Question about Kitchen Ranges
No electronic oven control guide for oven settings.
I recently purchased a kenmore smooth top electric range,which according to your web site does not exist(unless it's a panasonic car radio). The oven did not come with any instructions,the store kindly printed off the instructions for us but not for the electronic oven control guide(which I need because my last oven I got in 1992 and it belonged to an older couple that had decided to upgrade). I know nothing about setting the oven. Please respond soon. Thank you Lisa
product is actually kenmore smooth top range C970-65732800 not what I had to record at bottom.
  • unicornuslad Jan 04, 2009
    I could not access web sites, not even when I tried to type them in myself. Thanks anyway
    Scholar:
  • 140 Answers
Hello, here is the link to your manual.ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318200445en.pdf
and here is the link to the controls ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318200167.pdf.
Don't worry about it saying electrolux. They make some of the Kenmore appliances. Hope this takes care of you and don't forget to rate me. Thanks.
Posted on Jan 03, 2009
My model #C970-655821 that I got from the pull out drawer on bottom doesn't exist
Kenmore models start with 3 numbers a dot or period and six or seven numbers after the dot. I checked Sears web site and indeed these numbers don't work. The model plate will say model number but there shouldn't be any letters in the number.
Oct 04, 2014 | Kenmore Electric Smooth Top Stove
While oven on range top front is very hot
I do not know the unit but check if the oven vent is near the front. It is also possible the door seal on the top of the door is failing.
Apr 13, 2014 | Kenmore Electric Smooth Top Stove
Oven continues to heat after reaching set temperature
It's held in place by 2 screws in the oven. Take out the screws and pull the wire gently. It has a connector on it but if it comes unplugged or the wire breaks inside a simple fix just got complicated. God luck.
Eric
Sep 18, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
What product do I use to clean my Kenmore 95034?
Fofr the top I recomend a smooth top cleaner call cerama bryte, you can get it a any Menards or Lowes, the oven is a self cleaner so I would only use that to clean the oven
Jul 21, 2009 | Kenmore 95032 / 95034 Electric Kitchen...
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Oven does not work
somthing shorted those are easyer to repair because theres evidence some where.turn off power and surch 4 that burnt spot then repair accordingly.most common on electric stoves are the element shorting you would see blistering on the element.God bless,tom
Jan 01, 2009 | Kenmore 95822 / 95824 / 95829 Electric...
Kenmore Model #790 - smooth top range
Probably not. It sounds like your broil element burned out. This just happens sometimes. If it is this , it will have visible chunks missing. Yes, It shorted with enough force to blow the main fuse. Unplug it as sometimes it can still be live and sparking when power is restored. Element is fairly cheap usually less than $50 and you can fix it yourself.
Jun 19, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Kitchen Ranges Logo
402 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
