Question about Dryers
FGR231ASY GAS DRYER BURNS FLEESE MATERIAL CLOTHING WHY
WAS WONDERING WHAT I COULD DO TO FIX THE PROBLEM OF WHY IT BURNS FLEESE SHEETS AND CLOTHING
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
Hello my name is George,
I was wondering if the dryer was just burning fleece or all of your clothes. Fleece is a very delicate material, and should be dried on low temp or delicate depending on your drier. Driers are thermally protected inside with various parts. If the drier is getting to hot one of these would have caused the drier to stop heating. If the drier is burning all the clothes and not just the fleece I would recommend having a technician come out and check it as this could be a hazard for you and your family.
Posted on Oct 26, 2012
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: my gas dryer only burns for 15 seconds. which
Its only supposed to burn 15 seconds. That is normal. It cycles on and off all during the cycle. If it stayed on the thing would burn up. If you mean it works and quits or takes a long long time to come back on then you need to replace the control solenoids. Fell them after a burn. The hot one is the problem. 58a72fb.jpgpart number 279834
Posted on May 08, 2010
  • 8404 Answers
SOURCE: Dryer gets hot and partially burns clothing before
Check your exhaust system starting at the filter ... ending at the outside vent. Remove the hose and clean it completely ... If it is plastic, I recommend you replace it with a aluminum hose available at home centers and hardware stores everywhere.
Posted on Nov 01, 2010
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
Why do dryer sheets stick to the vent outlet on a Kenmore gas dryer?
The dryer sheets soften during the drying cycle to release the softening material. Air flow through the dryer drum causes the sheets to "glue" themselves to the vent outlet. If you have the dryer disassembled for service, you will find a sticky residue on the back of the vent.
Dec 31, 2014 | Kenmore 73952 Gas Dryer
Where do you put the fabric softener
In the dryer. Use dryer sheets - they're much more convenient and more direct. Clothing doesn't get stiff in the washing machine, it gets stiff in the dryer - treat it in the dryer, where it happens.
Better still, hang your clothing outdoors on a clothesline if you can - that's as good as it gets, and laundry CANNOT smell better than it does fresh off the clothesline.
Jul 25, 2014 | Kenmore Washing Machines
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
Mine gets too hot and burns clothing. how do I adjust the heat
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Mar 13, 2011 | Amana ALG331RAW Gas Dryer
Hello my dryer doesnt work properly it runs
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG dryer manual
Dec 13, 2010 | LG D2526 Gas Dryer
Whirlpool duet dryer - when using the settings that automatically sense if the clothing is dry the dryer is saying the clothes are dry but the clothing is still damp
Easy fix: Look inside the drum below where the filter goes in. You will see two metal strips. They sense the wetness. Now get this: the dryer sheets rub against them and a thin wax buildup on them prevents the controls from properly determining wetness. The control has no clue the clothes are still damp and thinks everything is kosher; so it advances to the end. Solution. Clean the stuff off of the sensors so that they can sense the true wetness once again.
May 22, 2010 | Whirlpool GEW9250 Electric Dryer
My electric dryer shuts off after about 20 minutes of drying
ok sounds like you are using dryer sheets,,,dryer sheets coat the automatic dry sensors and fool the unit into thinking the clothing is dry,,,,replace the sensor or try to clean it if possable with a green scrubbie,,,,also try the time cycle it dose not use the sensor.......www.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
Rust stains on clothing
Cleaned lint out of the dryer internal air ducts.
Replaced the upper and lower drum seals.
Aug 23, 2009 | Frigidaire Dryers
Same thing
Liquid fabric softners usually cause spots and/or marks on light colored clothing . If you rewash the clothing and the marks dissapear , then try using dryer sheets instead . However , if you have an older dryer , then clothing could be getting rubbed between the rear drum seal and panel , but that would cause streaks but no spotting .
Jul 26, 2009 | Washing Machines
Dryers Logo
91 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
