Question about Frigidaire Affinity ATF7000ES Front Load Washer
E68 error code on frigidaire affinity
Removed lint filter casing and cleaned inside, error still showing
  • Official Brand Answer
  • 4,342 Answers
Hello - Typically error code E68 can indicate one or two issues. First problem could be that one of the keys (buttons) is stuck closed (active). Enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again. If button is free but the error code still exist, the electronic control will need to be replaced. Second issue could possibly be a current leakage to ground on heater or fuse opened. However, I would strongly suggest contacting a professional to the check the resistance of the heating element (should be approximately 14ohms) or the resistance between the ground and both heater terminals. It should be open when heater terminals are disconnected. If the readings are incorrect, replace the heating element.
Posted on Oct 26, 2012
SOURCE: ERROR CODE E20
Just fixed mine, only I did not have to take it all a part. Just tip it over and reached in thru the opening in the bottom. Took the clamp loose with a phillips screwdriver and pulled the rubber off that contains the filter. Stuck my hand in the opening and pushed up on the filter from the bottom on the rubber container. Out came the filter and I cleaned it and pushed back down inside until it was past the lip that held it in place. Works great, took about 10 mins., not bad for a woman, huh. Thanks for the info, could not have done without your diagram and information.
Posted on Jul 26, 2008
  • 1525 Answers
SOURCE: Code E36 and Code E68
hello e36 means control board problem E68 means current leakage to ground on heater or fuse opened
shaun
Posted on Jan 14, 2009
SOURCE: Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Posted on Sep 26, 2009
  • 2468 Answers
SOURCE: how to clean a affinity frigidaire front load
remove the toe kick panel just below the front door and its located right below the drum
Posted on Oct 01, 2010
SOURCE: Frigidaire Dryer Error E 04
I have the same problem. Does anyone have an answer?
Posted on Feb 21, 2011
Frigidaire affinity LEQ6000ES2 error code e68...dryer will not start
Good Afternoon David,
I understand that your Frigidaire Affinity dryer, model# LEQ6000ES2, is showing you an error code of E68 and will not start. I also see that you have changed the thermal limiter. Looking at what the E68 error code means, a key or button stuck, there could be something else causing the code to come up. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the E68, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire Dryers
Why is my Frigidaire affinity showing code E68?
Good Morning Gary,
I understand you are receiving an E68 code on your Frigidaire Affinity washer, model# ATF7000E. The E68 code states that there is a current leak to the ground on the heater or there is a fuse open. This could also be a false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 19, 2014 | Frigidaire Affinity ATF7000E Front Load...
Error code e68
Good Afternoon Friend,
I understand you are receiving an E68 error code on your Frigidaire Affinity washer, model# ATF7000E. The E68 error code states that there is a possibility something is going on with the heating element inside your washer. It could also be a false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start your washer on the hottest cycle on a heavy soil level. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Affinity ATF7000E Front Load...
I have a Frigidaire Affinity Clothes dryer manufactured in 05/07 that is displaying a code E68 after in runs for just a few minutes. Any idea what could be causing this?
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Mar 06, 2011 | Frigidaire Electric Dryer
My frigidaire dryer start and a few seconds later an alarm sounds and E68 appears.
Remove your lint filter. Now remove the waffled plastic that covers the lint filter slot. Hint, its inside the dryer, and there's two screws holding it in. Be careful when you pull it out, because there's two wires connected to the metal strip on the bottom edge of it. That metal strip is either the temperature or moisture sensor, I bet. Don't drop the screws into the lint filter slot. If yours is like mine, you'll find that a lot of lint has built up around the contacts for those two wires. Carefully clean all the lint (use soft toothbrush), and reinstall. While you have it opened up, stick your vacuum's crevice tool down inside the lint filter slot and clean up all the lint in there as best you can. Problem solved. I think the build up of lint was shorting the two contacts, and this was screwing up the electronics.
Sep 12, 2010 | Frigidaire AEQ6000ES Electric Dryer
My dryer SHOWS ERROR 68 ON PANEL and shuts off?
Error 68 can mean that your start button is stuck; check to make sure the button is not stuck in the pressed position behind the controls cover.
Apr 25, 2010 | Frigidaire Electric Dryer
Jul 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
HELLO,
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity Front Load Electric Dryer
I have a totally unrelated solution. Remove your lint filter. Now remove the waffled plastic that covers the lint filter slot. Hint, its inside the dryer, and there's two screws holding it in. Be careful, because there's two wires connected to the metal strip on the bottom edge of it. That metal strip is either the temperature or moisture sensor, I bet. Don't drop the screws into the lint filter slot. If yours is like mine, you'll find that a lot of lint has built up around the contacts for those two wires. Carefully clean all the lint, and reinstall. While you have it opened up, stick your vacuum's crevice tool down inside the lint filter slot and clean up all the lint in there as best you can. Problem solved. I think the build of of lint was shorting the two contacts, and this was screwing up the electronics.
Sep 09, 2007 | Dryers
Washing Machines Logo
110 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
