Question about Springfield 910491 Wireless Digital Outdoor Thermometer with Radio Control
Do not get outside temperature readings on the base station, only outside on the remote
Reads well outside the house, but not inside the house. Batteries have been replaced.
  • Gene Van Stedum
    Gene Van Stedum Oct 26, 2012
    I repeated the process, and after a trial or 2 of resetting the remote I got readings on the base  unit.  Problem solved.
2 Suggested Answers
bbl242003
  • 1637 Answers
SOURCE: Inside and outside temperture reads 158 degrees
Please remove the batteries from your wireless unit. Replacement the batteries after a few seconds and the digital unit will reset. If you continue to experience problems, please replace the batteries. If you have further questions, please return.
Posted on Jan 09, 2011
I have a new weathr station and can not get the outside temp. to display what can I do?
I assume it is a wireless station. If so, there is a procedure to go through to get the temperature sender and the base station to sync up and work. You need to check your owners manual to get the exact procedure for your unit. On my station, I have to remove the battery from the base station, let it power up and within 5 minutes, install the battery in the remote station(s) (temperature, rain gauge, wind gauge, etc.). Also, you must keep the remote station within a certain range for the base to get a good signal. Probably 25 feet, but the owners manual will have the right number. Also, use new batteries.
Aug 02, 2016 | Oregon Scientific WMR86 - Backyard Pro...
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
Replaced batteries, outsid temp. does not display
Jan 05, 2016 | Taylor Measuring Tools & Sensors
How do I get it to display outside temperature?
Usually, batteries have to be installed in the remote unit first, followed by house unit. Allow time for the remote unit to begin sending data to the house unit, then you should see it displayed.
May 15, 2015 | Measuring Tools & Sensors
Why is the outside temperature not displaying on the base?
After a battery replacement, the outside and inside units have to "talk" to each other before you can get a display. Also, the outside unit's batteries have to be replaced first. You should not press any buttons for 10 minutes until the two units have finished "talking"
Jan 24, 2013 | AcuRite Acu-Rite 00593W Wireless Weather...
Indoor temp is 5 degrees colder than display reads on digital thermostat
Where are you measuring the indoor temperature?
To compare it to the thermostat temperature you have to measure both temperatures at thermostat.
The thermostat will only control the temperature at the thermostat, not any where else in the room.
The room temperature depending on insulation in walls and ceiling and distance from outside wall and outside temperature, can be as high as 10° difference from outside wall to inside wall of house.
The lower the outside temperature, the greater the room difference in heating. The higher the outside temperature the greater the room difference in cooling.
Feb 13, 2010 | Honeywell Programmable Thermostat Heater
My new storm tracker STX7500 weathertech does not display the outside temperature
Take out the batteries in the main station for at least 5 min. Also, check the batteries on your outside station and make sure that they are new and the same brand, not rechargeables. Make sure that the outside station is reading a temperature and humidity first. Make sure that the outside gauge is close enough to your inside station. Having your inside station to near electrical or metal things or the outside station too far from the inside station is the most likely of your problems. To test this, once you've restarted your inside station, bring it close to the outside station and see if it's reading. Also, check the bottom right to see if your inside station has an antenna icon. If so, it's just updating from the radio station that updates your station often. Wait for that antenna to disappear from the bottom screen before trying to figure if your outside station is reading correctly. Finally, make sure that you have the right time zone, state, and city programmed into your inside station. If none of these work, call or e-mail the link in your book. Hope this works.
Dec 28, 2009 | Discovery Channel Toys
Outdoor device won't register inside.
All these wireless weather station devices have to be paired to the base unit whenever the batteries are changed in any of the remotes. It's a poor design issue, but there is no way around it, due to the nature of wireless operation.
Place both units near each other and look on the back of your base and remote sensor units, you should find a reset button (or a small hole). Either press the button or use the end of a paper clip to depress and hold the reset on each unit; Base 1st, then the remote 2nd.
After a brief moment, the remote should register with the base and you'll be back getting wireless readings.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | Kitchen Appliances - Others
Springfield 910491 Wireless Digital Outdoor Thermometer with Radio Control Logo
70 people viewed this question
Top Springfield Measuring Tools & Sensors Experts
ray gallant
Tom Chichester
Are you a Springfield Measuring Tool and Sensor Expert? Answer questions, earn points and help others
