Question about Intermec CK31 Barcode Scanner
How do you stop ITE from auto starting on a CK31 intermec scanner?
4 Suggested Answers
  • 13 Answers
SOURCE: Intermec CK31 handheld - Configure to read bracket symbol
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Posted on Sep 09, 2008
  • 61 Answers
SOURCE: My Intermec CK31 just hangs, it scan and there is
Sounds like you could have a main logic board problem. Try restoring computer to factory defaults from the intermec settings.
Posted on Apr 05, 2009
SOURCE: Intermec CK31 the most slow terminal.. is a piece
We have come across this many many times. After the terminal has fully booted (can take an hour when slow) and if you manage to access the CPU monitor you would be able to see that the CPU is running constantly at 100% - not good.
A complete blank and operating system restore is required.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Posted on Dec 10, 2009
Can't connect CK31 to Barcode software
Hi Chris,
You need a few things to be able to connect your Intermec CK31 to a server and all the settings are within the "Intermec Settings" within the terminals control panel.
First thing to start with is the wireless profile, set this up to match your current access point wireless settings, SSID, Encryption Type, Key etc. You can also set your wireless IP. Once this is done there will be an icon in the taskbar that shows connection and signal strength. Depending on the firmware revision of the terminal you should be able to use the tools to ping a device on your network, if the server responds to a ping then you should be able to get to your server when you try and connect.
I hope this helps.
helpdesk@biastechnology.com or TEL +44(0)1202 620955
Jun 19, 2012 | Intermec CK31C,COLOR TE2000,5KY LINR
The folder... is read-only because the prroxy server is not set up to allow full access.
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Dec 06, 2011 | Intermec CK31 Barcode Scanner
Scanner reads some barcodes (black and white, larger barcodes), but not smaller barcodes that are black w/gold background.
Acutually, some kind of conbinations of bar color and background color will prevent barcode readers from accurate scanning. So I think you should check whether your color combination is feasible first.
I want to attach an image, but it is too big to upload.
Feb 08, 2011 | Intermec CK31 Barcode Scanner
How to reset factory defaults to CK31? How I can put the settings to access WPA2 in wireless network?
Restoring Default Settings
You can restore the CK31 to factory default settings from
Intermec Settings.
Note: Using the Restore Defaults option restores all parameters
including network settings. When you choose to restore defaults,
you erase the registry. As a result, you may lose network
communications.
To restore factory default settings
1 From Intermec Settings, select Device Settings > Restore
Defaults.
2 Select Restore Defaults and choose the Run App button. A
Run Application dialog box appears asking if you want to run
the restore defaults program.
www.portablesolutions.com
May 12, 2010 | Intermec CK31 Portable Terminal
Intermec CK31 the most slow terminal.. is a piece of ****..
or TEL 01202 620955
Nov 07, 2009 | Intermec CK31
How do you put Caps lock on?
Click here, or copy and paste in your browser. It will take you to the manual and you can print it out.
Good Luck.
http://www.intermec.ch/handbuch/CK31_Handbuch.pdf
Apr 09, 2009 | Intermec CK31 Barcode Scanner
Ck31
Sep 07, 2008 | Intermec CK31 Portable Terminal
Mar 10, 2008 | Intermec CK31 Portable Terminal
Intermec CK31 Barcode Scanner Logo
42 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
