Question about Panasonic SC-HT830V System
Digital lighting is out on the front of the unit. Everythig works on that unit but you can't see what stations you are on or anything like that. Also do these units shuffle the cd's whilel lplaying music. Mine plays one disc then stops. You have to manually change the disc number to go to the next disc
  • Petteruti Feb 01, 2009
    LED lighting is out on the unit. Is it worth fixing. Or is there an easy fix.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    I do not have schematics of this particular model so unable to guide you.
    Shuffle and CD selection is just user matter and can be set when unit front display will glow.
    If you send me service manual of this unit in pdf format then I can help you out.
  • 79 Answers
Press the botton "Repea"t>"Disc"
Posted on Jan 31, 2009
Fuel guage always shows empty
It sounds as if the fuel tank sending unit is faulty. This is a small float connected to a variable resistor on the fuel pump/sending unit assembly. Unfortunately this assembly is fairly expensive (over $300) and the fuel tank may need to be removed to replace it.
Aug 23, 2012 | 1999 Isuzu Rodeo
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    All of a sudden everythig in purple / violet in
    There could be a issue with the lens or shutter which is causing the pic quality very bad. kindly get it check
    regards,
    priti
    May 28, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
    Hello
    Volume + power resets it - making the player turn off lets you know that the reset work
    Will it play non-radio music files fine?
    Once again, when you change the radio station, you must press the play or right-pointing arrow button, or it will just continue playing the last radio station that you had it turned to
    If it still won't change, then autoprogram the unit and select presets like it suggests in pp.32-35 of the manual
    Jun 13, 2008 | Philips GoGear HDD6330 MP3 Player
    Battery/Docking Station
    I have a working used one if you're interested. Google my username, and I can help out... ;)
    Jan 11, 2008 | Casio EXILIM EX-Z1000 Digital Camera
    Archos 604 not recognizing DVR Station
    Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
    Oct 29, 2007 | Archos 604 Digital Media Player
    Panasonic SC-HT830V System Logo
    204 people viewed this question
    Top Panasonic Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
