The directions and not helpful and there is no button on there that will help sync the drums.
Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
Insert a Wii Balance Board compatible game into the Wii system.
Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
Turn the Wii Balance Board upside down.
Remove the battery cover under the balance board to reveal another sync button.
Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
Also cannot get the Rock Band Drum kit to sync with the Wii
the wireless drums will not sync to the wii console
Drums won't sync, just flashing blue light.
I bought the rockband drum set it only came with one cord.
I plugged it in to the Wii the blue light came on but how do you sync the drums?
Iv'e tried everything.
Any suggestions
Dongle light goes solid but console still doesn't recognize them as a controller
the cord that came with the drums has no reset button.
rockband drums original have built in control ,still can,t sync.
any suggestions?
Can't sync drums with wii only one cable came with drum set, do I need another cable to make it work?
I have rockband original drumset.
Blue light comes on when plugged in but thats all.
Sync lights on drums don't come on at all.
Any suggestions?
Thanks
We have tried two drum sets on two different Wii systems, Rock Band 2 Drums won't sync.
I have the same problem, Blue Light on the Rock Band 1 drums is on, but wont recognize as a controller and wont work
