Question about Hotpoint VWSR4150B Top Load Washer
The machine will not spin on high speed or pump the water out
    Problem Solver:
  • 10 Answers
Go to Britishjames.com
Posted on Oct 27, 2012
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My washing machine has stopped working altogether
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 05, 2010
My washer machine working in all function but in the spin function the motor rotate slowly
there is a problem in the program board
the unit starts to spin slow as the water is pumped out
that is supposed to distribute the clothes for balance and then it goes into a high speed spin
you unit is not progressing to that high speed spin
Call a technician for a proper diagnosis and fix
Nov 06, 2016 | Washing Machines
Although water does drain from machine pump seems to be trying to pump out all time
this is normal as the pump is controlled by the program and not the amount of water available
the spin speed can start slow as the sensors feel for out of balance before going to high speed spin
down load a operators manual for the machine from google site and if you still have problems call a service technician in to check it out.
Aug 29, 2015 | Washing Machines
My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
Mar 06, 2015 | Maytag Washing Machines
Kenmore front load washer model 41744052400 will not enter into high speed spin at end of cycle. I can run the test for the different cycles and can get the high speed spin, but only in the test mode. ...
Try to get the repair manual for your machine, it's worth the cost. Meanwhile, with the power unplugged, undo any wire connectors that just plug in and check for corrosion. Check the capacitor, a dent will ruin it.
Nov 26, 2013 | Hotpoint WMA64 Front Load Washer
My Hoover 500M top loader is very noisy on the spin cycle intermittanly. It sounds like a faulty or dry bearing, maybe when the water pump is emptying the bowl. The noise stops as soon as the spin cycle...
First I would bench check the water pump and see if it is operational or not. If it is then I would check the transmission. When it is in the spin cycle it switches to the high speed, so if you hear the grinding only in the spin cycle it could be the high speed gear.
Do you have any indication of a transmission leak? Fluid on the floor or on the transmission?
Jun 22, 2011 | Hoover Washing Machines
The water is not spinning out. the water is pouring out onto the floor when the spin cycle starts. not leaking when in wash cycle
You may have a pump that's bad. When it goes into spin cycle it assumes the water will be drained within a period of time before it goes into high speed spin. If it goes into high speed spin and the pump hasn't done it's job then you will get a bad mess, flood, water all over.
Rich
Western Appliance Repair
Appliance Repair Meridian
Oct 09, 2010 | Kenmore 9380x Top Load Stacked Washer /...
Duet
yes it should run continuosly,(at least untill the water level drops.) a more common instance withthis machine is that the drain line is blocked/restricted, or somethingis ninthe pump housing. it is even possible hat the pump impeller has dislodged from the housing and although it sounds as if its "pumping" its moving no water..usually in htis case your able to open the filter assembly and "pushback on hte impeller(normal impeller will not ,ove back" however if it was dislodged it will have foward play.i would even blow out the drain hose form the pump to the drain standpipe, just in case.
F02 is def a long pump out time and no ther ewill be no high speed spin with water in unit(or if it thinks thers water in unit)
Dec 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint VWSR4150B Top Load Washer Logo
24 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
