Question about DCS CTD304SSN Cooking Products : Cook Tops
How can I open my VGSU161-6BSS unit to see the spark module pant number in order to replace it?
I need to replace the spark module of my VGSU161-6BSS but I do not know the part number. I have been told by Viking part dealers that there are two part numbers that could suit me: PA020042 and PA020048, but to be sure I have to open the unit and get the correct part number. How can I do this? Burners Bases are hard to remove!
The ignitor keeps sparking and won't stop.Do not
First of all, the model number is under the cooktop bottom, and secondly, this can happen due to the burner switches got wet somehow. Best thing to do is to unplug unit for 6-12 hours, allow to dry, then re-plug unit back in, this should be enough time to dry out the burner switches.
Good luck
Jul 13, 2011 | Bosch Cooktops
How do I replace spark ignitor on GE JGP963SEF1SS gas cooktop?
If none of your burners are igniting, you need a new Spark Module. If only 1 or 2 of your burners are not igniting, you may need a Spark Igniter. Click on the pictures below for a larger image.
The Spark Module is number 318 in the following diagram (underneath the burners):
The Spark Igniter is number 154 in the following diagram:
Jun 02, 2011 | GE Cooktops
Piezo igniter won't quit
Possible stuck burner switch or failed spark module. Unplug unit. Remove wires from burner switches at module and plug back in. If it starts sparking, replace module. If it stops, then replace switch harness.
Jan 18, 2011 | GE 30 in. Profile JGP932 Gas Cooktop
GE Profile nat gas cooktop, Model No JGP636BEV3BB won't ignite
If you can hear the clicking sound but are not getting a spark then there is probably a short in the ignition system. Check for any loose wires on the ignition system. Make sure all the wires are properly seated. Make sure the spark module is properly grounded. As far as testing the spark module it should be generating a spark of course. The problem is that the average voltage for the spark module is 15,000 VDC so actual testing of that voltage can be difficult. Is the spark erratic?(should spark evenly). An erratic spark timing is a sign of a bad spark module. Is the spark slow? Check the polarity of the electrical plug. If it is clicking evenly then it is probably arcing somewhere inside the cooktop and you just need to find out where. Also be aware that if you get water into the cooktop that can cause possible grounding of the spark module or ignition system.
Jan 18, 2010 | GE Profile JGP636 Gas Cooktop
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Recived spark module for 6 burner gas stove on DCS gas oven/
I want to gas geyser using sparking unit (ckt Diagram)
Feb 28, 2009 | DCS Cooktops
I need a user manual
I need access to the spark plug module for replacement. The plastic stove top seems sealed to the metal housing. How do I gain access? Creda GH 102 series cooktop. Spark Module Replacement.
Apr 15, 2008 | Cooktops
Viking cooktop disassembly
Well, it happened again. I'd replaced the spark module last time around, due to spillage getting into/onto that control unit. This time around, I had one burner that just kept sparking after it was lit. Cleaning the sparking post (emitter) didn't solve the problem, but I realized that there might be contamination elsewhere in the connect. I pulled the brass rings (nuts, really) and was able to lift the the top off. I carefully removed the individual sparking wires from each burner, and examined each assembly. After cleaning some debris off the male connector for that bad burner's spark assy, and reassembling the cooktop, it worked!
Things learned: The top can lift off without having to worry about dropping the entire unit. (This probably varies by model). The emitters _and_their_connectors_ are sensitive to contaminants. This was an EASY fix! Thanks for the helpful instructions everyone!
Nov 10, 2007 | Viking 31 in. VGSU101 Gas Cooktop
Burners not lighting
I had the same issue and replaced the spark module myself, lots of wires and you have to make sure to label them before removal to be able to hook them back up correctly. To get to the module you need to unscrew all burners, no need to take the cover plate under the knobs. Burners remove by unscrewing center, brass nut. OEM spark module is VIKING RANGE #PA020021 U-67205-21. Go
od Luck
Apr 18, 2007 | Viking 37 in. VGSU161 Gas Cooktop
DCS CTD304SSN Cooking Products : Cook Tops Logo
270 people viewed this question
Top DCS Cooktops Experts
Timllfixit
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a DCS Cooktop Expert? Answer questions, earn points and help others
