The machine's display reads "incorrect" cartridges installed. Will print, but prints each copy as a separate operation, making a lot of noise in between.
Normal
0
Driver could be corrupt. Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Was this helpful?
Yes
No
Popular Solutions for Konica Minolta magicolor 2480
trying to print on thick paper on tray 1 but it says paper jam even though it has not taken the...
(More)
trying to print on thick paper on tray 1 but it says paper jam even though it has not taken the paper
Hi ! Well , i`m trying to fix my konica , it says cyane catige missing ... But the cartige is...
(More)
Hi ! Well , i`m trying to fix my konica , it says cyane catige missing ... But the cartige is allready instaled . If you guys have a service book for that kinde of printer , please send it over Thanks alot !
The block is only on copies, not on printouts from the computer or status reports from the...
(More)
The block is only on copies, not on printouts from the computer or status reports from the all-in-one itself.
I have a Konica Minolta Magicolor 2480MF. I am getting the "Black toner not installed"...
(More)
I have a Konica Minolta Magicolor 2480MF. I am getting the "Black toner not installed" message. I can remove the drum and one toner, but I can't figure out how to get the other two toners out. They won't rotate. I have read that I need to do this in order to clean the "crum reader". How do I remove the other two toners? The button that is supposed to rotate them doesn't work.
