Question about GPS
Fuse and spring fell out of charger 320-00239-24. What goes back in first, spring or fuse.
    Problem Solver:
  • 17 Answers
Make sure nothing is plugged in first.
Should not matter which goes first, they should go in together. The spring is to let the fuse have a good contact.
Posted on Oct 26, 2012
Testimonial: "First time user. Very fast response. Thank you"
What fuse goes in streamlight car charger
find the watts and voltage of the light , watts divided by volts. Example 100 watts divided by 12 volts = 8.4 amps. use a 10 amp fuse.
Nov 13, 2016 | Streamlight Camping, Backpacking & Hiking
Took out cable connection charger, that attaches to Garmin NUVI, from cigarette lighter in car and the inside springs broke
that's how you can change the fuse.the piece at bottom of picture goes into the threaded piece 1st.
The piece at bottom of picture goes into the threaded piece. The spring goes into the body of the charger then the fuse and then the
threaded piece with the small piece still inside of it is screwed on.
Should work.
Oct 28, 2012 | GPS
To replace the fuse in my garmin 650 car charger, when reassembling which goes in first the spring or the fuse ? The cap came off and the spring and fuse fell out and I am not sure how to reassemble it.
As long as it works correctly when assembled it doesn't matter, the spring is part of the circuit and as long a the fuse and spring have contact with the tip and internal connection the circuit will function properly without any risk of damage to the device. Most times the spring goes in first though.
Mar 13, 2011 | Garmin nuvi 650 GPS Receiver
My GTM 20 tip got unscrewed and the parts fell out. I put the parts together and then found out that both the car socket fuse and the GTM 20 fuse were busted. I replaced both fuses. The car socket works...
The GTM 20 can be repaired. It's likely that either you're not using the correct fuse or there's a short circuit. The short circuit would be caused by the metal tip, spring or fuse touching the outer part of the plug. There's a repair kit available from http://www.gpscity.com/garmin-replacement-parts-for-gtm2x.html
Jan 26, 2011 | Garmin GTM 20 Lifetime Traffic Receiver...
My garmin goes at usb mode when i put the car charger on it.how can i fix it
the car charger plug has a fuse in it check the fuse
To do that ...Unscrew the silver tip of plug.... be careful its spring loaded
check the 3A fuse
Oct 25, 2010 | Garmin nuvi 260W GPS Receiver
Power cord light does not come on and garmin does not charge. Unit was ust bought in May 2009.
make sure the socket is working that your plugging the charger in to, like a cell phone. if you verified that the car socket is good, there should be a fuse in the tip of the car charger where it goes in the car socket....just unscrew the tip off...if there is no tip on it, its probably fell off and might be in the car socket.
if the car socket does not power anything else up, locate the fuse in the fuse panel of the car an check the fuse.
if you need further help, just let me know by replying to this post.
bill
Mar 07, 2010 | Garmin nuvi 255W GPS Receiver
Car charger for nuvi 205w
The Garmin Chargers use a 1A 5x20mm glass fuse in the tip.
The DC output of the charger is +5VDC @ 1A. The 1A rating is the max rating and your Nuvi should draw less than 1A under normal conditions.
You would not want to put a 3A in there because if there is a short in the Nuvi, you want the fuse to blow quickly. A 3A fuse is too high in value.
- Jim
SHARCNET-USA
Sep 09, 2009 | Garmin nuvi 205W GPS Receiver
The part that goes into the cigarette lighter broke on my Garin Nuvi. When I pulled it out, the small metal pieces, and a little glass tube fell out. How do I put it back together?
The glass tube is the fuse. There should be a spring and threaded metal barrel with a metal tip that slides through it. Look for these (4) parts.
The spring goes in first, followed by the glass fuse and then the metal tip should pass through the metal barrel. Screw the metal barrel with the tip on the end over the fuse. When you press on the tip, it should push in a little and spring back out. If you lost the pieces, you'll need to purchase another charger.
- Jim
SHARCNET-USA
Dec 16, 2008 | Garmin nuvi 255W GPS Receiver
GPS Logo
145 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
