Question about Bosch 0280120301 Throttle Position Sensor
Where does the throttle position sensor go?
I have all ready bought a throttle position sensor and do not know where it goes.
  • Bosch Master
  • 14,406 Answers
WHAT KIND OF VEHICLE.
Posted on Oct 27, 2012
The other day my car wouldn't take gas so my brother said it was my transmission fluid so he changed it and put a new tube on my car. So yesterday it drove jus fine but today im ready to go to work goes...
could be a clogged fuel filter, bad throttle position sensor, bad throttle cable, clogged fuel line, bad fuel pump, bad map/maf sensor. have your throttle position sensor and cable checked.
Mar 23, 2015 | 2005 Nissan Sentra 1.8
WHAT DOES P0123 MEAN?
SYMPTOM
P0123-THROTTLE POSITION SENSOR VOLTAGE HIGH
WHEN MONITORED
With the ignition ON and battery voltage above 10.4 volts .
SET CONDITION
Throttle Position Sensor voltage at the PCM goes above 4.5 volts for 3.2 seconds .
POSSIBLE CAUSES
  • Clock spring shorted
  • Throttle position sensor sweep
  • Intermittent condition
  • Throttle position sensor signal circuit shorted to 5 volt supply circuit
  • Throttle position sensor signal circuit shorted to battery voltage
  • Throttle position sensor internal failure
  • Sensor ground circuit open
  • Throttle position sensor signal circuit open
  • PCM
hope this helps, Tim 423 327 4108
Jun 06, 2014 | 2001 Dodge Dakota
What is a throttle positioning sensor
A throttle position sensor (TPS) is a sensor used to monitor the position of the throttle. If it goes bad (and they do sometimes) it will cause your check engine light to show up. I have never had anything bad happen to any of my cars when the TPS goes bad. Just need to get the part and replace it.
Mar 05, 2013 | 2009 Chevrolet Malibu
I do not know where the throtlle position sensor has to go
Year, make, model, engine size would be helpful. The TPS would be located on the throttle body on the opposite side ot the throttle cable
Oct 26, 2012 | Cars & Trucks
need to know make of car. model and engine size.also the year. good-day ! but most are found on throttle body at the throttle plate !
Nov 13, 2011 | Cars & Trucks
Need to know were this part goes tps4111 acelerador throttle sensor
The throttle position sensor is going to be located on the throttle body.This sensor detects the position of the butterfly to the PCM to regulate fuel and air mix along with information from other sensors.
Feb 08, 2011 | 2004 Suzuki Verona
I have a 2006 chevy aveo. i was told the throttle position sensor was out. i bought the sensor. i cannot find the location on the engine where it goes. is there a photo available which would show the...
Easiest thing to do would be to follow the air intake tube to the throttle body.( big round rubber or plastic that goes from front area of car to engine and is usually held on with a clamp where it attaches to intake of throttle body) Right in that area, you will see your throttle linkage/cable etc, and where it pivots when gas pedal is pushed. Look opposite side of that housing and you should see the throttle position sensor.
Jul 27, 2010 | Chevrolet Aveo Cars & Trucks
VEHICLES STARTS BUT GOES OFF IMMEDIATELY. iF GAS
The throttle position sensor responds to the accelerator pedal movement. This sensor is a kind of potentiometer which transforms the throttle position into output voltage and emits the voltage signal to the ECM. In addition, the sensor detects the opening and closing speed of the throttle valve and feeds the voltage signal to the ECM. Idle position of the throttle valve is determined by the ECM receiving the signal from the throttle position sensor. This one controls engine operation such as fuel cut, etc. The throttle position sensor unit has a built-in “wide open and closed throttle position switch,” which is not used to control the engine. For the G35, the throttle position sensor is part of the throttle control actuator.
Jun 08, 2010 | 2004 Infiniti G35 Sport Coupe
Diagram throttle position sensor for jeep grand cherokee limited 2004
Take the Intake Air Hose off. This goes from the Air Filter to the Throttle Housing. When you see the Throttle Gate draw a horizontal line across the center - this should be the the Throttle Gate Pivot Arm. The Throttle Position Sensor is lined up with this Pivot Arm. It should be the only sensor lined-up with this. There should be a Idle Air Sensor that is located above this, but this is not lined-up to the Throttle Gate Pivot Arm.
Let me know if this helped, or if you have additional information or questions. Feel free to contact me on FixYa.com!
Jan 06, 2010 | 2004 Jeep Grand Cherokee
Here is the problem when i start my car 1999 vw passat 2.8 v6 the check engine light turns on then when i try to asselerate the engine, it goes up to 1500 rpm and 2000 rpm it goes up and down, then if i...
I researched this & you need to replace the throttle body gasket & get the throttle body re-calibrated. Seems to be dealer only. Also, the t.p.s. (throttle position sensor) could be bad.
Jun 23, 2009 | 1999 Volkswagen Passat
Bosch 0280120301 Throttle Position Sensor Logo
54 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
