Question about Uniden D1660 Cordless Phone
I have a Uniden phone with Cable phone service. Sitting right beside the base set, I get the message that I am too far away. Solutions?
I was on a long distance call. For less than five minutes, when the call was dropped and it said I was too far from the base. I called back, talked for less than 15 seconds and the call was dropped again. This is a new phone and the Cable phone service is also new. The phone is never off its base unless I am making a call. I am the only one who uses this phone and I have been out of town for four days and the phone has been on the base all that time. The handset is fully charged and the signal from the base is strong.
    Problem Solver:
  • 17 Answers
Unfortunately the Unidens have a problem with batteries. Leaving it on the base for a long time without discharging it can lower the lifespan of a battery.
But your problem is that the it lost connections with your service provider. Turn off everything by unplugging the power only from all the devices. Turn on just your cable phone service box first and give it 5 minutes to connect. Then power on the phone. If you still have issues, you need to contact your phone service provider to make sure the box is connection.
Posted on Oct 26, 2012
Fixe_You
  • 1800 Answers
SOURCE: Uniden Power Max 5.8 - (TRU8880-2)
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
please rate this post
Posted on Aug 25, 2008
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
SOURCE: Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Posted on May 06, 2009
Both our uniden phones are displaying New CID:28 and New CID:29 and we are neither receiving or can make calls??? What does this mean?
page 26 of the user manual ( detc 6)
problem --no handsets can make or receive calls ===possible solutions
check telephone cord connected at wall socket
disconnect the base ac adaptor for a few minutes , then reconnect it
move the hand set closer to the base
the cid :26 is caller I D number 26 and so on
google www.uniden.com.au for user manuals for other models
I googled ---messages cid 26 on uniden phones disconnects phones ---and got a list of uniden sites that may have the answers you want
Sep 18, 2017 | Uniden Lands Phones
The hand-set on the main station, has a red light on the upper right corner, this light BLANKS all the time. Also, the message in the display window states <Hand Set too far from the Base ...
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
May 29, 2011 | Uniden Cordless Phone
Searching and out of range message keep appearing. Can't dial out or receive calls Uniden Dect 6.0 (both phones) Tried to register base but unsuccessful.
This is because of the following reasons
1.The handset is far away from the base unit.Try to bring the hand set near the base unit and try.
2.The base unit is not plugged in to the power supply.Please check it.
Thanx
Jul 27, 2010 | Uniden DECT 6.0 Cordless Telephone...
Keeps saying I'm too far away from the base when
The best thing would be to take out any plug ro anything from the wall
then put your cordless phone on the base for 10-15 seconds to reset everything.
the resetting should work as i had problems like this
Jul 26, 2010 | Uniden Cordless Phone
I have a Uniden PowerMax 5.8 the message light won't turn off how do i fix it
To make the message light go away when there are no messages - remove the handset from the base and press and hold the "find handset" key for 5 seconds. Resets it!
Jul 04, 2010 | Uniden Cordless Phone
Uniden 6.0 answer/base/ cord less message set up
Thanks for using FixYa.
Please let us know the complete model number of the phone.
May 15, 2010 | Uniden DECT 6.0 Cordless Telephone...
Phone message reads
If you are not too far away-not "out of range" then try rehoming/pairing the handset with the base unit. You probably need the phones together to do this. Your manual will explain how-it will have been done in the original setup.
Oct 03, 2009 | Uniden TCX905 Cordless Accessory Handset...
How do I retrieve my voice mail when I'm away from home?
Go to the base unit.
scroll to the answering machine option.
Under there is a setting for your security key.
you can read what's there, or change it to your own two digit code.
when you call in, during the message, enter that two digit code and it'll go into messages. There's a "toll saver" mode so that the machine answers after two rings instead of 4, so that if you call and it rings 3 times, you know there's no new messages.
Manual:
http://www.uniden.com/pdf/DCT648-2om.pdf
Feb 03, 2009 | Uniden DCT648-3 Cordless Phone
No dial tone. No calls. Can't call out.
E4 IS AN ERROR MESSAGE, THE BASE IS NO LONGER GOING TO WORK, POSSIBLY A POWER OUTAGE COULD OF DAMAGED THE BASE.
Dec 28, 2008 | Uniden Cordless Phone
No dial tone...but can hear the tv
move the Base unit away from the TV. Check if ADSL filter in use may need to replace one or all ADSL filters
2.4 GHZ hmmm do you have 802.11 BNG WI FI in use with any of your computers ???
2.4 Ghz is a problem as computer WI FI uses this frequency as well !
check the line cord is plugged in to the base unit
Check base has power
May 24, 2017 | Uniden DCX770 for DMX700, DCT600 Cordless...
Uniden D1660 Cordless Phone Logo
123 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
