer at talk2us@singerco.com
1 ยท April 9, 2014 at 2:30pm
Heather Jamison
Heather Jamison I figured it out. It means the thread is tangled around the bobbin. Thanks
Nov 29, 2016 | Singer Sewing Machines
Singer error codes 6
You are getting a thread breakage error. I'm presuming that you are getting repeated error 06 codes to write in. Before I start, though, you also get that error code if your bobbin is out of thread. The thread sensor thinks your thread has broken because your thread is not seated at all, or not seated enough, between your tension disks, which are on the right side of your tension dial. Take the cover off the thread path (page 52 in your user's manual), lower your presser foot, and turn the tension dial to zero. Use UNWAXED dental floss, and floss between those disks. Chances are there is loose threads and/or lint between the disks, preventing the thread from seating properly. When threading, make sure that your presser foot is UP (tension disks are spread to accept thread), and apply tension to your thread, both at the top and bottom, to make sure your thread gets between those disks. Thread it a few times with the cover off, if necessary; you don't need to have it on to embroider, although you can't use your needle threader with it off.
Mar 05, 2014 | Singer Futura XL-400 Quartet 4-in-1 Sewing...
I have error C7 on singer one plus and it wont sew at all?
I was getting a C7 error on my Singer Heritage sewing machine every time I pushed the pressure foot. I decided to see if the reverse sewing button would work and it did. Then I pushed the pressure foot to sew again and it worked. Hope this helps someone else.
Jan 27, 2013 | Singer Sewing Machines
Singer quantum futura ce200 - thread breaks
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Feb 06, 2012 | Singer CE-200 Quantum Futura Computerized...
Oct 20, 2009 | Singer Sewing Machines
Aug 24, 2009 | Singer CE350
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
